WQHD super narrow bezel professional monitor with wide viewing angle. Ultra-wide viewing-angle eliminates color shift for excellent visual performance. Provides 100% sRGB color space with WQHD resolution. Eye care features including Flicker free, Low Blue Light, anti-glare & ergonomic adjustment stand. User-friendly design: super narrow bezel, 6-axls color adjustment, 5-way OSD navigation joystick, Quick release stand, QuickFit and SplendidPlus functions.
- ASUS PB328Q - LED monitor - 32"
- LED-backlit LCD monitor - 32"
- Energy Class
- Class A
- Energy Consumption per Year
- 52 kWh
- Power Consumption (On mode)
- 36 W
- 5-way joystick, USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440
- Brightness
- 300 cd/m²
- Contrast Ratio
- 100000000:1 (dynamic)
- Response Time
- 4 ms (grey-to-grey)
- Colour Support
- 1.074 billion colours (10-bit)
- Input Connectors
- HDMI, DVI-D, VGA, DisplayPort
- Speakers
- Integrated
- Height, pivot (rotation), swivel, tilt
- Screen Coating
- Anti-glare
- Voltage
- AC 120/230 V (50/60 Hz)
- Black
- 73.5 cm x 24.2 cm x 62.5 cm
- 11.8 kg
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, KC, RCM
- Display Type
- Energy Class
- Class A
- 52 kWh
- Diagonal Size
- 32"
- Built-in Devices
- USB 3.0 hub
- Panel Type
- VA
- Aspect Ratio
- 16:9
- Native Resolution
- WQHD 2560 x 1440
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Response Time
- Vertical Refresh Rate
- 49 - 76 Hz
- Horizontal Refresh Rate
- 30 - 83 kHz
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Screen Coating
- Anti-glare
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Brightness, gamma correction, input select, blue reduction
- Picture in picture, picture by picture, ASUS Smart Contrast Ratio (ASCR), ASUS QuickFit Virtual Scale, ASUS VividPixel Technology, super narrow frame, Low Blue Light Mode, Flicker Free technology, ASUS SplendidPlus Video Intelligence Technology, 12-bit lookup table
- Black
- 73.5 cm x 24.2 cm x 62.5 cm - with stand
- 11.8 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
Input
- 5-way joystick
- DVI-D (dual link) , VGA , DisplayPort , HDMI , Audio line-in , 4 x USB 3.0 downstream (Type A) , USB 3.0 upstream (Type B)
Mechanical
- Tilt Angle
- -5/+20
- Swivel Angle
- 120
- Rotation Angle
- 90
- Height Adjustment
- 150 mm
- VESA Mounting Interface
- 100 x 100 mm
- Security lock slot (cable lock sold separately), quick release mechanism
- Cables Included
- 1 x DVI cable , 1 x audio cable , 1 x DisplayPort cable , 1 x HDMI cable
- Security Slot Type
- Kensington security slot
- Power Supply
- Internal
- Input Voltage
- 36 W
- Power Consumption (Typical)
- 32.26 Watt
- 0 Watt
- On / Off Switch
- Dimensions & Weight Details
- Without stand - width: 73.4 cm - depth: 6.685 cm - height: 43.1 cm , With stand - width: 73.5 cm - depth: 24.2 cm - height: 62.5 cm - weight: 11.8 kg
- Shipping Width
- 84.7 cm
- Shipping Depth
- 35 cm
- Shipping Height
- 55.2 cm
- Shipping Weight
- 16.5 kg
Sustainability Information
- ENERGY STAR Certified
