Asus PRIME GeForce RTX 5070 12GB GDDR7 - PRIME-RTX5070-O12G
Quicklinx: J3N1WS00 Mfr#: 90YV0M10-M0NA00
Graphics Processor Manufacturer: NVIDIA
Graphics Processor: NVIDIA GeForce RTX 5070
Interface: PCI Express 5.0
10 left in stock
£519.16 ex VAT
£622.99 inc VAT
Express delivery Order within the next 19 hours for delivery on Wednesday
Experience Primal performance with the Prime GeForce RTX 5070, an SFF-ready graphics card featuring a 2.5-slot design for expansive compatibility, enhanced by a triple-fan setup for supreme airflow design for supreme cooling.
  • Robust video memory
    With 12 GB of GDDR7 SDRAM and a memory speed of 28 Gbps, this graphics card ensures swift data processing and a seamless gaming experience.
  • Advanced performance capabilities
    The graphics card features 6144 CUDA Cores and achieves up to 2557 MHz boost clock speed, offering substantial graphical processing power.
  • Versatile connectivity options
    Featuring three DisplayPort and one HDMI outputs, this card offers flexible connectivity to multiple monitors, enhancing productivity and gaming immersion.
  • Enhanced cooling technology
    The card comes with a 2.5-slot Fan Cooler and Dual Ball Bearing Fans, ensuring effective thermal management while maintaining quiet operation.
  • Integrated NVIDIA technologies
    Includes NVIDIA DLSS 4, Reflex 2, and Broadcast features, maximizing performance and enhancing the user experience for gamers and content creators.
ASUS PRIME GeForce RTX 5070 12GB - OC Edition - graphics card - GeForce RTX 5070 - 12 GB
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
NVIDIA GeForce RTX 5070 - up to 1005 TOPS
12 GB GDDR7
Memory Speed
28 Gbps
Boost Clock
2557 MHz
Boost Clock (OC)
2587 MHz
CUDA Cores
6144
Memory Interface
192-bit
Max Resolution
7680 x 4320
Max Monitors Supported
4
Interfaces Details
3 x DisplayPort , HDMI
API Supported
OpenGL 4.6
5 cm x 30.4 cm x 12.6 cm
Graphics card
Bus Type
PCI Express 5.0
Graphics Engine
Boost Clock
2557 MHz
Boost Clock (OC)
2587 MHz
CUDA Cores
6144
VR Ready
Max Resolution
7680 x 4320
4
Interfaces Details
API Supported
OpenGL 4.6
5th gen Tensor Cores, 4th gen Ray Tracing Cores, NVIDIA DLSS 4, NVIDIA Reflex 2, NVIDIA Avatar Cloud Engine (ACE), NVIDIA G-Sync ready, Nvidia Studio, NVIDIA Multi Frame Generation, NVIDIA Frame Warp, Nvidia Broadcast, 9th Gen NVIDIA Encoder, 2.5-slot Fan Cooler, 0dB Technology, Dual ball Bearing Fans, vented backplate, MaxContact technology, phase-change thermal pad, ASUS GPU Guard, protection plate, stainless steel mounting bracket, Dual Bios, AUTO-EXTREME technology, NVIDIA GeForce SFF-Ready, HDCP
Size
12 GB
GDDR7 SDRAM
Memory Speed
28 Gbps
Bus Width
192-bit
Performance
NPU Performance Up To (TOPS)
1005 TOPS
Required Power Supply
750 W
Additional Requirements
16 pin PCI Express power connector, 2 adjacent PCI slots
2x8-pin to 12VHPWR cable, hook-and-loop fastener, thank you card, graphics card support bracket
Software Included
ASUS GPU Tweak III, MuseTree
HDCP 2.3, DisplayPort 2.1b
5 cm
30.4 cm
12.6 cm
Brand: Asus
Price Range Ex VAT: £500 - £750
Stock Status: While stocks last
Stock Status: Clearance
