Lights up your Wi-Fi everywhere!
The RP-N14 ensures full coverage and no more signal dead zones with internal MIMO antennas. Its strong repeater functionality expands wireless home networking to every corner. Even the hardest to reach spots get high speed internet coverage for notebooks, tablets, smartphones, game consoles, and smart TVs.
One-press setup and worry-free connectivity
RP-N14 installation doesn't require a CD or even mouse and keyboard. One press of the WPS button and setup is complete. Optimized performance is assured, so internet experiences are seamless and smooth. For detailed management, you can simply connect the RP-N14 to a PC via Ethernet cable and go to the configuration page directly, or quickly set it up from tablet or smartphone wirelessly, with no disc or app needed.
Wireless media playback -
Enjoy all your favorite music with wireless convenience using the RP-N14 and ASUS AiPlayer. Great compatibility with a complete range of multimedia formats means streaming is smooth and effortless, working every time to bring you plug n play enjoyment, to be shared with those that matter.
*Free download ASUS AiPlayer from App Store and Google Play now.
Signal indicator
Reactive LED lighting on the front of the RP-N14 offers at a glance signal strength indication from router to the RP-N14
Internet radio
Get your favorite stations via the internet with live streaming, or webcasting. Streams playable through the router's graphical user interface and dedicated app.
Hands-on control for music and lighting
Simply touch a sensor on the RP-N14 to start or stop music playback and turn the LED lighting on and off. All it takes is one touch, adding instant convenience to artistic beauty - plus you can personalize sensor settings via the user-friendly interface.
Stylish power lights up your home
The RP-N14 has an additional LED on the back, serving as a gentle nightlight for a very pleasing visual effect.
Flexible and space saving placement options
The RP-N14 uses a back power plug design to help you save space and give you more freedom when choosing device location. It can connect directly to wall sockets or power strips, promoting neater and less cluttered homes.
The RP-N14 ensures full coverage and no more signal dead zones with internal MIMO antennas. Its strong repeater functionality expands wireless home networking to every corner. Even the hardest to reach spots get high speed Internet coverage for notebooks, tablets, smartphones, game consoles, and smart TVs. -
Signal indicators
Reactive LED lighting on the front of the RP-N14 offers at a glance signal strength indication for the 2.4 GHz band. -
The 2.4 GHz band has very good signal strength
The 2.4 GHz signal is very weak. Move the RP-N14 closer to the router to increase signal strength -
Repeater and access point modes
RP-N14 has two convenient modes to make it even more flexible. As well as a repeater, it can also work as a wireless access point (AP). In AP mode it can be connected to any wired LAN - for example, a hotel's Internet connection - to create a personal Wi-Fi hotspot, allowing the Internet connection to be accessed from laptops, phones or other Wi-Fi devices. AP mode is also handy for adding wireless capability to a router with no built-in Wi-Fi. -
RP-N14 installation doesn't require a CD or even mouse and keyboard. One press of the WPS button and setup is complete. Optimized performance is assured, so Internet experiences are seamless and smooth. For detailed management, you can simply connect the RP-N14 to a PC via Ethernet cable and go to the configuration page directly, or quickly set it up from tablet or smartphone wirelessly, with no disc or app needed. -
Internet radio
Get your favorite stations via the internet with live streaming, or webcasting. Streams playable through the router's graphical user interface. -
Simply touch a sensor on the RP-N14 to start or stop music playback and turn the LED lighting on and off. All it takes is one touch, adding instant convenience to artistic beauty - plus you can personalize sensor settings via the user-friendly interface. -
- ASUS RP-N14 - Wi-Fi range extender - Wi-Fi
- Form Factor
- In-wall mountable
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- OS Required
- Linux, Apple MacOS X, Microsoft Windows 7, Microsoft Windows Vista, Windows 8
- 4.5 cm x 3.1 cm x 8.5 cm
- 4.5 cm
- 3.1 cm
- 8.5 cm
- Form Factor
- In-wall mountable
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Signal strength
- Repeating mode, Access Point operational mode, MIMO technology, Wi-Fi Protected Setup (WPS), reset button, Roaming Assist technology
Aerial
- Antenna
- Internal
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45 (WAN) , 1 x audio line-out - mini-jack
- OS Required
