Gaming handheld
Sink deep into your favorite AAA or indie games and watch the hours melt away with an expansive Full HD 120 Hz display and incredibly comfortable ergonomics. -
Home entertainment system
Share the fun by connecting to a TV and pairing multiple controllers, instantly transforming the Ally into a formidable couch multiplayer console. -
Full throttle gaming
For a truly top-tier experience, pair the Ally with an XG Mobile external GPU, monitor, mouse, and keyboard for esports and high-fidelity 4K gaming. -
Born for handheld gaming
AMD's Ryzen Z1 Extreme processor powers this incredible gaming machine. Built on the cutting edge 4 nm process, this silicon features both the Zen 4 architecture and RDNA 3 graphics. Featuring incredible upscaling technologies like FidelityFX Super Resolution and Radeon Super Resolution, the Ally can boost framerates while retaining excellent image quality. ROG worked in close collaboration with AMD to unleash the full potential of this cutting-edge hardware, and the Ryzen Z1 Extreme is here to take the gaming world by storm. -
MicroSD expansion
If you have a larger game library, the Ally has you covered. A dedicated UHS-II microSD card slot allows you to effortlessly add high-speed storage to your machine, letting you keep more of your games installed and ready to play. Boasting nearly the same load times as the dedicated PCIe Gen 4 SSD, you'll never need to worry where you store your games. -
Game on the go
Play your favorite games and content for hours without worrying about a charger. Enjoy many hours of gaming locally on the device, with long time of video playback. The Ally also supports fast charging, enabling it to charge from 0-50% in a short time. -
Zero gravity thermal system
The ROG Ally is designed to let you play anywhere, so it needed a thermal solution to match. Traditional thermal solutions count on gravity to help heat pipes cycle heat out of the system, but with a specially constructed pipe that uses a mesh, the Ally truly defies gravity. -
Anti-Gravity heat pipes
Anti-Gravity heat pipes improve thermal transfer by using a mesh for the wick, increasing capillary pressure by more than 15%. This allows the Ally's cooling solution to maintain effectiveness even when upside-down. -
Fluid dynamic bearing
Both fans have a fluid bearing design, which is a tried and tested style that will keep the Ally spinning like a top for years to come. Fluid bearing fans also are low friction even when run in non-traditional orientations, letting you hold the Ally in any direction without worry. -
Zero distraction
While many handhelds on the market opt for a single fan, ASUS knows that extra airflow is always beneficial. The Ally is equipped with two fans, allowing better cooling at slower speeds to keep noise to a minimum. -
Lightning fast, crystal clear
A high-powered machine needs a top-spec display to match, and the Ally has specifications that just a few years ago would have rivaled gaming laptops many times its size. Sporting a 1080p touchscreen panel with a 120 Hz refresh rate and FreeSync Premium support, this 7-inch display is truly a joy to game on. With 100% coverage of the sRGB color space, you can trust that all of your content looks exactly as the game makers intended.
- ASUS ROG Ally RC71L-NH001W - handheld game console - 512 GB SSD - white
- Product Type
- Handheld game console
- Internal Memory
- 512 GB SSD
- Operating System
- Windows 11 Home
- Display
- 7" colour - 1920 x 1080 - touch screen (Multi-Touch) - 120 Hz - 10-point multi-touch, glossy display, 7ms grey-to-grey response time, Gorilla Glass DXC, Gorilla Glass Victus, NTSC 72%, sRGB 100%, Adobe 75.35%
- Sensors
- Fingerprint reader
- Media
- Flash memory card
- Supported Flash Memory Cards
- microSD, microSDHC UHS-II Memory Card, microSDXC UHS-II Memory Card
- Network
- Wi-Fi 6, Bluetooth 5.2
- Battery
- 4-cell Lithium Ion - 40 Wh - 40 Wh
- White
- 28 cm x 2.12 cm x 11.1 cm
- 600 g
- Included Accessories
- AC power adapter
- Product Type
- Operating System
- Windows 11 Home
- Internal Memory
- 512 GB SSD
- Media
- Flash memory card
- Processor
- Ryzen Z1 Extreme 8-core
- RAM
- 16 GB LPDDR5 SDRAM
- Graphics Processor
- AMD Radeon Navi3
- Sound
- Speakers
- Network
- 802.11a/b/g/n/ac/ax, Bluetooth 5.2
- AI noise cancelling technology, Smart Amplifier Technology, ASUS Aura Sync technology, triple-band Wi-Fi connection, built-in microphone array, Hi-Res audio certification, ROG XG Mobile interface
- Surround Sound Supported
- Dolby Atmos
- 28 cm
- 2.12 cm
- 11.1 cm
- 600 g
- White
Display
- LCD display 7" colour
- Resolution
- 1920 x 1080
- Touch Screen
- Yes (Multi-Touch)
- Refresh Rate
- 120 Hz
- Display Features
- Connector Type
- USB 3.2 Gen 2 , Audio line-out
- Power Source
- AC power adapter, battery
- Battery
- Rechargeable - 4-cell Lithium Ion - 40 Wh - 40 Wh
- Sensors
- AC power adapter
