Asus ROG Swift PG258Q 24.5 1920x1080 Gaming Monitor 1ms DP HDMI
Quicklinx: CXNTWS00 Mfr#: PG258Q
ROG Swift PG258Q is all about speed - making it the perfect monitor for eSports and fast-paced action games. This Full HD monitor is incredibly fast, with a 240 Hz native refresh rate, 1 ms response time and NVIDIA G-SYNC technology for silky-smooth gameplay and ultra-realistic visuals. On top of that, Swift PG258Q has distinct ROG-inspired design elements that let everyone know that this is no ordinary gaming monitor.
  • Incredibly fast refresh rate
    ROG Swift PG258Q's astonishing 240 Hz native refresh rate makes it twice as fast as conventional 120 Hz monitors. You'll experience amazingly fluid gaming visuals, giving you the upper hand in first-person shooters, racing, real-time strategy and sports titles. There will be no break in the action!
  • NVIDIA G-SYNC technology with ultra low motion blur
    Coupling ROG Swift PG258Q's 240Hz refresh rate with NVIDIA G-SYNC technology results in the smooth, fast, breathtaking gaming. G-SYNC synchronizes Swift PG258Q's refresh rate to the GeForce GTX graphics card in your PC or laptop to eliminate screen tearing and to minimize display stutter. There's also the Ultra Low Motion Blur (ULMB) technology to make objects in motion look sharper, so gameplay is more fluid and responsive.
  • 1 ms rapid response time
    ROG Swift PG258Q features a 1ms gray-to-gray response time to completely eliminate smearing and motion blur. It's especially useful in fast - paced games - so you can take corners like a pro race car driver, or make that impossible headshot.
  • Present gaming aesthetic
    ROG Swift PG258Q has a futuristic, gaming-inspired design featuring strong and bold lines, as well as built-in lighting effects on its stand to add ambience to your gaming set up.
  • GamePlus technology
    The GamePlus hotkey provides in-game enhancements like a crosshair overlay, an onscreen timer, a frames per second counter, and a display alignment function.
  • Seamless multi-display setups
    Designed for those who want the ultimate battlestation, the PG258Q features frameless design, nearly seamless for multi-display setups, for an even greater degree of immersion.
ASUS ROG SWIFT PG258Q - LED monitor - Full HD (1080p) - 24.5"
LED-backlit LCD monitor - 24.5"
Energy Class
Class B
Energy Consumption per Year
40 kWh
Power Consumption (On mode)
27 W
Adaptive-Sync Technology
NVIDIA G-SYNC, NVIDIA G-SYNC Compatible
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 (DisplayPort: 240 Hz, HDMI: 60 Hz)
Pixel Pitch
0.2832 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
Response Time
1 ms (grey-to-grey)
Gaming
Colour Support
16.7 million colours
Input Connectors
HDMI, DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
Voltage
Dark grey, plasma cooper
56.41 cm x 25.37 cm x 38.37 cm
5.6 kg
UL, TUV, VCCI, cUL, WHQL, CB, CCC, FCC, RoHS, KCC, WEEE, PSE Mark, J-MOSS, E-Standby, ERP, RCM, CEL level 1, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification, DisplayPort 1.2
Display Type
Energy Class
Class B
40 kWh
Diagonal Size
24.5"
Built-in Devices
USB 3.0 hub
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2832 mm
Brightness
400 cd/m²
Contrast Ratio
1000:1
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
30 - 240 Hz
Horizontal Refresh Rate
67 - 255 kHz
Gaming
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, frameless, Trace Free Technology, nVidia 3D Vision 2 Ready, NVIDIA 3D LightBoost technology, 5-way Navigation Key, integrated cable management, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, NVIDIA Ultra Low Motion Blur Technology, ASUS Smart Air Vent Design, ASUS GameVisual Technology, Colour Temperature Selection
56.41 cm x 25.37 cm x 38.37 cm - with stand
5.6 kg
DisplayPort , 2 x USB 3.0 downstream (Type A) , HDMI , Headphones , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
100
Rotation Angle
90
Height Adjustment
120 mm
VESA Mounting Interface
100 x 100 mm
1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
Input Voltage
27 W
Power Consumption (Typical)
65 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.5 watt
On / Off Switch
No
Dimensions & Weight Details
With stand - width: 56.41 cm - depth: 25.37 cm - height: 38.37 cm - weight: 5.6 kg , Without stand - width: 56.16 cm - depth: 7.25 cm - height: 33.06 cm - weight: 3.14 kg
Shipping Width
66.14 cm
Shipping Depth
23.9 cm
Shipping Height
44.3 cm
Shipping Weight
7.9 kg
