Asus PN41 BP045ZD Mini PC Pentium Silver N6000 4GB 128GB Win 10 Pro
Quicklinx: GDLPWS00 Mfr#: PN41-BP045ZD-OSS
  • IEEE 802.11n
ASUS Mini PC PN41 is an ultracompact computer that delivers powerful performance for a wide variety of home and business applications. Featuring the latest 11th Gen Intel mobile processor with Intel UHD Graphics, plus support for high-speed 2933 MHz DDR4 memory, Mini PC PN41 is ready for everyday multitask computing, yet its diminutive size makes it well-suited for applications where traditional PCs won't fit - from digital signage to small home-office setups.
  • Performance
    ASUS Mini PC PN41 is powered by the latest 11 Gen Intel mobile processor. Compared with traditional same-tier mobile processors, these Intel mobile processors deliver performance improvements of up to 36.45% for single-thread computing, up to 31.8% for multi-thread computing, and up to a 32% lift for the entire system - ensuring smooth operations for everything you do.
  • Powerful graphics
    ASUS Mini PC PN41 delivers class-leading graphics performance with Integrated Intel UHD Graphics. In fact, compared to previous-generation mobile processors, PN41's graphics performance in 3DMark11 v1.0.132 has increased by over 90% - and by an impressive 120% in 3D Mark Fire Strike.
  • Hyper-fast 2.5 Gbps networking
    ASUS Mini PC PN41 is engineered with onboard networking that runs at up to 2.5 Gbps - or 2.5X faster than even gigabit Ethernet. This hyper-fast LAN support provides seriously speedy networking that makes everyday tasks smoother and more efficient.
  • Power Delivery input
    With support for USB Power Delivery input, PN41 can receive power from a supported display or other device via a cable, eliminating the need for separate power adapters to keep your workspace uncluttered.
  • Triple-display support
    ASUS Mini PC PN41 supports up to three displays with 4K UHD resolution through HDMI, DisplayPort over USB-C and a user-configurable port, extending your workspace across multiple monitors for more efficient and comfortable productivity experiences.
  • Diverse applications
    With support for up to three displays and a fanless design, ASUS Mini PC PN41 is versatile enough for all sorts of commercial applications - from digital signage in shops, exhibition halls and retail stores, to interactive kiosks, home working and online learning. PN41 is also compact and powerful, making it the perfect choice for conference rooms and offices, including home working, or even for remote learning. With built-in Power Delivery input and onboard 2.5 Gbps Ethernet, PN41 makes setup and communication swift, smooth and efficient.
  • Modern, space-saving chassis
    With a modern design featuring sleek lines and a stylish, brushed finish, ASUS Mini PC PN41 easily blends into home, office and retail environments. Compact and lightweight at 115 x 115 x 49 mm, and with a mere 0.62-liter volume, it can be placed almost anywhere and even attached to the back of a display with a VESA mount for a space-saving, all-in-one solution.
  • Fanless chassis and a dedicated SSD heatsink
    ASUS Mini PC PN41 has a fanless design to support a 6-watt CPU, so it's ideal for industrial applications where reliability, durability and low noise levels are paramount. It also has a dedicated heatsink to cool the SSD, keeping the average temperature of the drive at a mere 50° C.
  • High-speed connectivity
    ASUS Mini PC PN41 provides comprehensive connectivity with multiple ports, including a USB 3.2 Gen 2 Type-C port with DisplayPort 1.4 support and a configurable port to support legacy devices, additional displays or multiple network connections. PN41 also provides Power Delivery input for setup simplicity and easier cable management. The configurable port offers the option of VGA, DisplayPort, COM or LAN connectivity, making it ideal for a variety of monitor types or legacy devices - from barcode scanners to receipt printers. With such port versatility, PN41 is perfect for a wide range of business scenarios, including signage, point-of-sale (POS) systems and intelligent vending machines.
  • Seamless media experience
    ASUS Mini PC PN41 supports HDMI CEC and has a built-in IR sensor, allowing you to manage almost all your media devices, from audio and video playback to menu navigation, via a single remote control. PN41 also sets the standard for the best Windows 10 experience, with a dual-microphone array that supports Microsoft Cortana - the personal digital assistant that helps you get things done easily. The array mic ensures accurate voice control, even in noisy conditions.
  • Reactive cooling
    To ensure stable performance, ASUS Mini PN41 has dedicated thermal monitoring for the SSD. It also has numerous preset cooling policies to cater to a diverse variety of scenarios.
  • Reduce environmental impact while lowering operating costs
    ASUS Mini PC PN41 has an energy-efficient design that reduces environmental impact while helping to lower operating costs. Eco-friendly ASUS Mini PCs are recipients of some of the industry's highest environmental certifications, including ENERGY STAR . Specifically, PN41 consumes as little as 3.69 watts at idle. It is also whisper-quiet, with the fan-cooled model generating just 34.1 dB(A) at full load. Its fanless sibling generates a mere 23.5 dB(A) at full load.
ASUS Mini PC PN41 BP045ZD - mini PC Pentium Silver N6000 1.1 GHz - 4 GB - SSD 128 GB
Personal computer - mini PC
Intel Pentium Silver N6000 / 1.1 GHz (up to 3.3 GHz, (Quad-Core)
RAM
4 GB DDR4 SDRAM
Storage Controller
SATA (SATA 6Gb/s)
Hard Drive
SSD 128 GB - PCI Express 3.0 x4 - M.2
Optical Storage
No optical drive
Graphics Controller
Intel UHD Graphics
1GbE, 802.11a, 802.11b/g/n, Wi-Fi 5, 802.11ax, Bluetooth 5.2
OS Provided
Windows 10 Pro
Limited warranty - 3 years - on-site
Personal computer
Product Form Factor
Mini PC
Embedded Security
Firmware Trusted Platform Module (TPM 2.0) Security Chip
Processor / Chipset
CPU
Clock Speed
1.1 GHz
Max Turbo Speed
3.3 GHz
Number of Cores
Quad-Core
CPU Qty
1
Max CPU Qty
1
RAM
Installed Size
4 GB
DDR4 SDRAM
Effective Memory Speed
2933 MHz
Rated Memory Speed
2933 MHz
Configuration Features
1 x 4 GB
Hard Drive
SSD - M.2
1 x 128 GB
Interface Type
PCI Express 3.0 x4
Storage Controller
1 x SATA
Controller Interface Type
SATA 6Gb/s
Optical Storage
No optical drive
Monitor
Monitor Type
None.
Graphics Controller
Graphics Processor
Intel UHD Graphics
Video Interfaces
HDMI, DisplayPort
Wireless LAN Supported
Wireless NIC
Intel Wi-Fi 6 AX 201
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, 802.11ax, Bluetooth 5.2
Bays
1 (total) / 1 (free) x internal 2.5"
1 x HDMI , 1 x LAN (Gigabit Ethernet) , 1 x DisplayPort , 1 x headphones/microphone (1 in front) , 3 x USB 3.1 (1 front, 2 rear) , 1 x USB-C 3.1 (1 in front) , 1 x DisplayPort/USB-C 3.1
VESA mounting kit
VESA Mounting Interface
Power adapter
Operating System / Software
OS Provided
Windows 10 Pro
