Asus ROG Swift OLED PG48UQ 47.5" 4K Gaming Monitor
Quicklinx: HTQRWS00 Mfr#: PG48UQ
Diagonal Size: 47.5in
Max Resolution: 3840 x 2160
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£1,356.43 ex VAT
£1,627.71 inc VAT
The ROG Swift OLED PG48UQ is a 47.5-inch 4K OLED gaming monitor that features an anti-glare micro-texture coating to reduce reflections to ensure you see more accurate onscreen colors. Its superfast 138 Hz (overclocked) refresh rate and blazing 0.1 ms response time delivers incredibly immersive gaming on a larger scale. Plus 98% DCI-P3 gamut, true 10-bit color and Delta E < 2 ensure true-to-life colors and the darkest-possible black hues.
  • Detailed visuals and clearly-defined text
    ROG Swift OLED gaming monitors feature the OLED panels designed for greater efficiency and brightness. The sub-pixel layout provides extremely detailed visuals and clearly-defined text to upgrade the viewing experience.
  • Ultra-realistic colors
    The PG48UQ gaming monitor features true 10-bit color depth and a cinema-grade 98% DCI-P3 gamut to deliver unparalleled realism. Each monitor is pre-calibrated to Delta E < 2 to ensure the very best color reproduction on its brilliant OLED panel.
  • Deepest blacks and high perceptual brightness
    The OLED technology in the PG48UQ produces the deepest blacks and provides vivid colors at any brightness level. In-game details are extremely crisp and can be picked out in even the darkest scenes.
  • Blazingly fast response time for smooth visuals
    With an ultra-rapid 0.1 ms response time, the PG48UQ smoothly displays fast-paced action scenes and ensures low-latency gameplay. Viewers also enjoy subtle benefits such as blur-free text scrolling.
  • Intelligent cooling design for 8% lower temperatures
    The custom heatsink found in the PG48UQ offers more surface area for heat exchange to provide more efficient cooling performance, even in long gaming stints. The lower temperature enables better OLED performance with lower likelihood of image sticking. This robust fanless system operates silently to minimize distractions.
  • Less glare, fewer distractions
    A special matte micro-texture coating on the surface of the display significantly reduces glare. This allows the PG48UQ to display more accurate colors free of distracting screen glare.
  • Certified NVIDIA G-Sync compatible
    The PG48UQ delivers a seamless, tear-free gaming experience by enabling variable refresh rate technology as a default on NVIDIA GeForce graphics cards.
  • Rich connectivity
    The PG48UQ has an array of connectivity options that cater to any gaming or streaming setup. It includes HDMI, as well as DisplayPort 1.4 (DSC) at the rear to connect to various devices. Two USB ports and a tripod socket on top of the monitor makes it easy to mount a camera. Lastly, there's even a headphone jack at the bottom of the display.
  • Uniform brightness
    When activated, the ROG-exclusive uniform brightness function setting within the OSD menu decreases peak brightness to keep levels consistent for better viewing, even when changing the size of bright white windows. It also makes marathon gaming sessions much more comfortable on the eyes.
  • Aspect control
    For gamers that prefer playing on smaller monitors, the PG48UQ supports a range of aspect ratios to cast a 24", 27", or 34" image that can be shifted vertically to aid the viewing experience. See it all, and set the pace with the 0.1 ms response time of OLED.
ASUS ROG Swift OLED PG48UQ - LED monitor - 4K - 47.5" - HDR
LED-backlit LCD monitor - 47.5"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1223904
Energy Class
Class F
Adaptive-Sync Technology
NVIDIA G-SYNC Compatible
USB 3.2 Gen 1 hub, woofer
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 138 Hz
Pixel Pitch
0.27405 mm
Brightness
450 cd/m²
Contrast Ratio
135000:1 / 1500000:1 (dynamic)
HDR Capable
HDR10
Gaming
Colour Support
1.074 billion colours (10-bit)
Colour Gamut
133% sRGB, 98% DCI-P3
Input Connectors
4xHDMI, DisplayPort
Display Position Adjustments
Tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
106.8 cm x 26.6 cm x 68.6 cm
16.2 kg
TUV Hardware Low Blue Light Certification
Display Type
LED-backlit LCD monitor / OLED
Energy Class
Class F
Energy Class (HDR)
Class G
Diagonal Size
47.5"
Built-in Devices
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.27405 mm
Brightness
450 cd/m²
Contrast Ratio
HDR Format
HDR10
Colour Support
Colour Gamut
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
HDCP, Trace Free Technology, ASUS GamePlus, Low Blue Light Mode, Flicker Free technology, ASUS GameVisual Technology, Delta E<2 calibration, Shadow Boost technology, Display Stream Compression, tripod socket
106.8 cm x 26.6 cm x 68.6 cm - with stand
16.2 kg
Audio
Speakers - stereo
Output Power / Channel
10 watt
DisplayPort , 4 x HDMI , Headphones
Mechanical
Tilt
VESA Mounting Interface
300 x 300 mm
ROG pouch
1 x DisplayPort cable , 1 x USB cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
59 kWh/1000h
Power Consumption HDR (On mode)
66 kWh/1000h
Power Consumption (Typical)
300 watt
Power Consumption Stand by
0.5 watt
Power Consumption (Off Mode)
0.3 watt
Dimensions & Weight Details
Without stand - width: 106.8 cm - depth: 4 cm - height: 61.2 cm
Shipping Width
123 cm
Shipping Depth
18 cm
Shipping Height
88 cm
Shipping Weight
22.7 kg
Interfaces: HDMI
Brand: Asus
Price Range Ex VAT: £1000 - £1500
