ROG Delta Core is a 3.5mm gaming headset that supports all of your favorite gaming platforms. Equipped with exclusive ASUS Essence drivers, airtight chambers and audio signal diversion technology, ROG Delta Core delivers high-resolution sound and deep, punchy bass to fully immerse you in your games. Ergonomic D-shaped ear cups with ROG Hybrid ear cushions give you upgraded comfort, so you can game without fatigue. With superb sound quality and an excellent balance of features, ROG Delta Core is ready to become an essential component in your gaming arsenal.
High-resolution audio
With ROG Delta Core, the exclusive ASUS Essence drivers have been updated with Audio Signal Diversion technology, giving them a circular wall that helps separate high-, low- and medium-frequency sounds, reducing interference between frequency ranges for purer and clearer audio. Additionally, the drivers feature a wide frequency response of 20Hz-40kHz to provide incredibly strong bass and optimised gaming sound, so you'll hear every detail while enjoying an all-around immersive acoustic experience. -
Exclusive airtight-chamber design
Fine-tuned by audio engineers, ROG Delta Core features an enlarged area around the drivers with an exclusive airtight-chamber design for improved isolation and pristine, natural-sounding audio. -
Clear communication
ROG Delta Core comes with a detachable, unidirectional boom microphone which is tuned to make your voice stand out for clearer and easier communication with your teammates. -
ROG Delta Core has ergonomic, D-shaped ear cups that more closely match the shape of human ears compared to oval ear cups, reducing the unnecessary contact area by 20% for a better, more comfortable fit, especially when the headset is worn for long periods. -
Angled for better comfort and sound
The drivers inside each ear cup are tilted by 12 degrees, closely matching the natural angle of human ears. This sloped design not only provides better comfort, but also helps improve sound quality by enabling the audio signal to travel directly into the ear canal. -
Instant control at your fingertips
A volume wheel and microphone toggle on the ear cup let you make instant audio adjustments and mute or unmute your voice during gameplay. With intuitive controls right within reach, you can stay focused on your game instead of your gear.
- ASUS ROG Delta Core - headset
- Product Type
- Headset - wired - 3.5 mm jack
- Recommended Use
- Game console, portable electronics, computer
- Headphones Form Factor
- Full size
- Connectivity Technology
- Wired
- Sound Output Mode
- Stereo
- Audio Specifications
- Frequency Response 20 - 40000 Hz
- Microphone
- Boom
- Microphone Operation Mode
- Uni-directional
- Controls
- Volume, microphone on/mute
- 1-year warranty
- Designed For
- ROG Strix G GL531GU; ROG Strix G15; G17; G531GT; ROG Zephyrus G14; M15; S15; S17; TUF Gaming F17; FX505DT; FX505DV; TUF505DV
- Product Type
- 346 g
- Recommended Use
Audio Output
- Full size
- Wired
- Sound Output Mode
- Stereo
- 20 - 40000 Hz
- Diaphragm
- 50 mm
- Magnet Material
- Neodymium
Microphone
- Boom
- Form Factor
- Detachable headset microphone
- Uni-directional
- Sensitivity
- -40 dB
- 100 - 10000 Hz
- Audio Input Details
- Uni-directional - 100 - 10000 Hz
Remote Control
- Controls
- Connector Type
- Headset (mini-phone stereo 3.5 mm 4-pole)
Cable
- Cable Length
- 1.5 m
- Included Accessories
- 2 ear cushions
- Cable Details
- Headset cable - 1.5 m , Mini-phone 3.5 mm 4-pole to 2 x mini-phone 3.5 mm cable - 1 m
- Limited warranty - 1 year
- Designed For
- ASUS ROG Strix G GL531GU WB53 , ASUS ROG Strix G15 G512LU-AL041T, G512LW-WS74 , ASUS ROG Strix G17 G712LU-H7015T, G712LU-H7023T, G712LV-EV023T, G712LV-H7074T, G712LV-H7077T , ASUS ROG Strix G531GT , ASUS ROG Zephyrus G14 GA401II-025T , ASUS ROG Zephyrus M15 GU502LV-HC049T, GU502LW-HN138T , ASUS ROG Zephyrus S15 GX502LWS-HF020T , ASUS ROG Zephyrus S17 GX701LWS-HG052T , ASUS TUF Gaming F17 FX706LI-AU022T, FX706LI-H7010T , ASUS TUF Gaming FX505DT HN571T , ASUS TUF Gaming FX505DV , ASUS TUF505DV HN232T
