Asus ROG Strix GeForce RTX 4070 Ti OC Edition Graphics Card
Quicklinx: HVGGWS00 Mfr#: ROG-STRIX-RTX4070TIS-O16G-GAMI
ROG Strix GeForce RTX™ 4070 Ti SUPER 16GB GDDR6X OC Edition buffed-up design with chart-topping thermal performance
  • AI Performance: 722 AI TOPS
  • Powered by NVIDIA DLSS3, ultra-efficient Ada Lovelace arch, and full ray tracing.
  • 4th Generation Tensor Cores: Up to 4x performance with DLSS 3 vs. brute-force rendering
  • 3rd Generation RT Cores: Up to 2X ray tracing performance
  • OC edition: Boost Clock 2700 MHz (OC Mode)/ 2670 MHz (Default Mode)
  • Axial-tech fans scaled up for 31% more airflow
  • 3.15-slot design: massive fin array optimized for airflow from the three Axial-tech fans
  • Diecast shroud, frame, and backplate add rigidity and are vented to further maximize airflow and heat dissipation
  • Digital power control with high-current power stages and 15K capacitors to fuel maximum performance
  • Auto-Extreme precision automated manufacturing for higher reliability
  • Advanced cooling
    The Axial-tech Fan Design ensures superior cooling efficiency, keeping the ASUS ROG Strix GeForce RTX 4070 Ti SUPER 16GB running smoothly even under heavy loads.
  • Immersive gaming
    With 3rd gen Ray Tracing Cores and 4th gen Tensor Cores, gamers can experience incredibly realistic lighting, shadows, and reflections for a truly immersive gaming experience.
  • Enhanced connectivity
    Equipped with 2 HDMI and 3 DisplayPort interfaces, this video card supports up to 4 monitors, allowing for a versatile and expansive display setup.
  • High-speed memory
    The 16 GB GDDR6X SDRAM with a 256-bit bus width and a memory speed of 21 Gbps delivers exceptional bandwidth for high-resolution gaming and tasks.
  • Robust build quality
    Featuring AUTO-EXTREME technology and a metal backplate, the ASUS ROG Strix GeForce RTX 4070 Ti SUPER 16GB is built for durability and reliability.
ASUS ROG Strix GeForce RTX 4070 Ti SUPER 16GB - OC Edition - graphics card - GeForce RTX 4070 Ti Super - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4070 Ti SUPER
16 GB GDDR6X
Memory Speed
21 Gbps
Boost Clock
2670 MHz
Boost Clock (OC)
2700 MHz
CUDA Cores
8448
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
2 x HDMI , 3 x DisplayPort (version 1.4a)
API Supported
OpenGL 4.6
6.3 cm x 33.6 cm x 15 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2670 MHz
Boost Clock (OC)
2700 MHz
CUDA Cores
8448
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
3.15-slot Fan Cooler, AUTO-EXTREME technology, digital power control, metal backplate, ARGB Lighting, Aura Sync, Axial-tech Fan Design, 4th gen Tensor Cores, 3rd gen Ray Tracing Cores, NVIDIA DLSS 3, NVIDIA Ada Lovelace GPU technology, Nvidia Broadcast, NVIDIA G-Sync ready, NVIDIA Reflex, Nvidia Studio, Power Delivery (PD), Resizable BAR, Dual Bios, HDCP
Size
16 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
256-bit
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector
Graphics card support bracket, graphics card holder, collection card, hook-and-loop fastener, thank you card, 16-pin to 2x 8-pin cable adapter
Software Included
ASUS GPU Tweak III, GeForce Game Ready Drivers, NVIDIA Studio drivers
DisplayPort 1.4a, HDCP 2.3
6.3 cm
33.6 cm
15 cm
