TRANSCENDENCE
Push the limits of gaming with ROG Swift OLED PG34WCDM ultrawide curved gaming monitor. It features a 34-inch 3rd generation ROG OLED technology panel that offers 30% brighter imagery compared to its predecessor with 100% window in HDR, color-fringing reduction, and ASUS Extreme Low Motion Blur (ELMB) technology. The Swift OLED PG34WCDM features AMD FreeSync™ Premium Pro technology and NVIDIA® G-SYNC™ compatibility, ensuring super-smooth, tear-free visuals with low latency combined with a stunning 3440 x 1440 resolution, 240 Hz refresh rate and typo 0.03 ms gray-to-gray (GTG) response time ensure incredibly immersive virtual worlds without motion blur or screen tearing. Plus, an advanced custom heatsink design reduces the risk of burn-in to improve performance and longevity of the OLED panel.
A STUNNING DISPLAY
Experience the thrill of smooth and responsive gaming visuals on the ROG Swift OLED PG34WCDM’s 34-inch ultrawide 800R curved panel. The panel curvature mimics the shape of the human eye for unparalleled viewing experiences, and a blazing-fast 240 Hz refresh rate ensures that fast-paced onscreen action remains fluid and blur-free.
ASUS DISPLAYWIDGET CENTER
Intuitive ASUS DisplayWidget Center software lets you easily change monitor settings and OLED-related functions with your mouse, without needing to access the OSD menu.
DYNAMIC SHADOW BOOST
ASUS Dynamic Shadow Boost uses ROG Gaming AI technology to automatically enhance dark areas of the screen, making it easier to spot enemies hiding in dim corners of the map.
ERGONOMIC STAND
A specially designed hollowed-out stand offers tilt, swivel, and height adjustments for ideal viewing positions. The display is also VESA wall-mount-compatible.
 - ASUS ROG Swift PG34WCDM - OLED monitor - curved - 34" - HDR
 - OLED monitor - 34"
- Energy Label QR Code URL
 - Https://eprel.ec.europa.eu/qr/1815319
- Energy Class
 - Class F
- KVM Switch
 - USB
- Curved Screen
- Adaptive-Sync Technology
 - VESA Adaptive-Sync, AMD FreeSync Premium Pro, NVIDIA G-SYNC Compatible
 - USB 3.2 Gen 1 hub
- Aspect Ratio
 - 21:9
- Native Resolution
 - 3440 x 1440 at 240 Hz
- Pixel Pitch
 - 0.231 mm
- Brightness
 - 450 cd/m²
- Contrast Ratio
 - 1500000:1
- HDR Capable
 - HDR10
- Response Time
 - 0.03 ms (grey-to-grey)
- Gaming
- Colour Support
 - 1.0737 billion colours (10-bit)
- Colour Gamut
 - 99% DCI-P3, 135% sRGB
- Input Connectors
 - 2xHDMI, DisplayPort, USB-C
 - Height, swivel, tilt
- Screen Coating
 - Anti-glare
- Voltage
 - AC 100-240 V (50/60 Hz)
 - Dark grey
- Dimensions (WxDxH) - with stand (highest position)
 - 78.6 cm x 29.3 cm x 55.1 cm
 - 8.4 kg
 - TUV Rheinland Flicker Free Certification, HDCP 2.2, TUV Rheinland Low Blue Light (Hardware Solution), FSC Mix
- Display Type
 - OLED monitor / OLED
- Energy Class
 - Class F
- Energy Class (HDR)
 - Class F
- Diagonal Size
 - 34"
- Viewable Size
 - 33.94"
- Curved Screen
 - Yes (800R)
- Built-in Devices
 - USB 3.2 Gen 1 hub
- Aspect Ratio
 - 21:9
- Native Resolution
- Pixel Pitch
 - 0.231 mm
- Brightness
 - 450 cd/m²
- Contrast Ratio
 - 1500000:1
- HDR Format
 - HDR10
- Colour Support
- Colour Gamut
- Response Time
- Vertical Refresh Rate
 - 40 - 240 Hz
- Horizontal Refresh Rate
 - 30 - 390 kHz
- Gaming
- Horizontal Viewing Angle
 - 178
- Vertical Viewing Angle
 - 178
- Screen Coating
 - Anti-glare
 - Picture in picture, picture by picture, HDCP, Trace Free Technology, Flicker Free technology, proximity sensor, ASUS GameVisual Technology, colour adjustment mode, Colour Temperature Selection, GameFast Input Technology, ASUS Extreme Low Motion Blur technology, Low Blue Light technology, Shadow Boost technology, ASUS Aura Sync technology, GamePlus, Display Widget, tripod socket, Delta E=2 colour accuracy, Variable refresh rate (VRR), custom heatsink
 - Dark grey
 - 78.6 cm x 29.3 cm x 55.1 cm - with stand (highest position)
 - 8.4 kg
KVM
- Keyboard / Mouse Interface
 - USB
 - DisplayPort 1.4 (DSC (Display Stream Compression)) , 2 x HDMI , USB-C (DisplayPort Alt Mode, data, power up to 90W) , 2 x USB 3.2 Gen 1 downstream , USB 2.0 downstream , SPDIF output , Headphone jack
Mechanical
- Tilt Angle
 - -5/+20
- Swivel Angle
 - 30
- Height Adjustment
 - 110 mm
- VESA Mounting Interface
 - 100 x 100 mm
- Security Slot Type
 - Kensington security slot
- Input Voltage
- Power Consumption SDR (On mode)
 - 30 kWh/1000h
- Power Consumption HDR (On mode)
 - 31 kWh/1000h
- Power Consumption (Typical)
 - 31 Watt
- Power Consumption Stand by
 - 0.5 Watt
 - 0.3 Watt
- Dimensions & Weight Details
 - Without stand - width: 78.6 cm - depth: 27.5 cm - height: 55.1 cm - weight: 5.6 kg , With stand (highest position) - width: 78.6 cm - depth: 29.3 cm - height: 55.1 cm - weight: 8.4 kg , With stand (lowest position) - width: 78.6 cm - depth: 29.3 cm - height: 44.1 cm - weight: 8.4 kg
- Shipping Width
 - 89 cm
- Shipping Depth
 - 46.5 cm
- Shipping Height
 - 29.1 cm
- Shipping Weight
 - 13.5 kg
 - 0 °C
 - 40 °C
