Asus Radeon R7 240 OC 4GB DDR3 Low Profile Graphic Card
Quicklinx: C0W0WS00 Mfr#: R7240-OC-4GD3-L
  • AMD Radeon R7 240
R7 240 is the astonishing new graphics card from ASUS – that’s perfect for home-theater PCs (HTPCs) and multimedia setups! Equipped with the Radeon R7 240 graphics-processing unit (GPU), R7 240 includes some brilliant technologies that you can get only from ASUS.
R7 240 also comes with easy-to-use tuning tool, GPU Tweak. Use this to squeeze every last drop of performance out of the card and then stream your pumped-up on-screen action over the internet in real time!
  • Dust-proof fan
    Unique fan design dissipates heat efficiently while extending a graphic card's lifespan by 25% through increased dust and particle resistance.
  • Super alloy power
    Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
  • Stream online instantly
    GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
ASUS R7240-OC-4GD3-L - graphics card - Radeon R7 240 - 4 GB
Graphics card - low profile
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 240
4 GB DDR3
Core Clock
770 MHz
Boost Clock
820 MHz
Effective Memory Clock
1.8 GHz
Memory Interface
128-bit
Max Resolution
1920 x 1200
Interfaces Details
DVI-D , HDMI , VGA
API Supported
DirectX 11.2
2 cm x 15.9 cm x 11.1 cm
Microsoft Certification
Compatible with Windows 7
Bus Type
PCI Express 3.0 x16
Graphics Engine
AMD Radeon R7 240
Core Clock
770 MHz
Boost Clock
820 MHz
Max Resolution
1920 x 1200
Interfaces Details
DVI-D , HDMI , VGA
API Supported
DirectX 11.2
Native HDMI, AMD CrossFireX Technology, AMD PowerTune technology, Super Alloy Power technology, Dust-proof fan, AMD App Acceleration, AMD ZeroCore Power technology, GPU Tweak Streaming, HDCP
Size
4 GB
DDR3 SDRAM
Effective Clock Speed
1.8 GHz
Bus Width
128-bit
75 Watt
Low-profile bracket
Software Included
Drivers & Utilities, ASUS GPU Tweak
2 cm
15.9 cm
11.1 cm
C0W0 C2G 2m HDMI to DVI-D Digital Video Cable In Stock £6.92
