Asus Pro Essential P550LA Intel Core i5-3317U 4GB 500GB 15.6" Windows 7 Professional
Quicklinx: 9QVDWS00 Mfr#: PU500CA-XO010G
  • Core i5
  • Microsoft Windows 7 Professional 64-bit Edition
  • IEEE 802.11n
  • Bluetooth 4.0
ASUSPRO PU Essential series business notebook is budget-friendly and extremely reliable. Specially designed for SMBs, it delivers uncompromised durability and security in a business-focused package. Designed primarily for growing enterprises that may lack a fully-managed IT environment, it helps improve productivity and boost reliability. It is the perfect choice for smart up-and-coming businesses on the path to success.
ASUSPRO PU550 has a built-in hardware module on the motherboard that supports Wake-on-LAN (WOL). This allows a computer to be powered on or woken from sleep mode by a network message via LAN or WAN connections. This feature is invaluable for remote PC maintenance and support.
  • Subtly stylish
    The ASUSPRO PU series uses a one-piece build to create a professional yet subtle look. The design simplicity extends to the underside, with no unnecessary clutter, and a premium look and feel is achieved by the use of a stylish dark brushed-metal finish.
  • True-comfort keyboard and dedicated numeric keypad increase productivity
    Notebook keyboards are of great concern in the workplace, as they are essential for comfort and productivity. ASUS engineers have fine-tuned the PU series keyboard, providing optimum key feel and long key travel to maintain comfort during long hours of work. The keyboard also provides a full dedicated numeric keypad, complete with navigation keys, to increase efficiency for data entry or document navigation.
  • Large multi-gesture touchpad
    With gesture support, it effectively replaces the mouse, offering an alternative and intuitive input option. Multi-touch input allows effortless accuracy without a mouse, including two-finger web page scroll, zooming and rotating images, plus three-finger tapping to mimic a right-click. Workflow can be streamlined with gesture control, especially multi-step tasks such as presentations and research projects.
  • Anti-glare display for comfortable viewing
    The matte screen surface used in ASUSPRO notebooks prevents unwanted reflections, reducing eye fatigue. It also prevents unsightly fingerprint smudges from spoiling displayed content such as presentations. Ergonomically-angled and textured palm rest areas provide a comfortable and solid feel for optimum productivity.
  • Anti-shock hard drive keeps data safe
    ASUSPRO PU Essential series notebook offers increased hard drive protection, with damage-absorbing sponge cushions designed to protect the hard disk against shocks and drops during transportation. Additionally, the hard disk features a complete protection mechanism consisting of G-sensor hardware and software that actively protects against imminent impacts in order to help keep data safe and secure. This system uses a 3D digital accelerometer with three levels of sensitivity: off, normal, and high. The latter is activated by default, and impact detection remains on at all times.
  • Wake-on-LAN (WOL) allows PCs to be turned on by a simple network message
ASUSPRO ESSENTIAL PU500CA-XO010G - 15.6" - Intel Core i5 3317U - 4 GB RAM - 500 GB HDD
Notebook
Operating System
Win 7 Pro 64-bit + Windows 8 Pro 64-bit Licence
Intel Core i5 (3rd Gen) 3317U / 1.7 GHz (2.6 GHz) / 3 MB Cache
4 GB DDR3 (1 x 2 GB + 2 GB (soldered))
Storage
500 GB HDD / 5400 rpm
Display
15.6" LED backlight 1366 x 768 / HD
Graphics
Intel HD Graphics 4000
Numeric Keypad
Integrated Webcam
802.11a/b/g/n, Bluetooth 4.0, Gigabit Ethernet
3-cell
G-sensor
Security
Fingerprint reader
38.3 cm x 25.67 cm x 2.25 cm
1.96 kg
Environmental Standards
ENERGY STAR Qualified EPEAT Gold
Notebook
Operating System
Microsoft Windows 7 Professional 64-bit Edition + Windows 8 Pro 64-bit Licence
Processor / Chipset
CPU
Max Turbo Speed
2.6 GHz
Number of Cores
Dual-Core
Cache
3 MB
64-bit Computing
Chipset
Mobile Intel HM77 Express
RAM
4 GB (1 x 2 GB + 2 GB (soldered))
Max RAM Supported
6 GB
DDR3 SDRAM
Speed
1600 MHz
SO-DIMM 204-pin
Slots Qty
1
Empty Slots
0
Storage
Main Storage
500 GB HDD SATA 3Gb/s / 5400 rpm
Display
15.6"
LCD Backlight Technology
LED backlight
Resolution
1366 x 768 (HD)
Widescreen
Anti-glare, WideView
Audio & Video
Graphics Processor
Camera
Sound
Stereo speakers, microphone
Audio Features
Output: ASUS SonicMaster Lite
Input
Keyboard, touchpad
Numeric Keypad
Multi-gesture touch pad, spill-resistant
Communications
Wireless
Network Interface
Gigabit Ethernet
Wake-on-LAN (WOL)
3-cell lithium polymer
44 Wh
AC Adapter
Input
Output
65 Watt, 19 V
Connections & Expansion
Headphone/microphone combo jack , VGA , USB 3.0 , 2 x USB 2.0 , LAN , HDMI
Memory Card Reader
2 in 1 (SD Card, MultiMediaCard)
Integrated Options
G-sensor
Security
Fingerprint reader
Security lock slot (cable lock sold separately), system password, hard drive password, Intel Anti-Theft Technology (iAT), ASUS Secure Delete, anti-shock hard drive, ASUS USB Charger+, Intel Small Business Advantage
Power adapter
UL, TUV, C-Tick, BSMI, CB, CCC, FCC, RoHS, WEEE, A-Tick, GOST-R, CECP, iDA, ErP 2013
1.96 kg
Sustainability Information
EPEAT Compliant
EPEAT Gold
ENERGY STAR Certified
