Stay In-Sync, stay immersed
ROG Cetra True Wireless gaming headphones are equipped with hybrid ANC technology and low-latency wireless to keep you in the zone and in sync with immersive audio experiences. EQs and specially tuned 10 mm ASUS Essence drivers add another layer of quality to your gaming audio, and more hours of battery life, wireless charging and IPX4 water resistance let you keep gaming wherever you go. -
Low-latency wireless audio
Gaming mode can be activated with a simple touch or via Armory Crate, enabling low-latency connection and greater synchronization between audio and video playback for competitive gaming. -
Active Noise Cancelation for full immersion
Hybrid Active Noise Cancelation (ANC) detects and filters out noise coming from both inside and outside of the headphones, enabling an immersive audio experience that leaves you undisturbed when you're jamming to your favorite beats or taking on missions in your favorite game. -
Exceptional audio
Specially tuned 10 mm ASUS Essence drivers and airtight chambers provide rich, clean sound, particularly in the mid and high frequency range, while powerful bass lets you enjoy true-to-life audio. -
Extensive battery life with fast charging
With ANC off, you can enjoy several hours of use on a single charge and extend that by extra hours with the charging case. When you're in a jam, just 10 minutes of charging gives you several hours of usage thanks to quick-charge technology. -
Water resistance
IPX4 splash-proof water resistance adds protection and extra durability. -
Instant control at your fingertips
Simple quick-touch controls at the tips of your fingers enable rapid in-game adjustments.
 - ASUS ROG Cetra True Wireless - true wireless earphones with mic
- Product Type
 - True wireless earphones - Bluetooth
- Recommended Use
 - Game console, portable electronics, computer
- Gaming
- Style
 - Games
 - Black
- Headphones Form Factor
 - In-ear
- Wireless Technology
 - Bluetooth
- Sound Output Mode
 - Stereo
- Sound Effects
 - 7.1 Channel Virtual Surround Sound
- Audio Specifications
 - Frequency Response 20 - 20000 Hz
- Impedance
 - 32 Ohm
- Active Noise Canceling
- Microphone Operation Mode
 - Omni-directional
- Controls
 - Play/pause, next/previous track, voice assistant, ANC on/off, game mode on/off, ANC mode
 - 2-year warranty
- Product Type
 - True wireless earphones - Bluetooth - wireless
- Style
 - Games
- Dimensions & Weight Details
 - Charging case: 42 g , Earphone: 5 g
 - Black
- Recommended Use
- Gaming
 - Touch control
- Protection
 - Splashproof, IPX4
Audio Output
 - In-ear
- Connectivity Technology
 - Wireless
 - Bluetooth
- Sound Output Mode
 - Stereo
- Sound Effects
- Active Noise Cancelling Technology
 - Hybrid ANC
 - 20 - 20000 Hz
- Impedance
 - 32 Ohm
- Diaphragm
 - 10 mm
- Magnet Material
 - Neodymium
Microphone
- Form Factor
 - Built-in
 - Omni-directional
- Sensitivity
 - -38 dB
 - 100 - 10000 Hz
Remote Control
- Controls
- Included Accessories
 - 2 pairs of ear tips
- Cable Details
 - Charging cable - 60 cm
 - IPX4
- Battery
 - Headphone battery rechargeable - wireless charging
- Run Time (Up To)
 - 5.5 hour(s)
- Run Time Details
 - Continuous playback (noise cancelling ON): up to 4.8 hours , Continuous playback (noise cancelling OFF): up to 5.5 hours , Continuous playback (noise cancelling OFF / with included charging case): up to 27 hours , Continuous playback (noise cancelling ON / with included charging case): up to 21.8 hours
 - Limited warranty - 2 years
