Asus ProArt PA90 Core i7-9700K 32GB 512GB SSD 1TB HDD Windows 10 Pro
Quicklinx: F5R4WS00 Mfr#: PA90-M7018ZN-OSS
Processor Type: Core i7
Operating System: Windows 10 Pro
Installed Memory: 32GB
Hard Drive Capacity: 1.512TB
Storage Type: SSD
  • Core i7
£2,207.88 ex VAT
£2,649.45 inc VAT
The workstation-class ASUS Mini PC ProArt series addresses the specific needs of creative professionals, delivering powerful and stable computing performance for computer-aided design (CAD) workflows for architecture, engineering and manufacturing, combined with an attractive, compact design that blends easily into any workspace. With Intel Core processors and NVIDIA Quadro graphics, ultrafast storage and connectivity, and a well-rounded feature set curated for professionals, ASUS Mini PC ProArt series delivers the power and reliability needed to fulfill any creative pursuit.
  • Professional NVIDIA Quadro graphics
    Professional designers need to work with precision and detail. Mini PC ProArt PA90 delivers on this requirement with NVIDIA Quadro graphics that provides accelerated performance to smoothly drive multiple ultra-high-resolution displays and speed up 3D rendering tasks. It's perfect for photo and video editing, computer-aided design (CAD) workflows for architecture, engineering and manufacturing as well as media and entertainment.
  • Liquid cooling for maximum performance and stability
    A high-performance cooling system is essential for heavy design workloads. With an all-in-one liquid CPU cooler, Mini PC ProArt PA90 unleashes the full performance of the CPU, while delivering consistently quiet and stable operation, helping to avoid slowdowns, application crashes and even unexpected shut downs while working on your projects. Its innovative cooling system also automatically extends the PC's top cover when the CPU is at full load to maximize airflow for optimal performance.
  • Quiet, energy-efficient design
    With its liquid CPU cooler, Mini PC ProArt PA90 is incredibly quiet, producing only 25.5dB at idle and 32dB at full load, so you can concentrate on your work without noise. It is also energy efficient. Eco-friendly ASUS mini PCs are recipients of some of the PC industry's highest environmental certifications, including Energy Star.
  • Ultrafast Thunderbolt 3 connectivity
    It is common for professional designers and content creators to transfer large files to external storage devices and connect to multiple product and data devices simultaneously. Mini PC ProArt PA90 easily supports these usage scenarios with Thunderbolt 3 connectivity, which delivers ultrafast data transfer speeds of up to 40Gbps - fast enough to transfer a full 4K movie in less than 30 seconds. Thunderbolt 3 also supports daisy-chaining multiple devices via a single port, and the small and reversible USB-C connector makes connecting docks, external drives and displays fast and easy.
  • Tested for perfection
    ASUS mini PCs undergo rigorous noise, vibration, drop, and thermal shock tests to ensure they meet exacting ASUS standards and exceed industry requirements. Be confident that your ASUS mini PC can cope with extreme conditions, ranging from dry -40 °C temperatures, to humid and hot environments exceeding 60 °C for long periods of time.
ASUS ProArt PA90 M7018ZN - mini PC - Core i7 9700K - 32 GB - 1.512 TB
Personal computer - mini PC
1 x Intel Core i7 (9th Gen) 9700K (8-core)
RAM
32 GB (installed) / 64 GB (max) DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
1 x SSD 512 GB - PCI Express - M.2
Hard Drive (2nd)
1 x 1 TB - Serial ATA - 7200 rpm
Optical Storage
No optical drive
Graphics Controller
NVIDIA Quadro P4000
Video Memory
8 GB
GigE, 802.11ac, Bluetooth 5.0
OS Provided
Windows 10 Pro
Midnight blue
17.6 cm x 17.6 cm x 3.65 cm
5.8 kg
Environmental Standards
ENERGY STAR Qualified
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Mini PC
Built-in Devices
Liquid cooling system
Embedded Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Midnight blue
Processor / Chipset
CPU
Number of Cores
8-core
CPU Qty
1
Max CPU Qty
1
Chipset Type
Intel Z390
RAM
Installed Size
32 GB / 64 GB (max)
DDR4 SDRAM
Effective Memory Speed
2666 MHz
Rated Memory Speed
2666 MHz
SO-DIMM 260-pin
Slots
4 (Total)
Hard Drive
SSD - M.2
1 x 512 GB
Interface Type
PCI Express
Hard Drive (2nd)
HDD
Interface Class
Serial ATA
1 x 1 TB
Spindle Speed
7200 rpm
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
NVIDIA Quadro P4000
Video Memory
8 GB
Video Interfaces
DisplayPort
Wireless LAN Supported
Wireless NIC
Intel Wireless-AC 9560
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11ac, Bluetooth 5.0
Wi-Fi CERTIFIED
Bays
1 (total) / 0 (free) x internal 2.5"
Slots
2 (total) / 1 (free) x M.2 Card
4 x DisplayPort , 4 x USB 3.1 Gen 2 (2 front, 2 rear) , 1 x LAN (Gigabit Ethernet) , 1 x headphones (1 in front) , 1 x microphone (1 in front) , 2 x Thunderbolt 3/USB-C 3.1 Gen 2 , 1 x audio line-out
2 x power adapters (180W + 230W)
UL, VCCI, C-Tick, BSMI, CB, CCC, FCC
Power adapter
Operating System / Software
OS Provided
Windows 10 Pro
ENERGY STAR Certified
17.6 cm
17.6 cm
3.65 cm
5.8 kg
Sound Emission
25.5 dB
Asus ProArt PA90 Core i7-9700K 32GB 512GB SSD 1TB HDD Windows 10 Pro Bundle deal on Asus ProArt PA90 Core i7-9700K 32GB 512GB SSD 1TB HDD Windows 10 Pro
£2,307.05
Storage Type: SSD
Processor Model: I7-9700K
Type: Personal computer
Case Style: Ultra small form factor
Display: not included
Optical Storage: None
Brand: Asus
Price Range Ex VAT: 1500+
