Asus ROG Swift OLED PG42UQ 41.5-Inch 4K Gaming Monitor
Quicklinx: HTQQWS00 Mfr#: PG42UQ
Diagonal Size: 42in
Max Resolution: 3840 x 2160
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI
£1,071.66 ex VAT
£1,285.99 inc VAT
The ROG Swift OLED PG42UQ is a 41.5-inch 4K OLED gaming monitor that features an anti-glare micro-texture coating to reduce reflections to ensure you see more accurate onscreen colors. Its superfast 138 Hz (overclocked) refresh rate and blazing 0.1 ms response time delivers incredibly immersive gaming on a larger scale. Plus 98% DCI-P3 gamut, true 10-bit color and Delta E < 2 ensure true-to-life colors and the darkest-possible black hues.
  • Detailed visuals and clearly-defined text
    ROG Swift OLED gaming monitors feature the OLED panels designed for greater efficiency and brightness. The sub-pixel layout provides extremely detailed visuals and clearly-defined text to upgrade the viewing experience.
  • Ultra-realistic colors
    The PG42UQ gaming monitor features true 10-bit color depth and a cinema-grade 98% DCI-P3 gamut to deliver unparalleled realism. Each monitor is pre-calibrated to Delta E < 2 to ensure the very best color reproduction on its brilliant OLED panel.
  • Intelligent cooling design for 8% lower temperatures
    The custom heatsinks found in the PG42UQ offers more surface area for heat exchange to provide more efficient cooling performance, even in long gaming stints. The lower temperature enables better OLED performance with lower likelihood of image sticking. This robust fanless system operates silently to minimize distractions.
  • Anti-glare micro-texture coating less glare, fewer distractions
    A special matte Micro-texture coating on the surface of the display significantly reduces glare. This allows the PG42UQ to display more accurate colors free of distracting screen glare.
  • Certified NVIDIA G-Sync compatible
    The PG42UQ delivers a seamless, tear-free gaming experience by enabling variable refresh rate technology as a default on NVIDIA GeForce graphics cards.
  • Frameless and super-slim design
    The frameless display allows for more immersive viewing and the super-slim profile helps save desktop space.
  • 5-way navigation joystick
    Easily access the OSD menu via a 5-way navigation joystick under the screen.
  • Remote control
    Adjust settings without having to reach up at the display.
  • Three stereo speakers
    Two sound by Harman/Kardon 10-watt front speakers and one 15-watt woofer deliver incredible audio fidelity.
  • Rich connectivity
    The PG42UQ has an array of connectivity options that cater to any gaming or streaming setup. It includes HDMI, as well as DisplayPort 1.4 (DSC) at the rear to connect to various devices. One USB port and a tripod socket on top of the monitor makes it easy to mount a camera. Lastly, there's even a headphone jack at the bottom of the display.
  • Uniform brightness
    When activated, the ROG-exclusive uniform brightness function setting within the OSD menu decreases peak brightness to keep levels consistent for better viewing, even when changing the size of bright white windows. It also makes marathon gaming sessions much more comfortable on the eyes.
ASUS ROG Swift OLED PG42UQ - OLED monitor - 4K - 42" - HDR
OLED monitor - 42"
Energy Label QR Code URL
Https://eprel.ec.europa.eu/qr/1276474
Energy Class
Class G
USB 3.2 Gen 2 hub
Aspect Ratio
16:9
Native Resolution
4K 3840 x 2160 at 138 Hz
Pixel Pitch
0.2395 mm
Brightness
450 cd/m²
Contrast Ratio
135000:1 / 1500000:1 (dynamic)
HDR Capable
HDR10
Gaming
Colour Support
1.074 billion colours (10-bit)
Colour Gamut
133% sRGB, 98% DCI-P3
Input Connectors
4xHDMI, DisplayPort
Display Position Adjustments
Tilt
Voltage
AC 100-240 V (50/60 Hz)
93.208 cm x 25.54 cm x 61.13 cm
14.77 kg
TUV Rheinland Flicker Free Certification, TUV Rheinland Low Blue Light (Hardware Solution)
3-year warranty
Display Type
OLED monitor / OLED
Energy Class
Class G
Energy Class (HDR)
Class G
Diagonal Size
42"
Built-in Devices
USB 3.2 Gen 2 hub
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.2395 mm
Brightness
450 cd/m²
Contrast Ratio
HDR Format
HDR10
Colour Support
Colour Gamut
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
HDCP, Trace Free Technology, Flicker Free technology, NVIDIA G-SYNC compatible, ASUS GameVisual Technology, Ultra-Low Blue Light Technology, Delta E<2 calibration, Shadow Boost technology, GamePlus, tripod socket
93.208 cm x 25.54 cm x 61.13 cm - with stand
14.77 kg
Audio
Speakers - stereo
Output Power / Channel
10 Watt
DisplayPort 1.4 , USB 3.0 , 4 x HDMI , Headphones , SPDIF output
Mechanical
Tilt
Tilt Angle
-5/+5
VESA Mounting Interface
300 x 300 mm
Remote control, ROG pouch
1 x DisplayPort cable , USB cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
Input Voltage
53 kWh/1000h
Power Consumption HDR (On mode)
70 kWh/1000h
Power Consumption (Typical)
220 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 93.208 cm - depth: 37.38 cm - height: 55.196 cm - weight: 13.6 kg
Shipping Width
107 cm
Shipping Depth
18.8 cm
Shipping Height
87 cm
Shipping Weight
20.07 kg
3-year warranty
Diagonal Size: 42in
Interfaces: HDMI
Brand: Asus
Price Range Ex VAT: £1000 - £1500
