ASUS ROG Strix GeForce RTX 4090 OC Edition Graphics Card
Quicklinx: HX21WS00 Mfr#: STRIX-RTX4090-O24G-WHITE
The ROG Strix GeForce RTX 4090 brings a whole new meaning to going with the flow. Inside and out, every element of the card gives the monstrous GPU headroom to breathe freely and achieve ultimate performance. The unleashed reign of the NVIDIA Ada Lovelace architecture is here.
  • Axial-tech upgrades
    Bigger and better. Axial-tech fans spin on dual-ball bearings and have been scaled up to propel 23% more air through the card, setting the stage for lower temperatures, less noise, and higher performance.
  • Reverse rotation and 0 dB technology
    The two side fans spin counterclockwise to minimize turbulence and maximize air dispersion through the heatsink. All three fans come to a standstill when GPU temps are below 50 Celsius, letting you play less-demanding games or perform light tasks in relative silence. Fans start up again when temps are over 55 Celsius, referencing a speed curve that balances performance and acoustics for work or play.
  • 3.65-slot design
    The custom sink is generously sized and structured to soak up heat from the GeForce RTX 4090 GPU so that it can be efficiently whisked away by the three Axial-tech fans.
  • Patented vapor chamber
    A vapor chamber featuring milled pathways lets the heatpipes sink in without being pressed flat, allowing heat to be carried more efficiently to the fin stack. In comparison to conventional vapor chamber and heatpipe combos, this potent pairing reduces GPU temperature by up to 5 Celsius when subjected to a 500 W thermal load.
  • Premium power delivery
    Digital power control, an array of high-current power stages, and a lineup of 15K caps ensure massive reserves to reliably push performance boundaries.
  • Compact PCB
    Component and trace layouts have been optimized onto a short PCB to reduce power losses and let heat escape through a massive backplate vent.
  • Metal exoskeleton
    A high-quality diecast frame, shroud, and backplate tightly brace the PCB and strategically steer airflow.
  • FanConnect II
    Two PWM FanConnect headers provide additional DIY flexibility. Chassis fans can be directly attached to the card and tuned with a curve that is based on CPU and GPU temperatures, delivering extra intake or exhaust for demanding 3D tasks.
  • Auto-Extreme technology
    Auto-Extreme technology is an automated manufacturing process that sets new standards in the industry by allowing all soldering to be completed in a single pass. This reduces thermal strain on components and avoids the use of harsh cleaning chemicals, resulting in less environmental impact, lower manufacturing power consumption, and a more reliable product overall.
ASUS ROG Strix GeForce RTX 4090 - OC Edition - graphics card - NVIDIA GeForce RTX 4090 - 24 GB - white
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4090 - up to
24 GB GDDR6X
Memory Speed
21 Gbps
Boost Clock
2610 MHz
CUDA Cores
16384
Memory Interface
384-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x HDMI , 3 x DisplayPort
API Supported
OpenGL 4.6
7.01 cm x 35.76 cm x 14.93 cm
Enclosure Colour
White
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2610 MHz
CUDA Cores
16384
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
3.5-slot Fan Cooler, Aura Sync, 3rd gen Ray Tracing Cores, 4th gen Tensor Cores, AUTO-EXTREME technology, Axial-tech Fan Design, NVIDIA Ada Lovelace GPU technology, NVIDIA DLSS 3, 0dB Technology, ASUS FanConnect II, Dual Bios, Nvidia Broadcast, NVIDIA Reflex, Nvidia Studio, Power Delivery (PD), Vapour Chamber Combined Heat-pipe Design, NVIDIA Ansel, NVIDIA G-Sync ready, Resizable BAR, HDCP
Size
24 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
384-bit
Required Power Supply
1000 W
Additional Requirements
16 pin PCI Express power connector
Collection card, graphics card holder, hook-and-loop fastener, ROG ring
Software Included
ASUS GPU Tweak III, ASUS Quantumcloud, Adobe Creative Cloud (30 days trial), GeForce Experience
DisplayPort 1.4a, HDCP 2.3
7.01 cm
35.76 cm
14.93 cm
Enclosure Colour
White
