Asus ROG Gladius II Core
Quicklinx: GRXGWS00 Mfr#: 90MP01D0-B0UA00
ROG Gladius II Core channels the classic Gladius optical gaming mouse spirit into an accessible form, sporting non-slip sides etched with the iconic ROG totem. Gladius II Core has a 6200-dpi optical sensor, and independent left and right buttons for accurate response and precise control. With right-handed ergonomics for extended comfort, a fatigue-preventing lightweight build, push-fit switch sockets and integrated Aura Sync illumination, Gladius II Core is primed for outstanding victories.
  • Gaming-grade performance
    With a gaming-grade PAW3327 optical sensor, ROG Gladius II Core is the perfect sidearm for gaming glory, delivering 200- to 6200-dpi sensitivity for pinpoint precision. It also tracks up to 220 inches per second (IPS) at up to 30 g acceleration, allowing you to strafe and swipe as swiftly as needed to rule the battlefield.
  • Exclusive switch socket design
    The ROG-exclusive switch-socket design takes personalization to another level by enabling mouse switches to be easily changed. This means you have the option to instal the switch of your preferred operating force and feedback, and you can replace worn or broken switches to extend the lifespan of the mouse.
  • Ergonomically designed for all grip types
    ROG Gladius II Core delivers the ultimate gaming comfort, campaign after campaign. Its contours and other design details, such as the textured side panels, were developed through meticulous trials. The result is a gaming mouse that fits snugly in the right hand, optimised especially for palm, claw grip or fingertip styles.
ASUS ROG Gladius II Core - mouse - USB - black
Mouse
Wired - USB
Orientation
Right-handed
6.7 cm x 12.6 cm x 4.5 cm
92.5 g
Movement Detection Technology
Optical
Movement Resolution
6200 dpi
Performance
30 G maximum acceleration, up to 220 inches per second
Gaming
Easy-swap switch socket, separate right/left buttons, ASUS Aura Sync RGB LED, Pixart PAW 3327 optical gaming sensor
Windows 10 (32/64 bits)
ASUSPRO P1; 14; 15; ROG Strix G GL531; ROG Strix G15; G17; ROG Strix SCAR 17; ROG Zephyrus Duo 15; ROG Zephyrus G14; M15; S15; S17; TUF Gaming A15; A17; F15; F17; FX505; FX705; TUF505; VivoBook 14; 15; 17; VivoBook Flip 12 TP202; 14 TP401; X543; ZenBook 13; 14; ZenBook Duo UX481
Mouse
Orientation
Right-handed
Gaming
6.7 cm
12.6 cm
4.5 cm
92.5 g
Input Device
Wired
USB
Optical
Movement Resolution
6200 dpi
Performance
Software Included
ROG Armoury II
ASUSPRO P1 P1440FA-C53P , ASUS 14 X409JA-EK026T , ASUS 15 M509BA-EJ183T, M509DA-EJ025, M509DA-EJ1062T, S509DA-EJ029T , ASUS ROG Strix G GL531GU WB53 , ASUS ROG Strix G15 G512LU-AL041T, G512LW-WS74 , ASUS ROG Strix G17 G712LU-H7015T, G712LU-H7023T, G712LV-EV023T, G712LV-H7074T, G712LV-H7077T , ASUS ROG Strix SCAR 17 G732LV-EV029T, G732LWS-HG029T, G732LXS-HG014R, G732LXS-XS94 , ASUS ROG Zephyrus Duo 15 GX550LWS-32T, GX550LWS-HC037T, GX550LXS-XS96 , ASUS ROG Zephyrus G14 GA401II-025T, GA401II-HE092T, GA401II-HE109T, GA401IU-HE002 , ASUS ROG Zephyrus M15 GU502LV-HC049T, GU502LW-HN138T , ASUS ROG Zephyrus S15 GX502LWS-HF020T , ASUS ROG Zephyrus S17 GX701LWS-EV029T, GX701LWS-EV076T, GX701LWS-HG052R, GX701LWS-HG052T, GX701LXS-HG007T , ASUS TUF Gaming A15 FX506II-HN111T, FX506IU-HN222T, FX506IU-HN296T , ASUS TUF Gaming A17 FX706II-AU031T , ASUS TUF Gaming F15 FX506IH-BQ224T, FX506LH-BQ030, FX506LH-HN111T, FX506LI-BQ052T, FX506LI-HN023T, FX506LI-HN222T, FX506LU-HN037T, FX506LU-HN333T , ASUS TUF Gaming F17 FX706LI-AU022T, FX706LI-H7010T , ASUS TUF Gaming FX505DT BQ000T, BQ137T, HN549T, HN565T, HN571T, WB72 , ASUS TUF Gaming FX505DV , ASUS TUF Gaming FX705DT , ASUS TUF Gaming FX705DY , ASUS TUF505DV HN232T , ASUS VivoBook 14 K413FA-EK695T, M413IA-EB371T , ASUS VivoBook 15 F512JA-EJ011T, X512DA-EJ1458T, X512FB-BR468T, X512FJ-EJ529T, X512JA-BQ147T , ASUS VivoBook 17 M712DA-AU311T, X712FA-AU606R, X712FA-AU642T, X712FA-AU643T, X712FA-AU848T , ASUS VivoBook Flip 12 TP202NA CMSP, QMSP, XS04 , ASUS VivoBook Flip 14 TP401MA CMSP, QMSP , ASUS X543UA GO3047T, GQ2636T , ASUS ZenBook 13 UX334FAC-A4113T , ASUS ZenBook 14 UM433IQ-PURE5, UX425JA-BM090R, UX431FA-AN168T, UX433FAC-AI258R, UX434FAC-A5188T , ASUS ZenBook Duo UX481FL
