Asus PB328Q 32" 2560x1440 DVI VGA HDMI Monitor
Quicklinx: CW2DWS00 Mfr#: PB328Q
Diagonal Size: 32in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI, VGA (HD-15)
£456.02 ex VAT
£547.22 inc VAT
WQHD super narrow bezel professional monitor with wide viewing angle. Ultra-wide viewing-angle eliminates color shift for excellent visual performance. Provides 100% sRGB color space with WQHD resolution. Eye care features including Flicker free, Low Blue Light, anti-glare & ergonomic adjustment stand. User-friendly design: super narrow bezel, 6-axls color adjustment, 5-way OSD navigation joystick, Quick release stand, QuickFit and SplendidPlus functions.
ASUS PB328Q - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class A
Energy Consumption per Year
52 kWh
Power Consumption (On mode)
36 W
5-way joystick, USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
QHD WQHD 2560 x 1440
Brightness
300 cd/m²
Contrast Ratio
100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
1.074 billion colours (10-bit)
Input Connectors
HDMI, DVI-D, VGA, DisplayPort
Speakers
Integrated
Display Position Adjustments
Screen Coating
Anti-glare
73.5 cm x 24.2 cm x 62.5 cm
11.8 kg
Environmental Standards
TCO Certified Displays 7, ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, RCM
Display Type
Energy Class
Class A
52 kWh
36 W
Diagonal Size
32"
Built-in Devices
USB 3.0 hub
Panel Type
VA
Aspect Ratio
16:9
Native Resolution
Brightness
300 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Vertical Refresh Rate
49 - 76 Hz
Horizontal Refresh Rate
30 - 83 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Controls & Adjustments
Brightness, gamma correction, input select, blue reduction
Picture in picture, picture by picture, ASUS Smart Contrast Ratio (ASCR), ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, super narrow frame, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, 12-bit lookup table
73.5 cm x 24.2 cm x 62.5 cm - with stand
11.8 kg
Audio
Speakers - stereo - integrated
Output Power / Channel
3 Watt
Input
5-way joystick
DVI-D (dual link) , VGA , DisplayPort , HDMI , Audio line-in , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B)
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), quick release mechanism
1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable , 1 x HDMI cable
Security Slot Type
Kensington security slot
Power Supply
Internal
32.26 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 73.4 cm - depth: 6.685 cm - height: 43.1 cm , With stand - width: 73.5 cm - depth: 24.2 cm - height: 62.5 cm - weight: 11.8 kg
Shipping Width
84.7 cm
Shipping Depth
35 cm
Shipping Height
55.2 cm
Shipping Weight
16.5 kg
TCO Certified
ENERGY STAR Certified
Asus PB328Q 32 Bundle deal on Asus PB328Q 32" 2560x1440 DVI VGA HDMI Monitor
£555.19
Diagonal Size: 32in
Response Time: 4ms
Interfaces: DVI
Interfaces: HDMI
Interfaces: VGA (HD-15)
Brand: Asus
Price Range Ex VAT: 300 - 500
