SABERTOOTH Z77: The ultimate thermal solution for Intel® Z77 motherboards with Thermal Armor and Thermal Radar
- LGA1155 Intel® 3rd/2nd Generation Processors Ready
- TUF Thermal Armor - Total Airflow-Boosting Heat Dissipation
- TUF Dust Defender - Repel the Dust, Expand the Lifespan
- TUF Thermal Radar - Real Time Temp. Detection and Heat Removal
- TUF Components [Choke, Cap. & MOSFET; Certified by Military-standard] - Certified for Tough Duty
- New DIGI+ Power Control - All-New Digital Power Control for both CPU and DRAM
TUF /t?f/, stands for The Ultimate Force.
The TUF series delivers a "tough" image. With the unique design & high quality components (military-standard), TUF series is born for pursuing the preeminent stability, all-round compatibility, and extreme durability
"Ultimate COOL!" Thermal Solution: Thermal Armor, Total Airflow-Boosting Heat Dissipation
New generation Thermal Armor boosts cooling with dual turbo fans, enhancing the original TUF thermal design and helping direct hot air away from components and the motherboard via smart shunt funneling. It covers the entire board with more powerful airflow, and uses special heat pipes to expedite thermal removal and make sure temperatures stay low. The dedicated I/O cover fan draws additional cold air in and expels even more heat for improved stability, plus new Thermal Armor comes with special convection holes in the PCB to facilitate underside airflow. It now sports a cool military-themed style, perfect for case modders.
Thermal Radar: Real Time Temp Detection and Heat Removal
Thermal Radar monitors temperatures in critical parts of the board, automatically adjusting fan speeds for better system stability. Fan Overtime keeps fans working in critical minutes post shutdown to extend component lifespan, dropping temperatures by 7?C in just ten minutes after the computer turns off. New Fan Off consists of a switch that disables fans should temperatures drop below a manually or automatically set level for effective power consumption.
"Safe & Stable!" Guardian Angel: Dust Defender, Repel the Dust, Expand the Lifespan
Dust particles and environmental contamination present a constant hazard to the optimal functioning of slots and connectors. Build up on contact points within slots compromises data transfer over time, negating the benefits of expensive and critical components such as graphics cards. Custom TUF design keeps this in mind with special shields that resist particulate entry, effectively extending slot and connector lifespan while promoting better performance.
ESD Guards: Unique protection of motherboard components from unexpected electrostatic discharges (ESD)
Electrostatic discharge (ESD) can happen suddenly and its damaging effects is often underestimated. Exclusive ASUS anti-static chip, a protective circuit design, and the I/O shield provides four times better protection to extend component lifespan.
This motherboard supports Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors are among the most powerful and energy efficient CPUs in the world
Intel® Z77 Express Chipset
The Intel® Z77 Express Chipset is a single-chipset design to support socket 1155 Intel® 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z77 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel® Z77 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
PCIe 3.0 Ready
PCI Express® 3.0 (PCIe 3.0) is the latest PCI Express bus standard with improved encoding schemes that provide twice the performance of current PCIe 2.0. Total bandwidth for a x16 link reaches a maximum of 32GB/s, double the 16GB/s of PCIe 2.0 (in x16 mode). As such, PCIe 3.0 provides users unprecedented data speeds, combined with the convenience and seamless transition offered by complete backward compatibility with PCIe 1.0 and PCIe 2.0 devices. PCIe 3.0 will become a must-have feature for users who wish to improve and optimize graphic performance, as well as have the latest technology available to them. * PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
Quad-GPU SLI and Quad-GPU CrossFireX Support! Flexible Multi-GPU Solutions, Your Weapon of Choice!
SABERTOOTH Z77 brings you the multi-GPU choice of either SLI™ or CrossFireX. The motherboard features the most powerful Intel® Z77 platform to optimize PCIe allocation in multiple GPU configurations. Expect a brand-new gaming style you've never experienced before!
LGA1155 Intel 3rd/2nd Generation processors ready
This motherboard supports the Intel 3rd/2nd generation processors in the LGA1155 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel 3rd/2nd generation processors are among the most powerful and energy efficient CPUs in the world. -
Intel H77 Express chipset
The Intel H77 Express chipset is a single-chipset design to support socket 1155 Intel 3rd/2nd generation processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, H77 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel H77 Express chipset can also enable iGPU function, letting users enjoy the latest Intel integrated graphic performance. -
Intel Smart Response technology
Intel Smart Response technology boosts overall system performance. It uses an installed fast SSD (min 18.6 GB available capacity required) as a cache for frequently accessed data. Key benefits include reduced load and wait times, and lower power consumption through the elimination of unnecessary hard drive spin. This technology combines SSD performance with hard drive capacity, operating up to 6X faster than a hard drive-only system. -
Intel Smart Connect technology
Your computer can receive web updates with fresh content for selected applications, even when the system is in sleep mode. This means less time waiting for applications to update and sync with the cloud, leading to a more efficient computing experience. -
Intel Rapid Start technology
Allows your computer to quickly resume from a low-power hibernate state in seconds. Saving your system memory to the designated SSD, it provides your computer a faster wake-up response time, while still keeping the energy use low. -
LucidLogix Virtu MVP
LucidLogix Virtu MVP featuring HyperFormance technology boosts your discrete graphics card up to 60% beyond its original performance through the test of 3DMark Vantage. Designed for Intel processor graphics and Windows 7 PCs, it perfectly combines the performance of discrete graphics cards with fast computing iGPU. Also with the newly designed Virtual Sync, users can enjoy a smoother gaming experience by eliminating tearing artifacts. LucidLogix Virtu MVP could also dynamically assign tasks to the best available graphics resource, based on power, performance and system load. This allows users to fully utilize 3x faster video conversion with Intel Quick Sync Video technology while retaining high-end 3D rendering and gaming performance, provided by both NVIDIA and AMD graphic cards. When the discrete graphics card is not required, power consumption goes automatically down to near zero, making the system more environmentally-friendly. For users searching for perfection, LucidLogix Virtu MVP provides great graphical performance and the best flexibility and efficiency.
- ASUS SABERTOOTH Z77 - motherboard - ATX - LGA1155 Socket - Z77
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z77 Express
- Processor Socket
- 1 x LGA1155 Socket
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600 (RAID), 2 x SATA-600, 4 x SATA-300 (RAID), 2 x eSATA-600
- USB / FireWire Ports
- 4 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1696 MB
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 5-year warranty
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z77 Express
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1866 MHz
- Speed
- PC3-12800, PC3-10600, PC3-14900
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1696 MB
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Intel 82579V
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 3 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin SATA, 2 x 7pin eSATA - 4 devices
- RAID Features
- Intel Smart Response Technology
- 1 x HDMI , 1 x DisplayPort , 1 x LAN (Gigabit Ethernet) , 4 x USB 2.0 , 4 x USB 3.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 6 x USB 2.0 , 1 x USB 3.0 - header , 1 x SPDIF out , 1 x audio
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
- Hardware Features
- Jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ESD Guards, TUF Engine!, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, Intel Turbo Boost Technology 2.0, TUF Thermal Armor, TUF Thermal Radar, Intel Clear Video HD Technology, Intel Smart Response Technology, USB 3.0 Boost, AMD Quad CrossFireX technology support, ASUS DIGI+ Power Control, ASUS Network iControl, ASUS USB Charger+, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, 8+4+2 Phase Power Design, Ultimate COOL!, Safe & Stable! Guardian Angel, TUF Dust Defender
- Included Accessories
- 2 x 35mm fans, accessory package
- Cables Included
- 4 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
- Plug and Play, ACPI 2.0a
- 30.5 cm
- 24.4 cm
- Limited warranty - 5 years
Asus Sabertooth Z77 S1155 Intel Z77 DDR3 ATX
