This board has been forged for ultimate reliability and force with its TUF series branding. A unique design and high quality components has ensured that the TUF series was born for pursuing unbeatable stability, all round compatibility and extreme durability.
Sabertooth X58 supports the latest Intel® Core™ i7 processors in an LGA1366 package with integrated memory controllers to support 3-channel (6 DIMMs) DDR3 memory. The Intel® X58 Express Chipset is one of the most powerful chipset designed to support the Intel® Core™ i7 Processors Intel® QuickPath Interconnect (QPI) supports with a system bus of up to 6.4 GT/s and a max bandwidth of up to 25.6 GB/s, providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. The Intel® Core™ i7 processor is one of the most powerful and energy efficient CPUs in the world. It also supports up to 36 PCI Express 2.0 lanes providing better graphics performance.
The motherboard supports DDR3 memory that features data transfer rates of 1866/1800/1600/1333/1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The triple-channel DDR3 architecture enlarges the bandwidth of system memory to boost system performance.
SABERTOOTH X58 brings users the multi-GPU choice of either SLI™ or CrossFireX. The motherboard features the most powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Expect a brand new gaming style, never experienced before!
Innovative ceramics effectively conducts heat away from the system. It replaces traditional anti-oxidant to effectively dissipate heat with a microscopic irregular surface and enlarged area. Better cooling leads to an overall improvement in system stability. Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature, caused by different climate conditions in different geographic regions and system loading. Built-in variety of useful profiles offers flexible controls of fan speed to achieve a quiet and cool environment. Exclusively for this motherboard, the switching power design is provided not only for the CPU, but also for other key components such as graphics card, PCI slots, and chipsets. E.S.P. dramatically improves system efficiency and reduces heat generation.
Users can generate a brutal performance even in the most challenging conditions with robust chokes, capacitors, and MOSFETs - certified through third-party, military-grade testing. TUF Chokes, also known as, "Alloy Choke", is made of a compound of various types of metal instead of standard iron. This enables the support of up to a massive 40A rated current, 25% higher than a conventional component. Furthermore, the single piece packaging also eliminates the emission of vibration noise, delivering superb characteristics as well as durability under extreme conditions. MemOK! ensures memory boot compatibility. This remarkable memory rescue tool requires a mere push of a button to patch memory issues. MemOK! determines failsafe settings and dramatically improves system boot success. Getting your system up and running in no time!
Experience ultra-fast data transfers at 4.8Gbps with USB 3.0. This has been built to provide simple and easy connections with next generation components and peripherals. USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components. Supporting next generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0 Gb/s data transfer rates. Additionally, get enhanced scalability and faster data retrieval and double the bandwidth of current bus systems.
ASUS Unique Selling Points
- CeraM!X Heatsink Coating Technology, Larger area for heat dissipation with the revolutionary ceramics-coating technology
- E.S.P. Efficient Switching Power Design, Optimal power efficiency for key components
- TUF Components Alloy Choke, Cap. & MOSFET, certified by military-standard testing, Certified for totally stable performance
- MemOK! determines failsafe settings and dramatically improves your system boot success with Memory.
Key specification
- ATX Form Factor
- LGA1366 socket for Intel® Core™ i7 Processors
- Intel® X58 /ICH10R Chipset
- 6 x DDR3, up to 24.0G
- 8-CH HD audio
- Gigabit LAN controller
- 12 x USB 2.0 Ports
- 2 x USB 3.0 ports (blue, at back panel)
- 2 x SATA 6Gb/s ports (grey)
- 2 x 1394a port(s)
In The Box
- User's manual
- SLI bridge
- 2 in 1 Q-connector
- 2 x SATA 6Gb/s cables
- 2 x SATA 3Gb/s cables
- ASUS Q-Shield
Triple-channel DDR3 1866/1800/1600/1333/1066 support
The motherboard supports DDR3 memory that features data transfer rates of 1866/1800/1600/1333/1066 MHz to meet the higher bandwidth requirements of the 3D graphics, multimedia, and Internet applications. The triple-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance. -
Quad-GPU SLI and Quad-GPU CrossFireX support
Sabertooth X58 brings you the multi-GPU choice of either SLI or CrossFireX. The motherboard features the powerful Intel X58 platform to optimize PCIe allocation in multiple GPU configurations. Expect a gaming style you've never experienced before! -
Ceramics effectively conducts heat away from the system. It replaces traditional anti-oxidant to dissipate heat better with its microscopic irregular surface and enlarged area. Better cooling leads to overall improvement in system stability. -
Active quiet and cool
Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature, which is caused by different climate conditions in different geographic regions and system loading. Built-in variety of useful profiles offer flexible controls of fan speed to achieve a quiet and cool environment. -
Exclusively for this motherboard, the switching power design is provided not only for the CPU, but also for other key components such as graphics card, PCI slots, and chipsets. E.S.P. dramatically improves system efficiency and reduces heat generation. -
Any memory is OK
MemOK! quickly ensures memory boot compatibility. This remarkable memory rescue tool requires a mere push of a button to patch memory issues. MemOK! determines failsafe settings and dramatically improves your system boot success. Get your system up and running in no time! -
10x faster date rates
Experience ultra-fast data transfers at 4.8Gbps with USB 3.0 - the connectivity standard. Built to connect easily with next generation components and peripherals, USB 3.0 transfers data 10x faster and is also backward compatible with USB 2.0 components. -
Experience the future of storage
Supporting Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems.
- ASUS SABERTOOTH X58 - motherboard - ATX - LGA1366 Socket - X58
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel X58 Express / Intel ICH10R
- Processor Socket
- 1 x LGA1366 Socket
- Max RAM Size
- 24 GB
- RAM Supported
- 6 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600, 6 x SATA-300 (RAID), 1 x SATA-300, 1 x powered eSATA-300
- USB / FireWire Ports
- 2 x USB 3.0 + 1 x FireWire + 6 x USB 2.0 + (1 x FireWire + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Product Type
- Motherboard - ATX
- Chipset Type
- Processor Socket
- LGA1366 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 24 GB
- Technology
- DDR3
- Bus Clock
- 1800 MHz, 1600 MHz, 1333 MHz, 1066 MHz
- Speed
- PC3-14400, PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Triple channel memory architecture
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8110SC
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 6 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 1 x PCIe x16 , 2 x PCIe x1 , 1 x PCI
- Storage Interfaces
- Intel ICH10R: SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9128: SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , JMicron JMB362: SATA-300 -connectors: 1 x 7pin SATA, 1 x 11pin eSATAp - 2 devices
- RAID Features
- Intel Matrix RAID Technology
- 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x FireWire - 6 pin FireWire , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 6 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 1 x FireWire , 6 x USB 2.0
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- Jack retasking, MemOK!, ASUS Q-Design, CeraM!X Heatsink Coating Technology, TUF Engine!, Q-DIMM, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, ASUS AI NET2, ASUS Noise Filter, audio jack detect technology, ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, NVIDIA Quad SLI Technology Support, Intel QuickPath Architecture, Intel Turbo Boost Technology, AMD Quad CrossFireX technology support
- Cables Included
- 1 x SLI bridge , 4 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS PC Probe, ASUS EZ Flash, ASUS Live Update, ASUS EZ-Backup
- Plug and Play, ACPI 2.0
- 30.5 cm
- 24.4 cm
- Limited warranty - 3 years
Asus Sabertooth X58 TUF LGA1366 DDR3 ATX (USB3, SATA 6Gb/s)
