ROG RAMPAGE VI EXTREME
Intel X299 EATX gaming motherboard with Aura Sync RGB LEDs, triple M.2, DDR4 4000MHz, 10G Lan, 802.11ad Wi-Fi, U.2 and USB 3.1
- Intel® Core™ X Series processor family: Ready for the latest LGA 2066 socket CPUs.
- Quad-channel DDR4 4000 (OC) support
- Superfast 10Gbps networking for up to 10X-faster data-transfer speeds, plus 802.11ad Wi-Fi support
- Synchronise RGB lighting with a vast portfolio of Aura Sync capable PC gear – now with support for addressable light strips
- ROG DIMM.2: Dual M.2 expansion card allows use of fans to prevent throttling
- 5-Way Optimisation: Automated system-wide tuning, providing overclocking and cooling profiles that are tailor made for your rig
- LiveDash OLED : Customisable panel displays vital system stats or your own logo
- Gaming Audio: SupremeFX and Sonic Studio III – High fidelity audio that draws you deeper into the action
- Best gaming protection – SafeSlot, and carefully-selected premium components for maximum durability
Enhanced audio experience
With SupremeFX 8-channel high definition audio codec, the ASUS ROG RAMPAGE VI EXTREME motherboard delivers exceptional sound quality that immerses gamers and audiophiles alike in a rich audio environment. -
Robust connectivity options
This motherboard boasts a comprehensive range of connectivity options, including Gigabit Ethernet, 10Gigabit Ethernet, and Wi-Fi standards up to IEEE 802.11ad (WiGig), ensuring high-speed connections for gaming, streaming, and more. -
Advanced cooling features
Equipped with ASUS Fan Xpert 4, the ASUS ROG RAMPAGE VI EXTREME ensures your system stays cool under pressure, enhancing performance and stability during intense gaming sessions. -
Superior memory support
Supporting DDR4 SDRAM across 8 DIMM slots with speeds up to 4200 MHz (O.C.), this motherboard allows for significant memory expansion and performance, catering to the needs of enthusiasts seeking overclocking capabilities. -
Versatile storage solutions
With support for M.2, U.2, and Serial ATA-600 interfaces, the motherboard offers flexible storage options, enabling users to benefit from fast data transfer speeds and high-capacity storage configurations.
- ASUS ROG RAMPAGE VI EXTREME - motherboard - extended ATX - LGA2066 Socket - X299
- Product Type
- Motherboard - extended ATX
- Chipset Type
- Intel X299
- Processor Socket
- 1 x LGA2066 Socket
- Compatible Processors
- Core i9
- Max RAM Size
- 128 GB
- RAM Supported
- 8 DIMM slots - DDR4, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 3 x M.2, 1 x U.2
- USB / FireWire Ports
- 1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 8 x USB 3.1 Gen 1 + (1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 2 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Bluetooth, 10 Gigabit Ethernet, Gigabit Ethernet, 802.11a/b/g/n/ac, WiGig
- Product Type
- Chipset Type
- Intel X299
- Processor Socket
- LGA2066 Socket
- Max Processors Qty
- 1
- Core i9
Supported RAM
- Max Size
- 128 GB
- Technology
- DDR4
- Bus Clock
- 2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3333 MHz (O.C.), 3733 MHz (O.C.), 3600 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.), 4200 MHz (O.C.)
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
- Audio Codec
- SupremeFX
- High Definition Audio
LAN
- Network Controller
- Intel I219V / Aquantia AQC107
- Network Interfaces
- Expansion Slots
- 1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (44-lane CPU (dual x16 mode; triple: x16, x16, x8 mode; quad: x16, x8, x8, x8 mode), 28-lane CPU (dual x16, x8 mode; triple: x8, x8, x8 mode)) , 1 x PCIe 3.0 x4
- Storage Interfaces
- SATA-600 -connectors: 6 x 7pin Serial ATA - RAID 0 / RAID 1 / RAID 10 / RAID 5 , PCIe 3.0 -connectors: 2 x M.2, 1 x U.2 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
- RAID Features
- Intel Rapid Storage Technology
- 1 x LAN (Gigabit Ethernet) , 8 x USB 3.1 Gen 1 , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 1 x LAN (10Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK
- Internal Interfaces
- 2 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x USB 3.1 Gen 2 - header , 1 x audio - header , 1 x Thunderbolt - header
- Power Connectors
- 4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ASUS EZ Flash 3, SMBIOS 3.0 support, ACPI 6.0 support
- Sleep / Wake Up
- Wake on LAN (WOL), wake on PME
- Hardware Features
- Jack retasking, MemOK!, NVIDIA SLI Technology Support, ASUS Q-Design, Q-DIMM, GPU Boost, Q-LED, Q-Slot, ProbeIt, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, ASUS DIGI+ VRM, Intel Smart Response Technology, NVIDIA 4-way SLI Technology Support, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS Wi-Fi GO!, AMD 4-way CrossFireX technology support, DirectKey, Clear CMOS Button, ASUS Stainless Steel Back I/O, NexFET, Dual Intelligent Processors 5, LANGuard, protective I/O cover, USB 3.1 Boost, KeyBot II, GameFirst IV, ROG SSD Secure Erase, ASUS Gamer's Guardian, ASUS Fan Xpert 4, ASUS SafeSlot, Intel Turbo Boost Technology 3.0, Intel Optane Memory Ready, Sonic Radar III, Sonic Studio III, ASUS SafeDIMM, ASUS LiveDash, Intel VROC support, ASUS PRO Clock II Technology
- Included Accessories
- ROG cable lables, ASUS 2T2R Wi-Fi moving aerials, fan extension card, ROG fan stickers, 3 x M.2 screws, ROG coasters, RGB (RGBW) LED strip extension cable, DIMM.2 extension card, ASUS WiGig 802.11ad moving aerial, 3 thermistor cables, ROG VGA holder, ROG DIMM.2 Fan Stand Pack
- Cables Included
- 3 x Serial ATA cable , 1 x SLI bridge , 1 x 4-way SLI bridge , 1 x 3-way SLI bridge
- Software Included
- ASUS AI Charger, ROG CPU-Z, ASUS AI Suite III, ASUS Turbo App, Overwolf, ASUS EZ Flash 3, ROG Aura, ASUS ROG RAMCache II, ROG CloneDrive
- Plug and Play
- 30.5 cm
- 27.7 cm
