Strix Raid Pro is a premium sound card set built with audiophile-grade components to satisfy gamers who demand ultimate audio performance. Strix Raid Pro features rich, immersive, and clear sound with an incredible signal-to-noise ratio (SNR), and a headphone amplifier for deep, tight bass. The simple yet powerful Sonic Studio sound utility and control box provides complete sound card control and allows instant in-game audio adjustments.
Gamer-friendly design
Raid Mode can be turned on right in the heat of gaming action with just one click on the audio control box to provide the exact audio adjustment you want. With this powerful combination of Raid Mode and the audio control box, gamers no longer need to pause the game and open sound software to adjust their audio, ensuring they don't miss a single moment of gaming action. -
Gain the gaming edge with Sonic Radar Pro
Precise audio positioning gives gamers a distinct edge over enemies. That's why Strix Soar includes Sonic Radar Pro, the technology that visualizes and enhances in-game sounds, giving you a vital edge in first-person shooters. Fire up your favorite game and Sonic Radar Pro displays a radar HUD (heads-up display) that pinpoints in-game actions relative to your position, so you'll know exactly where you are on the battlefield and what's happening around you. -
High signal-to-noise ratio (SNR) clarity
High-fidelity grade DAC delivers unrivaled, jitter-free sound and an exceptional signal-to-noise ratio (SNR) for greater clarity on-board audio. -
Hyper Grounding technology
Noise-blocking multi-layer PCB is developed with proficiency. -
Unleash your gaming instincts
Strix means keen hearing and sharp eyesight. Strix means feeling your environment so that you detect and react to any slight movement. Strix means survival on the very edge of instinct.
- ASUS STRIX RAID PRO - sound card
- Sound card
- Enclosure Type
- Internal
- Interface Type
- PCI Express
- 2.2 cm x 19 cm x 13 cm
- 480 g
- Signal Processor
- CM6632AX
- Sound Output Mode
- 7.1 channel surround
- DAC Resolution
- 24-bit
- Sample Rate
- 44.1 kHz (min) - 192 kHz (max)
- Signal-To-Noise Ratio
- 116 dB
- System Requirements
- Microsoft Windows 7 (32/64 bits) SP1, Windows 8 (32/64 bits), Windows 8.1 (32/64 bits)
- Sound card
- Form Factor
- Internal
- Interface Type
- PCI Express
- 2.2 cm
- 19 cm
- 13 cm
- 480 g
Processor / Memory
- Signal Processor
- CM6632AX
Audio Output
- Sound Output Mode
- DAC Resolution
- 24-bit
- Sample Rate
- 116 dB
- Frequency Response
- 10 - 48000 Hz
- Headphone Amplifier, Hyper Grounding Technology, Sonic Radar Pro, Raid Mode
- ASIO 2.0
- Audio Modes
- Record: 24-bit 192 kHz , Playback: 24-bit 192 kHz
- 1 x headphones - mini-phone 3.5 mm , 1 x speakers (front surround) - mini-phone 3.5 mm , 1 x speakers (center/subwoofer) - mini-phone 3.5 mm , 1 x speakers (side)/SPDIF output - mini-phone 3.5 mm , 1 x speakers (rear) - mini-phone 3.5 mm , 1 x audio line-in/microphone - mini-phone 3.5 mm
- Included Accessories
- Control box
- Cables Included
- 1 x S/PDIF optical adapter
- Software
- Driver, Sonic Studio
- OS Required
