Asus ROG Zephyrus R9-5900HS RTX3060 16GB 1TB 14" Win 10 Home
Quicklinx: GPXFWS00 Mfr#: GA401QM-K2196T
  • IEEE 802.11n
The ROG Zephyrus G14 makes powerful, ultraportable gaming accessible to everyone. This slim and stylish powerhouse rips through the demanding apps and games. Quad speakers pump out lush Dolby Atmos audio, while exclusive Two-Way AI Noise Cancelation makes voice chat crystal clear. Live life at Zephyrus speed with the ultimate blend of power and portability.
  • Precision machining
    The striking dot matrix design on the lid is made with a precision CNC milling process that creates 6,536 perfectly spaced perforations in an incredibly small surface area.
  • Power up
    The Zephyrus G14 changes the game for portability by packing unprecedented power into a 14-inch body. Its processor is tuned with lower power consumption and thermals that enable superior performance for ultra-slim laptops.
  • Live it up
    Gaming laptops typically struggle to stay alive without a massive power brick, but the Zephyrus G14's energy-efficient processor lets you finish up work, watch videos, and stay productive without the weight. USB Power Delivery gives you the flexibility to charge the battery with portable Type-C power packs and adapters, or quickly rejuvenate compatible smartphones and other devices. Say goodbye to fighting over sockets in crowded cafes, and live life untethered.
  • Turn it up
    Virtual 5.1.2-channel surround sound powered by Dolby Atmos technology puts you in the center of the action. Twin tweeters fire sound directly at you, while dual Smart Amp woofers bounce sound off the table. Switch between 6 preset modes that optimize settings based on the type of game and media, or make manual modifications that fit your preferences. Two-Way AI Noise Cancelation filters both input and output audio, making streams, chats, and recording clearer than ever.
  • Don't heat up
    Innovative solutions are needed to ensure reliable, sustained performance, so ROG's Intelligent Cooling philosophy mixes the right features and system settings to ensure the best experience no matter what you're doing. In the Zephyrus G14, self-cleaning cooling prevents dust build up from compromising long-term performance, while dual Arc Flow fans spin 84 blades each to generate impressive airflow within the slim frame.
ASUS ROG Zephyrus G14 GA401QM-K2196T - 14" - AMD Ryzen 9 - 5900HS - 16 GB RAM - 1 TB SSD
Notebook
Operating System
Windows 10 Home
AMD Ryzen 9 5900HS / 3 GHz, up to 4.6 GHz / 16 MB Cache
16 GB DDR4 (provided memory is soldered)
Storage
1 TB SSD - NVMe
Display
14" LED backlight 2560 x 1440 / WQHD @ 120 Hz
Graphics
NVIDIA GeForce RTX 3060 / AMD Radeon Graphics
Video Memory
6 GB GDDR6 SDRAM
Gaming
Keyboard Backlight
802.11a/b/g/n/ac/ax, Bluetooth 5.1
4-cell
Security
Fingerprint reader
Eclipse grey AniMe Matrix
32.4 cm x 22 cm x 1.99 cm
1.7 kg
Repairability Index
7.1 (out of 10)
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
4.6 GHz
Number of Cores
8-core
Cache
L3 - 16 MB
RAM
16 GB (provided memory is soldered)
Max RAM Supported
32 GB
DDR4 SDRAM
SO-DIMM 260-pin
Slots Qty
1
Empty Slots
1
Storage
Main Storage
1 TB SSD M.2 PCIe 3.0 - NVM Express (NVMe)
Display
14"
LCD Backlight Technology
LED backlight
Resolution
2560 x 1440 (WQHD)
V-Sync Rate at Max Res.
120 Hz
Widescreen
Image Aspect Ratio
16:9
Image Brightness
300 cd/m²
Colour Gamut
100% DCI-P3
Anti-glare, Adaptive-Sync technology, Pantone Validated, 170° horizontal and vertical viewing angle, IPS-level
Audio & Video
Multi-GPU Configuration
1 single GPU card / integrated GPU
Graphics Processor
Video Memory
6 GB GDDR6 SDRAM
Video System Features
NVIDIA Optimus, ROG Boost, Dynamic Boost
Gaming
Sound
Stereo speakers, two tweeters, array microphone
Dolby Atmos
Audio Features
Output: noise-cancellation technology, Smart Amp
Input
Keyboard, touchpad
Keyboard Backlight
Chiclet keyboard
Communications
Wireless
Dual stream (2x2)
4-cell Lithium Ion
76 Wh
AC Adapter
Input
AC 100-240 V (50/60 Hz)
Output
180 Watt, 20 V, 9 A
Connections & Expansion
Slots
1 x M.2 (PCI Express / SATA) (0 free)
Interfaces Details
Headphone/microphone combo jack , USB-C 3.2 Gen 2 (supports DisplayPort Alt Mode) (Power Delivery) , USB-C 3.2 Gen 2 , 2 x USB 3.2 Gen 1 , HDMI
Security
Fingerprint reader
System password
Theft/Intrusion Protection
Security Slot Type
Kensington security slot
Power adapter
1.7 kg
Sustainability Information
Repairability Index
7.1 (out of 10)
TCO Certified
