Asus Rog Gladius Gaming Mouse
Quicklinx: BRQJWS00 Mfr#: 90MP0081-B0UA00
ROG Gladius is an optical wired gaming mouse engineered with perfect right-hand ergonomics for first-person shooter mastery! Smooth-touch materials stay cool in your hand and high-quality Mayan-patterned rubber secures your grip. With exclusive switch socket design for customizable click resistance, 'slide-to-press' side switches and optical sensor that tracks up to 200 inches per second, the battlefield is at your mercy. Detach the cable for carrying around - lock and load!
  • Epic ergonomics and aesthetics
    World top pro gamers involved in design stage, back and forth to ensure the best ergonomics! The fine-tuned curves make Gladius the perfect fit for all grip-types.
  • Unbeatable performance
    Gladius is manufactured with high-quality mouse switches that are good for at least 20-million presses, so you'll enjoy accurate clicks from buttons that just keep going. Forget soldering hassles when changing mouse switches, as ROG's exclusive socket design means you pick and fit your perfect click resistance and recoil with one simple push.
  • Best mobility
    Gladius comes with two USB cables. Leave the 2-meter cable on your desk for convenience and carry the 1-meter travel cable to LAN parties or internet cafés - it takes just one touch to detach either cable!
  • Intuitive customization
    Gladius has built-in flash memory to store your favorite profile, so it's always by your side. It also features the innovative software - allowing you to create, customize, and store unlimited profiles on your PC! The Gladius software includes an intelligent surface-calibration tool for pixel-perfect precision. Gladius analyzes and learns the surface characteristics to hone the sensor's accuracy - and that means even better in-game responsiveness!
ASUS ROG Gladius - mouse - USB - steel grey
Mouse
Wired - USB
Steel grey
Orientation
Right-handed
6.7 cm x 12.6 cm x 4.5 cm
116 g
Movement Detection Technology
Optical
Buttons Qty
6
Movement Resolution
6400 dpi
Performance
50 G maximum acceleration, up to 200 inches per second
OMRON switches, braided cable, detachable micro-USB cable, built-in flash memory, programmable buttons, slide-to-press buttons, on-the-fly DPI switching, rubber side grips, easy-swap switch socket, separate right/left buttons, red LED illumination, 2 DPI levels, Alps scroll wheel encoder
Cable Length
2 m
Microsoft Windows 7, Windows 8, Windows 8.1
Mouse
Orientation
Right-handed
6.7 cm
12.6 cm
4.5 cm
116 g
Steel grey
Input Device
Wired
USB
Optical
Buttons Qty
6
Movement Resolution
6400 dpi
Performance
Cable Length
2 m
Carrying pouch, mouse feet, 2 Omron switches, USB cable (1 m), USB cable (2 m)
Software Included
ROG Armoury
