- Versatile camera that can be used as an in-car dash cam or portable camera.
- Full HD 1080p video recording with Sony sensor.
- Real-time previews and downloads on smart devices.
- NFC One Touch Engage for easy syncing to smart devices.
- 500GB of ASUS WebStorage free for one year.
- Compatible with standard camera accessories.
One camera. Double the excitement.
Reco Smart is a small and versatile device that doubles both as an in-car dash cam and portable camera. Connect it with your smart device via Wi-Fi and the ASUS Reco app for real-time previews, or download and share the images and videos. With One-Shot, Time Lapse, and Photo Burst modes, Reco Smart is more than just a car cam, it's one that lets you capture life's little moments.
Crisp Full HD recording
Record Full HD 1080p or 720p videos at a smooth 30 frames per second. Reco Smart features a Sony image sensor to give you high quality photos and videos with high color saturation and stunning clarity.
Capture all night time moments
Reco Smart has an f/1.8 aperture lens to help you record the tiniest details even in low-light environments. Wide Dynamic Range (WDR) technology improves image quality even under high-contrast lighting – so you're always guaranteed clear images and video.
See more of the road ahead
Reco Smart has a 150-degree wide-angle lens that gives you unobstructed views of the sides of your vehicle and the road ahead. It takes great videos and pictures once you're out of the car as well, with its wide-view lens allowing you to capture entire vistas in one frame.
Instant preview and download with the ASUS Reco app
The ASUS Reco app lets you connect Reco Smart to your smart devices via Wi-Fi to give you full intuitive control of the camera. You can even preview, download, or share images and videos with friends and family. Its user-friendly interface and NFC Engage makes setting up quick and easy.
Backup files in the cloud with 500GB of ASUS WebStorage free
With the ASUS WebStorage, you no longer need to worry about losing your memory card. In the event of an accident, the ASUS Reco app will automatically upload files to the cloud1. Reco Smart comes with 500GB of free ASUS WebStorage2 - that's enough space for over 7,500 video files.
ASUS WebStorage also lets you easily share files and access them anywhere, on any device, through the cloud. The service automatically syncs your files across all devices, so every file is kept up-to-date.
Get creative with three photo modes
Reco Smart not only takes single photos or records video; it even has Photo Burst and Time Lapse to help you capture fun and exciting moments.
Parking monitor mode
Reco Smart can be set to detect movement in front of your vehicle. It will automatically start recording and will continue to do so until it detects no movement for one minute. It keeps a watchful eye on your vehicle even when you're not around.
Emergency file back-up
In the event of a collision, the built-in three-axis G-sensor triggers the emergency record function, saving the video and locking it down so it won't be inadvertently deleted. There is also a manual emergency record button that allows you to save videos should you witness an incident. Reco Smart can also be programmed to send out an emergency text message to a designated contact to call for help.
Compatible with a wide range of camera accessories
Reco Smart has a standard 58mm filter ring and 1/4-inch screw mount, so it's compatible with tripod mounts, filters, and other accessories. A waterproof Reco Smart camera housing is available as well.
One camera - double the excitement
Reco Smart is a small and versatile device that doubles both as an in-car dash cam and portable camera. Connect it with your smart device via Wi-Fi for real-time previews, or download and share the images and videos. With One-Shot, Time Lapse, and Photo Burst modes, Reco Smart is more than just a car cam, it's one that lets you capture life's little moments. -
You can record Full HD 1080p or 720p videos at a smooth 30 frames per second. Reco Smart features a Sony image sensor to give you high quality photos and videos with high color saturation and stunning clarity. -
Reco Smart has an f/1.8 aperture lens to help you record the tiniest details even in low-light environments. Wide Dynamic Range (WDR) technology improves image quality even under high-contrast lighting - so you're always guaranteed clear images and video. -
Reco Smart has a 150-degree wide-angle lens that gives you unobstructed views of the sides of your vehicle and the road ahead. It takes great videos and pictures once you're out of the car as well, with its wide-view lens allowing you to capture entire vistas in one frame. -
Reco Smart not only takes single photos or records video, it even has Photo Burst and Time Lapse to help you capture fun and exciting moments. -
Reco Smart can be set to detect movement in front of your vehicle. It will automatically start recording and will continue to do so until it detects no movement for one minute. It keeps a watchful eye on your vehicle even when you're not around. -
- Main Chip
- Ambarella
- Sensor
- SONY CMOS Sensor
- Aperture
- F1.8
- Wi-Fi Technology
- Wi-Fi 802.11b/g/n
- Collision Sensor
- G-sensor
- Battery
- 720 mAh
- Storage
- 8 GB
- 32 GB Class 10 micro SD card
- Resolution
- Full HD 1080P (1920x1080)
- HD 720P (1280x720)
- Video
- .mp4? AVC/H.264?
- GPS
- External GPS mouse (On selected models)
- External GPS sensor (On selected models)
- Power
- 5V/1A
- Package Content
- Car Camcorder
- Car Charger
- GPS mount holder
- Quick Start Guide
- Self-adhesive cable clips
- Micro SD card
- Filter
- Dual USB car charger
- 4 meters USB cable
Main Chip
- Ambarella
Sensor
- SONY CMOS Sensor
Aperture
- F1.8
Wi-Fi Technology
- Wi-Fi 802.11b/g/n
Collision Sensor
- G-sensor
- 720 mAh
Storage
- 8 GB
Resolution
Video
- .mp4? AVC/H.264?
GPS
- 5V/1A
Package Content
- Car Camcorder
- Car Charger
- GPS mount holder
- Quick Start Guide
- Micro SD card
- Filter
