Asus ROG RAMPAGE VI EXTREME Intel X299 S2066 DDR4 eATX
Quicklinx: D23QWS00 Mfr#: ROG RAMPAGE VI EXTREME
  • IEEE 802.11n
Intel X299 EATX gaming motherboard with Aura Sync RGB LEDs, triple M.2, DDR4 4000MHz, 10G Lan, 802.11ad Wi-Fi, U.2 and USB 3.1
  • Intel® Core™ X Series processor family: Ready for the latest LGA 2066 socket CPUs.
  • Quad-channel DDR4 4000 (OC) support
  • Superfast 10Gbps networking for up to 10X-faster data-transfer speeds, plus 802.11ad Wi-Fi support
  • Synchronise RGB lighting with a vast portfolio of Aura Sync capable PC gear – now with support for addressable light strips
  • ROG DIMM.2: Dual M.2 expansion card allows use of fans to prevent throttling
  • 5-Way Optimisation: Automated system-wide tuning, providing overclocking and cooling profiles that are tailor made for your rig
  • LiveDash OLED : Customisable panel displays vital system stats or your own logo
  • Gaming Audio: SupremeFX and Sonic Studio III – High fidelity audio that draws you deeper into the action
  • Best gaming protection – SafeSlot, and carefully-selected premium components for maximum durability
ASUS ROG RAMPAGE VI EXTREME - motherboard - extended ATX - LGA2066 Socket - X299
Motherboard - extended ATX
Chipset Type
Intel X299
Processor Socket
1 x LGA2066 Socket
Compatible Processors
Core i9
Max RAM Size
128 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 3 x M.2, 1 x U.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 8 x USB 3.1 Gen 1 + (1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, 10 Gigabit Ethernet, Gigabit Ethernet, 802.11a/b/g/n/ac, WiGig
Chipset Type
Intel X299
Processor Socket
LGA2066 Socket
Max Processors Qty
1
Core i9
Supported RAM
Max Size
128 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3333 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.), 4200 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
SupremeFX
High Definition Audio
LAN
Network Controller
Intel I219V / Aquantia AQC107
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (44-lane CPU (dual x16 mode; triple: x16, x16, x8 mode; quad: x16, x8, x8, x8 mode), 28-lane CPU (dual x16, x8 mode; triple: x8, x8, x8 mode)) , 1 x PCIe 3.0 x4
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 2 x M.2, 1 x U.2 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
RAID Features
Intel Rapid Storage Technology
1 x LAN (Gigabit Ethernet) , 8 x USB 3.1 Gen 1 , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x LAN (10Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK
Internal Interfaces
2 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x USB 3.1 Gen 2 - header , 1 x audio - header , 1 x Thunderbolt - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ASUS EZ Flash 3, SMBIOS 3.0 support, ACPI 6.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
Jack retasking, MemOK!, NVIDIA SLI Technology Support, ASUS Q-Design, Q-DIMM, GPU Boost, Q-LED, Q-Slot, ProbeIt, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, ASUS DIGI+ VRM, Intel Smart Response Technology, NVIDIA 4-way SLI Technology Support, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS Wi-Fi GO!, AMD 4-way CrossFireX technology support, DirectKey, Clear CMOS Button, ASUS Stainless Steel Back I/O, NexFET, Dual Intelligent Processors 5, LANGuard, protective I/O cover, USB 3.1 Boost, KeyBot II, GameFirst IV, ROG SSD Secure Erase, ASUS Gamer's Guardian, ASUS Fan Xpert 4, ASUS SafeSlot, Intel Turbo Boost Technology 3.0, Intel Optane Memory Ready, Sonic Radar III, Sonic Studio III, ASUS SafeDIMM, ASUS LiveDash, Intel VROC support, ASUS PRO Clock II Technology
ROG cable lables, ASUS 2T2R Wi-Fi moving aerials, fan extension card, ROG fan stickers, 3 x M.2 screws, ROG coasters, RGB (RGBW) LED strip extension cable, DIMM.2 extension card, ASUS WiGig 802.11ad moving aerial, 3 thermistor cables, ROG VGA holder, ROG DIMM.2 Fan Stand Pack
3 x Serial ATA cable , 1 x SLI bridge , 1 x 4-way SLI bridge , 1 x 3-way SLI bridge
Software Included
ASUS AI Charger, ROG CPU-Z, ASUS AI Suite III, ASUS Turbo App, Overwolf, ASUS EZ Flash 3, ROG Aura, ASUS ROG RAMCache II, ROG CloneDrive
Plug and Play
30.5 cm
27.7 cm
