ROG Claymore is the world's first RGB mechanical gaming keyboard with a detachable numeric keypad to give you flexible placement options when gaming. It features Cherry MX RGB switches to give you precise and responsive keystrokes and individually-programmable backlit keys with Aura sync RGB LED technology for unmatched levels of personalization. This 100% anti-ghosting keyboard has N-Key rollover technology, on the fly macro recording, and dedicated hotkeys for exclusive ASUS motherboard cooling and overclocking controls. ROG Claymore gives you the winning edge in the digital battlefield.
ASUS Aura - let there be light
Fire up Aura and enjoy a mesmerizing light show on ROG Claymore's individually-customizable backlit keys, and get creative with its palette of over 16 million colors. You'll also be able to sync your customized light effect with the ever-growing range of Aura-enabled gear. -
Every keystroke counts
ROG Claymore features Cherry MX RGB switches, 100% anti-ghosting with N-Key rollover (NKRO) technology, fully programmable keys and on the fly macro key recording to ensure you always get the winning edge.
- ASUS ROG Claymore - keyboard - UK - black Input Device
- Keyboard
- Backlit
- RGB
- Interface
- USB
- Connectivity Technology
- Wired
- Localization and Layout
- UK
- Hot Keys Function
- Volume, mute
- Numeric Keypad
- Key Switch Type
- CHERRY MX Red
- Black
- 45 cm x 14.5 cm x 4.5 cm
- 943 g
- 2-year warranty
- Keyboard
- Backlit
- RGB
- Interface
- USB
- Hot Keys Function
- Volume, mute
- UK
- Keyboard Technology
- Mechanical
- Key Switch Type
- CHERRY MX Red
- Adjustable Height
- Detachable Cable
- Numeric keypad
- 45 cm
- 14.5 cm
- 4.5 cm
- 943 g
- Black
- Cable Length
- 1.8 m
- Included Accessories
- 2 x ROG pouches
- OS Required
- Microsoft Windows 7 / 8.1 / 10
- Limited warranty - 2 years
