Asus PA32UC-K 32" 3840x2160 5ms HDMI DP LED Monitor
Quicklinx: DMRKWS00 Mfr#: PA32UC-K
Diagonal Size: 32in
Max Resolution: 3840 x 2160
Response Time: 5ms
Speakers: Speaker(s)
Interfaces: DisplayPort, HDMI, Thunderbolt 3, USB + 1 more
£1,719.91 ex VAT
£2,063.89 inc VAT
ProArt PA32UC brings onscreen realism to another level. Its Ultra HD Premium-certified 4K IPS panel produces up to 1000 nits of brightness and delivers Rec. 2020, Adobe RGB, DCI-P3 and sRGB color space, providing a lifelike HDR experience that is ideal for advanced video editing. ProArt PA32UC is factory pre-calibrated and it features ProArt calibration technology to ensure color accuracy with a ?E value below 2. Certified for Windows and Mac OS, it's ideal for graphic designers, photographers and professional content creators.
ASUS ProArt PA32UC-K - LED monitor - 32"
LED-backlit LCD monitor - 32"
Energy Class
Class B
Energy Consumption per Year
67 kWh
Power Consumption (On mode)
46 W
5-way joystick, USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
4K UHD (2160p) 3840 x 2160 (DisplayPort: 60Hz, HDMI 65 Hz, Thunderbolt 3: 60Hz)
Pixel Pitch
0.1845 mm
Brightness
1000 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
5 ms (grey-to-grey)
Colour Support
1.07 billion colours
Input Connectors
4xHDMI, DisplayPort, Thunderbolt 3
Display Position Adjustments
Screen Coating
Anti-glare
Grey
72.7 cm x 22.9 cm x 60 cm
11.4 kg
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, ISO 9241-307, KCC, WEEE, PSE Mark, ICES, J-MOSS, E-Standby, UkrSEPRO, KC, ERP, RCM, TUV Rheinland Low Blue Light Certification, CU, TUV Rheinland Flicker Free Certification
3-year warranty
Display Type
Energy Class
Class B
67 kWh
46 W
Diagonal Size
32"
Built-in Devices
USB 3.0/USB-C hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.1845 mm
Brightness
1000 cd/m²
Contrast Ratio
Colour Support
Response Time
5 ms (grey-to-grey)
Vertical Refresh Rate
29 - 65 Hz
Horizontal Refresh Rate
109 - 142 kHz
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
LED backlight
Picture in picture, picture by picture, ErgoDesign, HDCP, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, WideView, ASUS QuickFit Virtual Scale, 100% sRGB colour gamut, 14-bit lookup table, Flicker Free technology, ASUS EyeCare Technology, 6-axis colour adjustment, ASUS ProArt Calibration technology, Bluelight Filter, Hardware Calibration Ready, DCI-P3 95% colour gamut, USB-C power delivery up to 60 W, 85% Rec 2020 colour gamut
Grey
72.7 cm x 22.9 cm x 60 cm - with stand
11.4 kg
Audio
Speakers - stereo
Output Power / Channel
3 Watt
Input
5-way joystick
Thunderbolt 3 / USB-C , Thunderbolt 3 / USB-C output , 4 x HDMI , DisplayPort , Headphones , USB 3.0 downstream with Power Delivery , 2 x USB 3.0 downstream , USB 3.0 upstream
Mechanical
Tilt Angle
-5/+23
Swivel Angle
120
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA interface support
1 x HDMI cable , 1 x DisplayPort cable , 1 x USB cable , 1 x Thunderbolt 3 / USB-C cable
56.84 Watt
Power Consumption (Off Mode)
0 Watt
On / Off Switch
Dimensions & Weight Details
Without stand - width: 72.7 cm - depth: 6.9 cm - height: 42.6 cm - weight: 7.8 kg
Shipping Width
91.3 cm
Shipping Depth
52.1 cm
Shipping Height
36.5 cm
Shipping Weight
16.7 kg
ENERGY STAR Certified
Limited warranty - 3 years , Limited warranty - LCD panel - 3 years
Asus PA32UC-K 32 Bundle deal on Asus PA32UC-K 32" 3840x2160 5ms HDMI DP LED Monitor
£1,819.08
Diagonal Size: 32in
Response Time: 5ms
Interfaces: HDMI
Interfaces: Thunderbolt 3
Interfaces: USB
Interfaces: USB-C
Brand: Asus
Price Range Ex VAT: 1500+
