Asus ROG RAMPAGE VI APEX Intel X299 S2066 DDR4 USB3.1 eATX
Quicklinx: D23NWS00 Mfr#: ROG RAMPAGE VI APEX
  • IEEE 802.11n
ROG RAMPAGE VI APEX
Intel X299 EATX enthusiast motherboard with record-breaking performance, Aura Sync RGB LEDs, DDR4 4000MHz+, dual DIMM.2 expansion cards (up to four M.2 SSDs), and USB 3.1 Type-A/C™.
  • Intel® Core™ X Series processor family: Ready for the latest LGA 2066 socket CPUs.
  • Quad-channel DDR4 4000MHz+ (OC) supported: Push memory to the max for smoother, faster performance.
  • Engineered for performance: Streamlined layout breaks all boundaries.
  • Dual DIMM.2: Two dual M.2 expansion cards with fan mounting kits that allow users to install their own fans to prevent throttling
  • X-shaped PCB: Unique cutouts allow Aura Sync lighting to shine through.
  • Illuminated customisable nameplate: Your board, your insignia.
  • Aura Sync RGB LED: Stunning synchronised effects and two Aura 4-pin RGB-strip headers.
  • ROG Water Cooling Zone: Dominate your cooling system.
  • 3D-Printing Friendly: Make it your own.
  • Made for great gaming: 5-Way Optimisation, SupremeFX audio, Intel gigabit Ethernet and LANGuard.
  • Best gaming protection: SafeSlot, SafeDIMM and premium components for maximum durability.
  • Hardware-level controls
    Rampage VI Apex includes an overclocker's toolkit with hardware-level controls to aid your overclocking experience. The motherboard's Dual BIOS allows you to experiment with different firmware versions and provides a path for recovery in case one becomes corrupt, and the onboard switch allows you to easily change between the first and second BIOS. The overclocker's toolkit also includes a Pause switch to halt the system, and four PCIe switches for quick slot toggling. Other tools include Safe Boot and ReTry buttons, an LN2 jumper to aid POST at sub-zero temperatures, and a Slow mode switch. Combined, they're quick and easy time-savers designed to help you break more records.
  • Condensation detection
    Specialized circuitry allows Rampage VI Apex to detect when condensation occurs on the back of the board. Divided into four distinct sections - CPU, DRAM L, DRAM R and PCIe - the feature provides a useful warning when an area may be at risk of short-circuiting.
  • Optimized trace layout
    It's the combination of intricate and innovative engineering that makes Rampage VI Apex such a big performer. Allotting just one DIMM slot per channel allowed the engineers to create shorter trace distances, which in turn means tighter control over impedance and reduced possibility for signal interference. The end result is a motherboard with better stability and more overclocking headroom, allowing you to get the best performance from your memory kit.
  • DDR4 overclocking strength in numbers
    ROG engineers adopted a four-slot memory design on an EATX motherboard, enabling a highly optimized layout for memory trace paths to minimize noise and improve signal integrity. R
  • Dual ROG DIMM.2
    Rampage VI Apex includes two ROG DIMM.2 modules to support a total of four PCIe 3.0 x4 M.2 SSDs. ROG DIMM.2 supports a wide variety of existing memory coolers, and the Rampage VI Apex comes with two fan mounts that support up to two 50 mm fans or a single 80 mm fan, making it easy to chill your M.2 drives. Each module features a pair of onboard thermal-sensor headers for temperature reporting, allowing control over fan speed and acoustics via Fan Xpert 4 software, or the ASUS UEFI.
  • Outshine the competition
    A well-tuned enthusiast system deserves a matching aesthetic. ASUS Aura offers full RGB lighting control with a variety of functional presets for the built-in RGB LEDs, as well as strips connected to the two onboard 4-pin RGB headers. And it can all be synced with an ever-growing portfolio of Aura Sync-enabled ASUS hardware.
  • X-shaped PCB
    With an asymmetrical X-shaped circuit board and a radical lighting scheme, Rampage VI Apex dares to be different. The unique X design enables simpler, cleaner cable routing, and features Aura RGB backlighting to make your build stand out from the crowd.
  • Shielded audio, superior sound
    Rampage VI Apex's awesome SupremeFX audio technology has leveled up, delivering an exceptional signal-to-noise ratio on the line-in connection for excellent ROG recording quality! The low-dropout regulator is also added for cleaner power delivery to the SupremeFX S1220A codec. It all adds up to audio that envelops you as never before!
ASUS ROG RAMPAGE VI APEX - motherboard - extended ATX - LGA2066 Socket - X299
Motherboard - extended ATX
Chipset Type
Intel X299
Processor Socket
1 x LGA2066 Socket
Compatible Processors
Core X
Max RAM Size
64 GB
RAM Supported
4 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
6 x SATA-600 (RAID), 3 x M.2
USB / FireWire Ports
1 x USB-C Gen 2 + 1 x USB 3.1 Gen 2 + 6 x USB 3.1 Gen 1 + 2 x USB 2.0 + (1 x USB 3.1 Gen 2 + 4 x USB 3.1 Gen 1 + 3 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Chipset Type
Intel X299
Processor Socket
LGA2066 Socket
Max Processors Qty
1
Core X
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2400 MHz, 2133 MHz, 2800 MHz (O.C.), 2600 MHz (O.C.), 3000 MHz (O.C.), 3200 MHz (O.C.), 3300 MHz (O.C.), 3333 MHz (O.C.), 3600 MHz (O.C.), 3800 MHz (O.C.), 3866 MHz (O.C.), 4000 MHz (O.C.), 4133 MHz (O.C.), 4500 MHz (O.C.), 4266 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
SupremeFX
High Definition Audio
LAN
Network Controller
Intel I219V
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x8, x8 mode; quad: x16, x8, x8, x8 mode; single card: x16 mode) , 1 x PCIe 3.0 x4
Storage Interfaces
SATA-600 -connectors: 6 x 7pin Serial ATA , PCIe 3.0 , SATA-600 / PCIe 3.0 -connectors: 1 x M.2
RAID Features
Intel Rapid Storage Technology
1 x LAN (Gigabit Ethernet) , 6 x USB 3.1 Gen 1 , 1 x USB 3.1 Gen 2 , 1 x USB-C Gen2 , 2 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x PS/2 keyboard , 1 x PS/2 mouse
Internal Interfaces
3 x USB 2.0 - header , 4 x USB 3.1 Gen 1 - header , 1 x USB 3.1 Gen 2 - header , 1 x audio - header
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, USB BIOS Flashback, UEFI BIOS, ASUS EZ Flash 3, SMBIOS 3.0 support, ACPI 6.0 support
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, NVIDIA SLI Technology Support, ASUS Q-Design, GPU Boost, ASUS EZ DIY, Q-LED, ProbeIt, ASUS Extreme Engine Digi+, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Intel Smart Response Technology, NVIDIA 4-way SLI Technology Support, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, AMD 4-way CrossFireX technology support, Clear CMOS Button, NexFET, Dual Intelligent Processors 5, LANGuard, ROG SSD Secure Erase, ASUS Fan Xpert 4, ASUS SafeSlot, Intel Turbo Boost Technology 3.0, 3D printing friendly, Intel Optane Memory Ready, ASUS SafeDIMM, Intel VROC support
I/O back plate, ROG cable lables, ASUS 2T2R Wi-Fi moving aerials, ROG fan stickers, 2 x M.2 screws, ROG coasters, RGB (RGBW) LED strip extension cable, CPU installation tool, DIMM.2 extension card, ROG DIMM.2 Fan Stand Pack
1 x Serial ATA cable , 1 x SLI bridge , 1 x 4-way SLI bridge , 1 x 3-way SLI bridge
Software Included
Kaspersky Anti-Virus, ROG CPU-Z, ROG Mem TweakIt Utility, ASUS WebStorage, WinZip, ASUS AI Suite III, ROG RAMDisk, ASUS Turbo App, Overwolf, ASUS EZ Flash 3, ROG Aura, ASUS ROG RAMCache II, ROG CloneDrive, DAEMON Tools
Plug and Play
30.5 cm
27.2 cm
