Asus ROG ZENITH EXTREME AMD X399 STR4 DDR4 PCIe3.0 M.2 U.2 eATX
Quicklinx: D326WS00 Mfr#: ROG ZENITH EXTREME
  • IEEE 802.11n
Customize your own favorite LED effects with Aura, the intuitive lighting-control software, to cast a stunning multi-color glow across your build via the ROG Zenith Extreme's brilliant built-in RGB LEDs or attached RGB strips via the two onboard 4-pin headers - all lights will perform in perfect synchronization. Fire up Aura and enjoy the creative freedom of nine different lighting schemes!
ROG Zenith Extreme includes a dedicated addressable RGB header that connects to compatible lighting strips, fans, coolers, and compatible PC cases - all to create a new world of illumination possibilities. Aura software offers an array of effects for addressable gear, and the Aura SDK takes things to the next level - allowing developers to control each LED individually, unleashing infinite lighting possibilities!
ROG Zenith Extreme comes equipped with all-new LiveDash - a built-in OLED panel that displays useful information and customizable graphics. During the power-on, self-test (POST) phase, LiveDash shows key progress stats, in simple language and via traditional POST codes. Then, during normal operation, the vibrant panel shows a choice of CPU frequency, device temperatures, fan speeds or information from the Water Cooling Zone, You're also able to customize the default LiveDash GIF, so it'll display your own image or animation.
  • Aura lighting control
  • RGB lighting perfected
  • LiveDash OLED
  • DIMM.2 with fan holder
    ROG Zenith Extreme's DIMM.2 module is a bundled expansion card that allows two M.2 drives to be connected via a DDR4 interface. You can then add a memory fan to direct cool air to the M.2 drives to prevent throttling, ensuring maximum performance.
  • Perfected cooling for unleashing performance
    ROG Zenith Extreme is equipped with an M.2 heatsink integrated into the PCH heatsink. With a huge cooling surface, the heatsink perfectly chills an inserted M.2 SSD - for maximum performance and reliability. Featuring a stylish angular design replete with an awesome glowing ROG eye logo, the heatsink adds a beautiful touch to the build, while the T-sensor allows you to connect a thermal probe and monitor M.2 drive temps in real-time.
  • ROG Areion 10G card
    ROG Zenith Extreme comes with ROG Areion, the high-performance expansion card that plugs you into the new era of 10 Gbps networking! Made especially for the demanding requirements of power users, content creators, and others who push the envelope, Areion is named after the mythological horse with legendary speed. The large heatsink keeps the card cool while transferring massive files like 4K videos, and support for intermediate 2.5G and 5G connectivity lets you step up to faster networks for maximum flexibility. Choose the bandwidth that meets your needs and enjoy ultra-low latency at any speed.
  • Flexible cooling and control
    The ASUS Fan Extension Card makes it easy to add three additional fans and a complimentary array of thermal probes to your setup. And each header can be comprehensively controlled fan via the UEFI BIOS or the Fan Xpert 4 software. It's ideal for high-performance air or water-cooled PCs - providing maximum cooling for marathon gaming sessions.
  • PRE-mounted I/O shield
    ROG Zenith Extreme's, and the fact that it's pre-fitted makes it even easier to install the motherboard into a chassis. It also has a sleek new design that makes it look as good as it performs.
  • Dual backplates
    ROG Zenith Extreme is ingeniously engineered with two distinct backplates, providing both form and function. The small, strong backplate prevents the motherboard from bending and bowing, ensuring that the voltage-regulator module's MOSFETs stay in direct contact for uninterrupted cooling and stable temperatures. The second, larger backplate is all about aesthetics: a style statement that's as bold as ROG Zenith Extreme is powerful.
ASUS ROG ZENITH EXTREME - motherboard - extended ATX - Socket TR4 - AMD X399
Motherboard - extended ATX
Chipset Type
AMD X399
Processor Socket
1 x Socket TR4
Compatible Processors
Ryzen ThreadRipper
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 3 x M.2, 1 x U.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 8 x USB 3.1 Gen 1 + (1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, 10 Gigabit Ethernet, Gigabit Ethernet, 802.11a/b/g/n/ac, WiGig
Chipset Type
AMD X399
Processor Socket
Socket TR4
Max Processors Qty
1
Ryzen ThreadRipper
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2666 MHz, 2800 MHz (O.C.), 3200 MHz (O.C.), 3600 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC, ECC
Registered or Buffered
Unbuffered
Quad channel memory architecture
Audio
Audio Codec
SupremeFX (S1220)
High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (x16, x16/x16, x16/x8/x16, x16/x8/x16/x8 modes) , 1 x PCIe 2.0 x1 , 1 x PCIe 2.0 x4
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 , SATA-600 / PCIe 3.0 -connectors: 3 x M.2 , PCIe 3.0 -connectors: 1 x U.2
1 x LAN (Gigabit Ethernet) , 8 x USB 3.1 Gen 1 , 1 x audio line-in - mini-jack , 1 x audio line-out - mini-jack , 1 x microphone - mini-jack , 1 x TOSLINK , 1 x USB-C Gen2 , 1 x USB 3.1 Gen 2 , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x audio line-out (rear) - mini-jack
Internal Interfaces
2 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x audio - header , 1 x USB 3.1 Gen 2 - header
Power Connectors
24-pin main power connector, 2 x 8-pin ATX12V connectors
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS O.C. Profile, USB BIOS Flashback, UEFI BIOS, ASUS EZ Flash 3, SMBIOS 3.0 support, ACPI 6.1 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-LED, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Extreme Tweaker, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, NVIDIA 4-way SLI Technology Support, ASUS ROG Extreme OC, AMD 4-way CrossFireX technology support, DirectKey, Preboot eXecution Environment (PXE), Clear CMOS Button, Dual Intelligent Processors 5, LANGuard, KeyBot II, ROG SSD Secure Erase, ASUS Gamer's Guardian, AURA RGB Lighting Control, ASUS Fan Xpert 4, ASUS SafeSlot, Sonic Radar III, Sonic Studio III, ASUS LiveDash
ROG cable lables, ASUS 2T2R Wi-Fi moving aerials, fan extension card, ROG fan stickers, 3 x M.2 screws, ROG coasters, RGB (RGBW) LED strip extension cable, DIMM.2 extension card, ASUS WiGig 802.11ad moving aerial, 3 thermistor cables, ROG VGA holder, ROG DIMM.2 Fan Stand Pack, ROG AREION 10G
3 x Serial ATA cable , 1 x SLI bridge
Software Included
Drivers & Utilities, ROG CPU-Z, ASUS AI Suite III, ASUS Turbo App, Overwolf, ASUS EZ Flash 3, ROG GameFirst IV, ASUS ROG RAMCache II, ROG CloneDrive
30.5 cm
27.7 cm
