ASUS ProArt GeForce RTX 4070 Ti Super 16GB OC Edition Graphics Card
Quicklinx: HVGHWS00 Mfr#: PROART-RTX4070TIS-O16G
The ASUS ProArt GeForce RTX 4070 Ti Super 16GB enhances professional graphics performance, combining NVIDIA's Ada Lovelace GPU technology with a robust 16 GB GDDR6X memory. Designed for creators and professionals, this video card supports high resolutions up to 7680 x 4320 across multiple displays, making it suitable for detailed design work, 3D rendering, and immersive gaming experiences.
With its triple fan design, Axial-tech Fan Design, and Dual ball Bearing Fans, it ensures efficient cooling and reliability during intensive tasks. The inclusion of 3rd gen Ray Tracing Cores and 4th gen Tensor Cores enhances realism and performance in AI-driven processes and graphics rendering. Additionally, the card's comprehensive connectivity options, including HDMI and DisplayPort, offer flexibility for various display setups. The ASUS ProArt GeForce RTX 4070 Ti Super 16GB is a comprehensive solution for professionals seeking to enhance their visual computing power.
  • Enhanced cooling
    The ASUS ProArt GeForce RTX 4070 Ti Super 16GB features an Axial-tech Fan Design, Dual ball Bearing Fans, and a triple fan Design, ensuring efficient cooling performance for sustained high-end graphics processing.
  • High-capacity memory
    Equipped with 16 GB of GDDR6X SDRAM on a 256-bit bus and a memory speed of 21 Gbps, this video card provides ample bandwidth and speed for demanding applications and gaming.
  • Advanced graphics technology
    Leveraging NVIDIA Ada Lovelace GPU technology, 3rd gen Ray Tracing Cores, and 4th gen Tensor Cores, the card delivers enhanced realism and performance in rendering and AI-driven tasks.
  • High-definition support
    With support for up to 4 monitors and a maximum external resolution of 7680 x 4320, users can experience high-definition visuals across multiple displays.
  • Comprehensive connectivity
    Featuring three HDMI and DisplayPort interfaces, along with compliance to DisplayPort 1.4a and HDCP 2.3 standards, this graphics card offers versatile connectivity options for various display setups.
ASUS ProArt GeForce RTX 4070 Ti Super 16GB - OC Edition - graphics card - GeForce RTX 4070 Ti Super - 16 GB
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
NVIDIA GeForce RTX 4070 Ti SUPER - up to
16 GB GDDR6X
Memory Speed
21 Gbps
Boost Clock
2640 MHz
Boost Clock (OC)
2670 MHz
CUDA Cores
8448
Memory Interface
256-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
HDMI , 3 x DisplayPort
API Supported
OpenGL 4.6
5 cm x 30 cm x 12 cm
Graphics card
Bus Type
PCI Express 4.0
Graphics Engine
Boost Clock
2640 MHz
Boost Clock (OC)
2670 MHz
CUDA Cores
8448
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
Triple Fan Design, 2.5-slot Fan Cooler, NVIDIA Ada Lovelace GPU technology, 4th gen Tensor Cores, 3rd gen Ray Tracing Cores, Axial-tech Fan Design, Dual ball Bearing Fans, AUTO-EXTREME technology, NVIDIA DLSS 3, NVIDIA Reflex, NVIDIA RTX Video Super Resolution, Nvidia Broadcast, Nvidia Studio, reverse airflow, 0dB Technology, Premium Digital Power Design, vented backplate, Optical Flow Accelerator, Resizable BAR, HDCP
Size
16 GB
GDDR6X SDRAM
Memory Speed
21 Gbps
Bus Width
256-bit
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector
Collection card, thank you card, 16-pin to 2x 8-pin cable adapter, hook-and-loop fastener, ProArt graphics card holder
Software Included
ASUS GPU Tweak III, ASUS Quantumcloud, NVIDIA GeForce Experience, Adobe Creative Cloud (3 months membership)
DisplayPort 1.4a, HDCP 2.3
5 cm
30 cm
12 cm
