ASUS SE465-Y Commercial Media Player displays feature 178-degree wide-view angle Full HD 1920 x 1080 panels for stunning visuals. With 500 cd/m2 brightness, making SE465-Y ideal for semi-outdoor wall-mounted, shelved, or end-cap installations. An embedded ambient light sensor automatically adjusts display brightness depending on environmental conditions.
SE465-Y display has a built-in multimedia player that supports various video, audio, and image files, as well as Windows Office and PDF documents. It comes with 4GB of onboard memory, enough storage for most media files.
The all-in-one design of the SE465-Y makes it an ideal, cost-effective solution for any business. You can put it at a shop entrance, display window, or exhibition booth to entice customers with product and sales promotions. The embedded media player makes it easy for you to conduct boardroom presentations; there are also extensive connectivity options like DisplayPort, HDMI, DVI-D, and D-Sub for laptop users.
Giving you the best images in any environment
The SE465-Y will capture viewers' attention with high quality digital content at Full HD 1920 x 1080 resolution. There's little or no color shift, image distortion or degradation too, thanks to the use of 178° wide-view angle panels. An ambient light sensor intelligently adjusts display brightness depending on environmental conditions to deliver the best images anytime, anywhere. -
Plug-and-Play convenience and support for numerous file formats
SE465-Y displays support a wide range of file formats and can automatically detect and play them the moment you plug in a USB drive. It's especially useful in the boardroom, allowing you to easily share your Microsoft Office and PDF files. It also comes with extensive connectivity options like DisplayPort, HDMI, DVI-D, and D-Sub for laptop users. For added convenience, these displays come with a built-in media player, stereo speakers, and 4GB of storage space. Its all-in-one designs make them ideal cost-effective solutions for any business. SE465-Y displays are suited for use in semi-outdoor environments such as train stations as well, where they can serve as information points for commuters. -
Power built-in 10 W speakers
Select SE465-Y models feature built-in twin 10 W speakers to provide quality audio to accompany what's onscreen. The speakers' rear placement maintains the display's streamlined profile, and gets rid of the need for external speakers.
- ASUS SE465-Y 46" LED-backlit LCD display - for digital signage
- Product Type
- LED-backlit LCD flat panel display
- Diagonal Class
- 46"
- Commercial Use
- Yes - digital signage
- Black
- Resolution
- 1920 x 1080
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- Connectivity
- LAN
- PC Interface
- DVI, VGA (HD-15), HDMI, DisplayPort, USB, serial RS-232
- LCD Backlight Technology
- Edge-lit LED
- Image Aspect Ratio
- 16:9
- TV Tuner
- No tuner
- Commercial Features
- Digital signage
- Speaker System
- 2 speakers
- DVR
- Flash - 4 GB
- Storage Drive Capacity
- 4 GB
- Storage Capacity
- 4 GB
- USB
- Included Accessories
- Remote control, IR extension cord
- Voltage
- AC 120/230 V (50/60 Hz)
- 200 Watt
- Power Consumption Stand by
- 0.5 Watt
- 104.8 cm x 5 cm x 60.2 cm
- 21.5 kg
- Environmental Standards
- ENERGY STAR Qualified
- Product Type
- 200 Watt
- Diagonal Class
- 46"
- Commercial Use
- TV Tuner
- No tuner
- TV Tuner Presence
- No
- Video Interface
- Component, HDMI
- HDMI Ports Qty
- 1 ports
- PC Interface
- Modes
- Portrait mode, landscape mode
- 104.8 cm
- 5 cm
- 60.2 cm
- 21.5 kg
- Enclosure Colour
- Black
Display
- Resolution
- 1920 x 1080
- 16:9
- Edge-lit LED
- Colour Depth
- Up to 1.07 billion colours
- Image Contrast Ratio
- 4000:1
- Dynamic Contrast Ratio
- 32000:1
- Brightness
- 500 cd/m²
- Viewing Angle
- 178 degrees
- Viewing Angle (Vertical)
- 178 degrees
- Pixel Pitch
- 0.53025 x 0.53025mm
- Response Time
- 6.5 ms
- Digital signage
Stands & Mounts
- Flat Panel Mount Interface
- 400 x 400 mm
DVR
- DVR
- Flash - 4 GB
Media Player
- Supported Video Formats
- MPEG-4, Xvid, AVI, MOV, VOB, RMVB, MPG
- Supported Audio Formats
- MP3, WAV, AC3, AAC, Ogg Vorbis
- Supported Pictures Formats
- BMP, JPG
- USB Port
- USB Ports Qty
- 1
- Configuration
- 4 GB
- 4 GB
Remote Control
- Remote control
Audio System
- Speaker System
- 2 speakers
- Output Power / Total
- 20 Watt
- Speakers
- 2 x main channel speaker - 10 Watt
Network & Internet Multimedia
- Connectivity
- LAN
- LAN Protocol
- Ethernet
- Connector Type
- VGA input , VGA output , Component video input , HDMI input , DisplayPort input , Audio input , Audio output , Audio output , DVI-D input , Serial input , Serial output , USB 2.0 , LAN , USB 2.0 , Remote control
- IR extension cord
- Cables Included
- VGA cable
- Plug and Play, UL, VCCI, BSMI, CB, FCC, PSE Mark, RCM
Sustainability Information
- ENERGY STAR Certified
- ENERGY STAR Version
- 6.0
- Power Device
- Power supply
- Input Voltage
- 0.5 Watt
- On / Off Switch
- 0 °C
- 40 °C
- 20 - 80%
