Asus PCE-N10 Wireless-N150 PCI Express Adapter
Quicklinx: 95J4WS00 Mfr#: PCE-N10
Wired / Wireless: Wireless
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Form Factor: Plug-in card
Compatibility: PC
Type: Network adapter
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
£16.75 ex VAT
£20.10 inc VAT
Easily Turn Your Desktop Wireless
The ASUS PCE-N10 is designed to provide complete end-to-end wireless performance from the server or server backbone to the switch infrastructure and down through to the desktop with the PCI Express connector. The PCE-N10 Wireless-N PCI Express Adapter provides wide compatibility, fitting with any standard PCI Express slot, x1, x2, x8, or x16. Compared with standard PCI network cards, it offers increased bandwidth, reliability and more functionality, allowing you to enjoy a fast and advanced connection, such as downloading, making internet calls and video streaming.
Enhanced Security
Supports 64/128-bit WEP,WPA2-PSK,WPA-PSK,WPS security.
WPS (Wi-Fi Protected Setup)
For quickly setting up a secure wireless connection, install the utility from the Support CD, then press the hardware WPS button on the PCE-N10 and click "next". Press the hardware WPS button on the router you would like to connect to, and that's it! After the utility finishes the setup procedure, the wireless connection is done!
Software AP Mode
Software AP mode allows the WLAN card to act as a virtual access point. The computer needs to be connected to a wired network using an Ethernet connection in order to provide network access to WLAN client.
  • WPS (Wi-Fi Protected Setup) button
    For quickly setting up a secure wireless connection. Press the hardware WPS button on PCE-N10 about 3 seconds, then press the WPS button on router as well. Either you can choose to use software WPS, enabling the WPS utility in the WPS wizard interface. And finish the setup with 3 steps.
  • Software AP
ASUS PCE-N10 - network adapter
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
12.1 cm x 8.8 cm x 2.2 cm
56 g
802.11b/g/n
Data Transfer Rate
150 Mbps
Frequency Band
2.4 GHz
Microsoft Windows Vista (32/64 bits), Ubuntu, Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits)
Network adapter
PCI Express
Wireless
Spread Spectrum Method
OFDM
Data Transfer Rate
150 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, OFDM
Frequency Band
2.4 GHz
Software access point, Wi-Fi Protected Setup (WPS)
Aerial
Antenna
External detachable
Antenna Qty
1
1 x aerial - R-SMA
Compatible Slots
1 x PCI Express
Low-profile bracket
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
C-Tick, IC, FCC
Software Included
Drivers & Utilities
12.1 cm
8.8 cm
2.2 cm
56 g
45 °C
5 - 95% (non-condensing)
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Brand: Asus
Price Range Ex VAT: 0 - 50
