Asus ROG Swift OLED PG34WCDM Curved 34" Gaming Monitor
Quicklinx: HTQMWS00 Mfr#: PG34WCDM
£1,230.41 ex VAT
£1,476.49 inc VAT
TRANSCENDENCE
Push the limits of gaming with ROG Swift OLED PG34WCDM ultrawide curved gaming monitor. It features a 34-inch 3rd generation ROG OLED technology panel that offers 30% brighter imagery compared to its predecessor with 100% window in HDR, color-fringing reduction, and ASUS Extreme Low Motion Blur (ELMB) technology. The Swift OLED PG34WCDM features AMD FreeSync™ Premium Pro technology and NVIDIA® G-SYNC™ compatibility, ensuring super-smooth, tear-free visuals with low latency combined with a stunning 3440 x 1440 resolution, 240 Hz refresh rate and typo 0.03 ms gray-to-gray (GTG) response time ensure incredibly immersive virtual worlds without motion blur or screen tearing. Plus, an advanced custom heatsink design reduces the risk of burn-in to improve performance and longevity of the OLED panel.
A STUNNING DISPLAY
Experience the thrill of smooth and responsive gaming visuals on the ROG Swift OLED PG34WCDM’s 34-inch ultrawide 800R curved panel. The panel curvature mimics the shape of the human eye for unparalleled viewing experiences, and a blazing-fast 240 Hz refresh rate ensures that fast-paced onscreen action remains fluid and blur-free.
ASUS DISPLAYWIDGET CENTER
Intuitive ASUS DisplayWidget Center software lets you easily change monitor settings and OLED-related functions with your mouse, without needing to access the OSD menu.
DYNAMIC SHADOW BOOST
ASUS Dynamic Shadow Boost uses ROG Gaming AI technology to automatically enhance dark areas of the screen, making it easier to spot enemies hiding in dim corners of the map.
ERGONOMIC STAND
A specially designed hollowed-out stand offers tilt, swivel, and height adjustments for ideal viewing positions. The display is also VESA wall-mount-compatible.
ASUS ROG Swift PG34WCDM - OLED monitor - curved - 34" - HDR
OLED monitor - 34"
Energy Class
Class F
KVM Switch
USB
Curved Screen
Adaptive-Sync Technology
VESA Adaptive-Sync, AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible
USB 3.2 Gen 1 hub
Aspect Ratio
21:9
Native Resolution
3440 x 1440 at 240 Hz
Pixel Pitch
0.231 mm
Brightness
450 cd/m²
Contrast Ratio
1500000:1
HDR Capable
HDR10
Response Time
0.03 ms (grey-to-grey)
Gaming
Colour Support
1.0737 billion colours (10-bit)
Colour Gamut
99% DCI-P3, 135% sRGB
Input Connectors
2xHDMI, DisplayPort, USB-C
Display Position Adjustments
Height, swivel, tilt
Screen Coating
Anti-glare
Voltage
AC 100-240 V (50/60 Hz)
Dark grey
Dimensions (WxDxH) - with stand (highest position)
78.6 cm x 29.3 cm x 55.1 cm
8.4 kg
TUV Rheinland Flicker Free Certification, HDCP 2.2, TUV Rheinland Low Blue Light (Hardware Solution), FSC Mix
Display Type
OLED monitor / OLED
Energy Class
Class F
Energy Class (HDR)
Class F
Diagonal Size
34"
Viewable Size
33.94"
Curved Screen
Yes (800R)
Built-in Devices
USB 3.2 Gen 1 hub
Aspect Ratio
21:9
Native Resolution
Pixel Pitch
0.231 mm
Brightness
450 cd/m²
Contrast Ratio
1500000:1
HDR Format
HDR10
Colour Support
Colour Gamut
Response Time
Vertical Refresh Rate
40 - 240 Hz
Horizontal Refresh Rate
30 - 390 kHz
Gaming
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Picture in picture, picture by picture, HDCP, Trace Free Technology, Flicker Free technology, proximity sensor, ASUS GameVisual Technology, colour adjustment mode, Colour Temperature Selection, GameFast Input Technology, ASUS Extreme Low Motion Blur technology, Low Blue Light technology, Shadow Boost technology, ASUS Aura Sync technology, GamePlus, Display Widget, tripod socket, Delta E=2 colour accuracy, Variable refresh rate (VRR), custom heatsink
Dark grey
78.6 cm x 29.3 cm x 55.1 cm - with stand (highest position)
8.4 kg
KVM
Keyboard / Mouse Interface
USB
DisplayPort 1.4 (DSC (Display Stream Compression)) , 2 x HDMI , USB-C (DisplayPort Alt Mode, data, power up to 90W) , 2 x USB 3.2 Gen 1 downstream , USB 2.0 downstream , SPDIF output , Headphone jack
Mechanical
Tilt Angle
-5/+20
Swivel Angle
30
Height Adjustment
110 mm
VESA Mounting Interface
100 x 100 mm
Security Slot Type
Kensington security slot
Input Voltage
30 kWh/1000h
Power Consumption HDR (On mode)
31 kWh/1000h
Power Consumption (Typical)
31 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption (Off Mode)
0.3 Watt
Dimensions & Weight Details
Without stand - width: 78.6 cm - depth: 27.5 cm - height: 55.1 cm - weight: 5.6 kg , With stand (highest position) - width: 78.6 cm - depth: 29.3 cm - height: 55.1 cm - weight: 8.4 kg , With stand (lowest position) - width: 78.6 cm - depth: 29.3 cm - height: 44.1 cm - weight: 8.4 kg
Shipping Width
89 cm
Shipping Depth
46.5 cm
Shipping Height
29.1 cm
Shipping Weight
13.5 kg
Brand: Asus
Price Range Ex VAT: £1000 - £1500
