Asus ROG Strix Hero III 15.6" Core i7-9750H 16GB RAM 512GB SSD + 1TB RTX 2060
Quicklinx: FDDTWS00 Mfr#: G531GV-ES037T
Display Size: 15.6in
Processor Model: I7-9750H
Operating System: Windows 10 Home
Installed Memory: 16GB
Hard Drive Capacity: 1.512TB
  • Core i7
11 in stock
£1,537.86 ex VAT
£1,845.43 inc VAT
The sleek and streamlined Strix Hero III is engineered for esports and peak gaming performance. Intelligent Cooling unleashes the raw power of the 9th Gen Intel Core CPU and GeForce RTX graphics, and makes full use of the ultra-fast gaming display. Jump into multiplayer matches anywhere with stronger RangeBoost Wi-Fi, show off your personality with the wraparound Aura Sync light bar, and gain privacy for personal data with the ROG Keystone.
  • Introducing the keystone
    Keystones offer an advanced way to personalize your machine and protect your personal data. These physical, NFC-enabled keys fit neatly into the Strix Hero III's chassis, adding a subtle accent along the trim.
  • See the game at professional speed
    Play at the speed of professional esports with the fast gaming laptop display. It enables true high-FPS gameplay capable of keeping up with competitive gaming at the high level. Stay in the flow of fast-paced action with impeccably smooth, crisp visuals that heighten your immersion.
  • Intelligent Cooling improves your experience
    ROG's Intelligent Cooling philosophy mixes the right features and system settings to ensure awesome experience for each situation.
  • Aura Sync
    Dim the lights and let Aura Sync take center stage. RGB glows behind the metallic ROG logo splashed across the lid, and illumination extends to the optional light bar wrapped around the outer rim of the chassis. Clear edges around the keys and transparent WASD caps highlight crucial keyboard commands. Access the full spectrum of colors and effects in the Aura control panel to let your personality shine.
  • A sound advantage
    Smart Amp technology monitors audio output and makes real-time adjustments to keep the speakers within thermal and excursion limits, preventing damage to the cones. The resulting sound has less noise distortion, higher dynamic range, more bass, and significantly higher potential output.
  • Explore virtual worlds
    Discover virtual and augmented reality titles with the ROG Strix Hero III. It delivers smooth, low-latency, and stutter-free VR for a wide variety of experiences. Plug-and-play compatibility with headsets means it's easy to access different environments on the platforms you prefer. Explore digital worlds with a cinematic smoothness that enables seamless visual immersion.
  • NVIDIA Turing Architecture
    This revolutionary architecture, combined with GeForce RTX platform, fuses together real-time ray tracing, artificial intelligence, and programmable shading. You've never created and enjoyed games like this before.
  • Real-time ray tracing in games
    Ray tracing is the definitive solution for lifelike lighting, reflections, and shadows, offering a level of realism far beyond what's possible using traditional rendering techniques. NVIDIA Turing is capable of real-time ray tracing.
  • Game Ready drivers
    Get high levels of performance, and a smooth experience, from the moment you start playing.
ASUS ROG Strix Hero III G531GV ES037T - 15.6" - Core i7 9750H - 16 GB RAM - 512 GB SSD + 1 TB Hybrid Drive
Notebook
Operating System
Windows 10 Home
Intel Core i7 (9th Gen) 9750H / 2.6 GHz (4.5 GHz) /
16 GB DDR4
Storage
512 GB SSD NVMe + 1 TB Hybrid Drive
Optical Drive
No optical drive
Display
15.6" LED backlight 1920 x 1080 / Full HD
Graphics
NVIDIA GeForce RTX 2060
Video Memory
6 GB GDDR6 SDRAM
Input Device
NumberPad
Keyboard Backlight
Yes (RGB)
802.11ac, Bluetooth 5.0, Gigabit Ethernet
36 cm x 27.5 cm x 2.49 cm
2.57 kg
Notebook
Operating System
Windows 10 Home
Processor / Chipset
CPU
Max Turbo Speed
4.5 GHz
Number of Cores
6-core
RAM
16 GB
Max RAM Supported
32 GB
DDR4 SDRAM
Rated Speed
2666 MHz
Storage
Main Storage
512 GB SSD - (M.2) PCIe - NVM Express (NVMe)
Secondary Storage
1 TB Hybrid Drive - Seagate
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1920 x 1080 (Full HD)
Widescreen
WideView, 100% sRGB colour gamut, slim bezel design, 3 ms response rate, 144 Hz refresh rate
Audio & Video
Graphics Processor
Video Memory
6 GB GDDR6 SDRAM
Sound
Stereo speakers, array microphone
Audio Features
Smart Amplification technology
Input
Keyboard, NumberPad
Keyboard Backlight
Yes (RGB)
Chiclet keyboard, ASUS Aura Sync RGB LED, per-key RGB, keystone button
Communications
Wireless
Network Interface
Gigabit Ethernet
AC Adapter
Output
230 Watt
Connections & Expansion
Headphone/microphone combo jack , 3 x USB 3.1 Gen 1 , USB-C 3.1 Gen 2/DisplayPort , HDMI , LAN
Case Material
Metal
Anti-dust cooling system, 3D Flow Zone design, Aura Sync light bar
Power adapter, web camera
2.57 kg
Software applications
Asus ROG Strix Hero III 15.6 Bundle deal on Asus ROG Strix Hero III 15.6" Core i7-9750H 16GB RAM 512GB SSD + 1TB RTX 2060
£1,637.03
Optical Storage: None
Graphics: NVIDIA GeForce RTX 2060
Hard Drive Type: SSD
Type: Gaming Laptop
Brand: Asus
Price Range Ex VAT: 1500+
