After redefining ultra-slim gaming laptops with the original Zephyrus, ROG brings hardcore gaming to an even thinner design framed by super-narrow bezels. ROG Zephyrus S uses innovative engineering to cool its powerful processor and GPU with Max-Q design, so you can immerse yourself in its no-compromise display.
Ultraportable gaming
Clever design and expert craftsmanship are required to put high-end chips into the slimmest gaming laptop ever. Extremely thin, the metal chassis and CNC-milled unibody lid make ROG Zephyrus S portable enough for life on the go and tough enough to survive everyday abuse. In one fluid motion of hidden scissor-door hinges, it transforms from svelte sidekick to gaming powerhouse. -
Shrinking bezels without sacrificing speed
Super-narrow bezels draw you deeper into the action on the fast refresh rate display. The high refresh rate makes gameplay smoother and lowers input lag, while the short gray-to-gray response time produces sharper visuals with no blurring. With the full sRGB color gamut and wide viewing angles, ROG Zephyrus S blends speed and beauty without compromise. -
Potent performance rivals desktops
Don't be fooled by its lithe body; ROG Zephyrus S has ample power for AAA games, VR experiences, and serious creative work. -
Cool under pressure
The unique ROG Active Aerodynamic System (AAS) expands to help Zephyrus S sustain high GPU clocks with demanding games. Lifting the lid opens an intake that increases airflow compared to traditional designs. Anti-dust tunnels keep the four heatsinks clean to preserve cooling performance and system stability as the hours add up. -
Aura Sync beyond the gaming keyboard
The keyboard ensures precise input in the heat of battle, and it's built to last. You can customize the backlight colors and effects to suit your style, and another configurable RGB zone illuminates the AAS intake at the back. Aura Sync harmonizes lighting across compatible ROG mice, headsets, and other peripherals to give your setup a cohesive look. -
Amp up your audio
ROG Zephyrus S puts audio at the forefront with dual speakers aimed right at you. Smart amplifier tech keeps them within thermal and excursion limits, so you can pump up the volume without harming the cones. The resulting output is louder, with more bass and range that help you hear every sound, and you can plug in a headset for even more immersion. -
Extensive connectivity
ROG Zephyrus S has all the connectivity needed for gaming on the go. Type-C (USB-C) ports are available at USB 3.1 Gen 2 and Gen 1 speeds, while Type-A USB 3.1 Gen 2 and USB 2.0 ports are perfect for a gamepad and mouse. HDMI 2.0 at the back supports high refresh rate 4K UHD displays, so you can game and entertain on big-screen TVs.
- ASUS ROG Zephyrus S GX531GW-ES008R - 15.6" - Core i7 8750H - 16 GB RAM - 512 GB SSD
- Product Type
- Notebook
- Operating System
- Win 10 Pro
- Processor
- Intel Core i7 (8th Gen) 8750H / 2.2 GHz (4.1 GHz) / 9 MB Cache
- Memory
- 16 GB DDR4 (1 x 8 GB + 8 GB (soldered))
- Storage
- 512 GB SSD - NVMe
- Optical Drive
- No optical drive
- Display
- 15.6" LED backlight 1920 x 1080 / Full HD @ 144 Hz
- Graphics
- NVIDIA GeForce RTX 2070 / Intel UHD Graphics 630
- Video Memory
- 8 GB GDDR6 SDRAM
- VR Ready
- Input Device
- Mouse
- Keyboard Backlight
- Yes (RGB)
- Integrated Webcam
- Networking
- 802.11ac, Bluetooth 5.0
- Battery
- 4-cell
- Black
- 36 cm x 26.8 cm x 1.61 cm
- 2.1 kg
- SAR
- 0.02 W/kg (body), 0.02 W/kg (limb)
- Product Type
- Notebook
- Operating System
- Windows 10 Pro
Processor / Chipset
- CPU
- Max Turbo Speed
- 4.1 GHz
- Number of Cores
- 6-core
- Cache
- 9 MB
- 64-bit Computing
- Chipset
- Mobile Intel HM370
- Intel Turbo Boost Technology 2.0
- RAM
- 16 GB (1 x 8 GB + 8 GB (soldered))
- Max RAM Supported
- 24 GB
- Technology
- DDR4 SDRAM
- Speed
- 2666 MHz
- Form Factor
- SO-DIMM 260-pin
- Slots Qty
- 1
- Empty Slots
- 0
Storage
- Main Storage
- 512 GB SSD M.2 PCIe - NVM Express (NVMe)
Display
- 15.6"
- LCD Backlight Technology
- LED backlight
- Resolution
- 1920 x 1080 (Full HD)
- V-Sync Rate at Max Res.
- 144 Hz
- Widescreen
- Image Aspect Ratio
- 16:9
- Anti-glare, 72% NTSC colour gamut, 100% sRGB colour gamut, 178° horizontal and vertical viewing angle, 3 ms response rate, 75.35% Adobe RGB colour gamut
Audio & Video
- Multi-GPU Configuration
- 1 single GPU card / integrated GPU
- Graphics Processor
- Video Memory
- 8 GB GDDR6 SDRAM
- Video System Features
- NVIDIA Optimus, NVIDIA G-SYNC, Max-Q design
- VR Ready
- Camera
- Yes - 720p
- Sound
- Stereo speakers, array microphone
Input
- Mouse, keyboard, touchpad
- Yes (RGB)
- 4-zone illumination
Communications
- Wireless
- Technology
- 4-cell Lithium Ion
- Capacity
- 60 Wh
AC Adapter
- Input
- AC 120/230 V (50/60 Hz)
- Output
- 230 Watt, 19.5 V, 11.8 A
Connections & Expansion
- Headphone/microphone combo jack , HDMI , USB-C 3.1 Gen 1 , USB 3.1 Gen 2 , USB-C 3.1 Gen 2/DisplayPort , 2 x USB 2.0
- Black
- Theft/Intrusion Protection
- Security Slot Type
- Kensington security slot
- Included Accessories
- Power adapter
- SAR Value
- 2.1 kg
