Asus S775 Intel G41 System
Quicklinx: 6MW4WS00 Mfr#: P6-P5G41E
The compact size-10.9L contains all possibilities. It is convenient to move and saving more space for you. With many hidden mechanical designs and its high sleek piano-black, the simple and elegant product fits all surroundings at home. It's not just a computer; it is an artistic decoration.
Glossy surfaces and an eye-catching power button, which are inspired from the halo of lunar eclipse in the night. The lighting shows powerful indications when switched on; in contrast, all the rest of the form sits quietly. It is just like a poem or painting describing the silent dark sky with a full moon and a mirror-like lake reflecting the bright shadow.
The highly integration of mechanism and MB design creates the best placement and air flow. Also, P6-P5G41E has unique Q-Fan Technology detected the CPU loading and temperature automatically. Therefore P6-P5G41E provides the best thermal & acoustic solution to build the quiet working environment.
P6-P5G41E supports DirectX10 which equips 3-D graphics-rendering capabilities in games and high-end 3-D applications. Plus the HDMI connector and the theater-like HD 8 channel audio, a new experience of home entertainment is evolved for you.
P6-P5G41E supports DDR3 memory that features data transfer rates of 1333/1066/800 MHz to meet the higher bandwidth requirements of the latest operation system, 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture doubles the bandwidth of system memory to boost system performance.
DriveClone Pro 7 is an advanced and available recovery tool which stores user data, applications and the operating system in the host-protected area of the hard drive just in few seconds and recover it in few minutes. Users can easily recover system to any state without restore CDs. No need to worry about losing data due to virus attacks.
To green our earth, P6-P5G41E equips the power saving design - EPU. It not only saves your money but also supports more stable electric force. Moreover, P6-P5G41E follows the stern EUP rule to show the resolution of protecting the world.
P6-P5G41E features ASUS-exclusive utility AI Manager, which includes AI Disk for clearing your browsers' history, cookies, files and even your recycle bin. AI Security enables you to secure all your devices, while AI Boot allows you to prioritize your boot order. My Favorites helps you add all your frequently used applications, and you can even seek technical help from ASUS via Support. Information allows you to have a one-stop view of your system information.
Express Gate offers an optional Linux OS boot-up that allows you to enjoy instant access to commonly used functions like accessing the Internet, VoIP, and Web emailing without entering Windows.
  • Magic space & tasteful design
  • Deliver visual and tactile experience
  • Excellent thermal & acoustic solution
    The highly integration of mechanism and MB design creates the best placement and air flow. Also, P6-P5G41E has unique Q-Fan technology detected the CPU loading and temperature automatically. Therefore P6-P5G41E provides the best thermal & acoustic solution to build the quiet working environment.
  • Deliver graphics enhancement and compatibility for entertaining
    P6-P5G41E supports DirectX10 which equips 3-D graphics-rendering capabilities in games and high-end 3-D applications. Plus the HDMI connector and the theater-like HD 8 channel audio, an experience of home entertainment is evolved for you.
  • Dual-channel, DDR3 1333 MHz support
  • Exclusive EPU power saving design & EUP - compliant to Sustain a greener world
    To green our Earth, P6-P5G41E equips the power saving design - EPU. It not only saves your money but also supports more stable electric force. Moreover, P6-P5G41E follows the stern EUP rule to show the resolution of protecting the world.
ASUS P Series P6-P5G41E - tower no CPU - 0 GB - no HDD
PC barebone - tower
No CPU
Processor Socket
LGA775 Socket
RAM
0 GB (installed) / 8 GB (max) - DDR3 SDRAM
Storage Controller
SATA (SATA 3Gb/s)
Hard Drive
No HDD
Optical Storage
No optical drive
Card Reader
3 in 1
Graphics Controller
Intel GMA X4500
Audio Output
7.1 channel surround - integrated
1GbE
Software Included
Drivers & Utilities, ASUS MyLogo2, PC-Cillin Antivirus, ASUS Express Gate, ASUS DriveClone Pro 7, ASUS EZ Flash2
11.2 cm x 36.6 cm x 27.9 cm
PC barebone
Product Form Factor
Tower
Processor / Chipset
CPU
No CPU
Max CPU Qty
1
CPU Upgradability
Upgradable
CPU Socket
LGA775 Socket
Chipset Type
Intel G41 Express
Front Side Bus
1333 MHz
RAM
Installed Size
DDR3 SDRAM
DIMM 240-pin
Slots
2 (Total) / 2 (empty)
Hard Drive
No HDD
Storage Controller
1 x SATA - integrated
Controller Interface Type
SATA 3Gb/s
Optical Storage
No optical drive
Card Reader
3 in 1 card reader
Monitor
Monitor Type
None.
Graphics Controller
Integrated
Graphics Processor
Intel GMA X4500
Video Interfaces
VGA, HDMI
Audio Output
Integrated
Sound Output Mode
High Definition Audio
Integrated
Ethernet Controller
Realtek RTL8111C
Wake on LAN (WoL), PXE support
Bays
1 (total) / 1 (free) x external 5.25" x 1/2H , 1 (total) / 1 (free) x internal 3.5" x 1/3H
Slots
1 (total) / 1 (free) x CPU , 2 (total) / 2 (free) x DIMM 240-pin , 1 (total) / 1 (free) x PCIe x16 , 1 (total) / 1 (free) x PCIe x1
6 x USB 2.0 (2 front, 4 rear) , 1 x headphones (1 in front) , 2 x microphone (1 front, 1 rear) , 1 x SPDIF output , 1 x LAN (Gigabit Ethernet) , 1 x HDMI , 1 x VGA
Power supply
Power Provided
200 Watt
Operating System / Software
Software
11.2 cm
36.6 cm
27.9 cm
