ASUS P8Z77-V Premium: The First Intel Certified and Windows Optimized Motherboard to Feature Thunderbolt Technology
World's 1st Windows®-based Thunderbolt Motherboard
Equipping with the fastest I/O, Thunderbolt onboard, it ramps up the transfer speed up to 10Gbps which is 2X faster than USB 3.0. Also supporting high resolution of a DisplayPort up to 2560 x 1600. No more messy cabling, it only requires one unified cable to transmit your high-performance storage and video capturing devices. Also, with the daisy-chain technology, it can connect up to 6 Thunderbolt devices which extends the extreme capability out of one compact port.
4-Way SLI/CFX Support
We prepare the greatest for the most enthusiastic users and the hunger for graphics is definitely on the top list. It features a unique PCIe 3.0 bridge chip to support 4-Way SLI/CrossFireX at x16/x16 or x8/x8/x8/x8 for unrivaled multi-GPU gaming performance. Explicit the best graphical performance onboard.
mSATA 32GB SSD Onboard
To minimize the efforts users might encounter, P8Z77-V PREMIUM get everything ready onboard. Armed with 32GB SSD , you don't have to prepare the extras to enjoy the Intel® Smart Response and Rapid Start Technology for a faster system performance and instant-on function.
Above all, the P8Z77-V PREMIUM also have full-collection of ASUS Z77 features which includes Dual Intelligent Processors 3 with Smart DIGI+ Power Control for ultra-precise tuning to CPU, iGPU and DRAM. Dual band Wi-Fi GO! support for complete cloud entertainment. Fan Xpert 2 for individual, customized fan control and more. Get prepared! The PREMIUM fever is now onboard!
- Dual Intelligent Processors 3 with Smart DIGI+ Power Control
- Thunderbolt Technology Onboard
- Dual band Wi-Fi 802.11n and Bluetooth 4.0/3.0+HS Support
- Wi-Fi GO!
- Fan Xpert 2
- ASUS SSD Caching II
- mSATA 32GB SSD Onboard
Specification
- LGA1155 socket for Intel® 3rd/2nd Generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors
- Supports 22/32nm CPU
- Supports Intel® Turbo Boost Technology 2.0* * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
- Chipset Intel® Z77 Express Chipset
- 4 x DIMM, max. 32GB, DDR3 2800(O.C.)*/2600(O.C.)*/2400(O.C.)*/2200(O.C.)*/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz, non-ECC, un-buffered memory
- Dual channel memory architecture
- Supports Intel® Extreme Memory Profile (XMP) * Hyper DIMM support is subject to the physical characteristics of individual CPUs. Please refer to Memory QVL(Qualified Vendors List) for details.
- 4 x PCI Express 3.0*/2.0 x16 slots (support x16; x16/x16; x16/x8/x8; x8x8x8x8 mode)
- 2 x PCI Express 2.0 x1 slots * PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
- Thunderbolt: VGA output support with max. resolution 2560 x 1600@60Hz / Data transfer rate up to 10Gbps / Daisy-chain up to 6 Thunderbolt devices
- Integrated Graphics Processor- Intel® HD Graphics support
- Multi-VGA output support: Thunderbolt/DisplayPort/HDMI port
- Supports Thunderbolt with max. resolution 2560 x 1600@60Hz
- Supports DisplayPort 1.1a with max. resolution 2560 x 1600@60Hz
- Supports HDMI with max. resolution 1920 x 1200@60Hz
- Supports Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™
- Maximum shared memory of 1696MB
- Supports NVIDIA® 4-Way SLI™ Technology
- Supports AMD® 4-Way CrossFireX™ Technology
- Supports LucidLogix Virtu MVP Technology* * LucidLogix Virtu MVP supports Windows 7 operating systems.
- Intel® Z77 Express Chipset with RAID 0, 1, 5, 10 support
- 2 x SATA 6.0 Gb/s ports (gray)
- 3 x SATA 3.0 Gb/s ports (blue)
- 1 x mSATA 3.0 Gb/s port with onboard 32GB SSD
- Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology*
- Marvell® 9230 PCIe SATA 6Gb/s controller - 4 x SATA 6Gb/s ports (navy blue) with RAID 0, 1, 10 support
- ASMedia® SATA 6Gb/s controller** / 2 x eSATA 6Gb/s ports with port multiplier support / * Supports on Intel® Core™ processor family with Windows 7 operating systems. ** These SATA ports are for data hard drivers only. ATAPI devices are not supported.
- Dual Intel® Gigabit LAN controllers- 802.3az Energy Efficient Ethernet (EEE) appliance and dual interconnect between the integrated LAN controller and physical layer (PHY)
- Intel® 82579V Gigabit LAN
- Intel® 82583 Gigabit LAN
- Wi-Fi 802.11 a/b/g/n supports dual frequency band 2.4/5 GHz
- ASUS Wi-Fi GO! Utility
- Bluetooth v4.0
- Bluetooth v3.0 + HS
- Realtek® ALC898 8-channel high definition audio CODEC
- Absolute Pitch 192khz/24bit true BD lossless sound
- BD audio layer content protection
- DTS UltraPC II
- DTS Connect
- Supports jack-detection, multi-streaming, front panel jack-retasking
- Optical S/PDIF out port at back I/O
- 1 x ASMedia USB 3.0 controller- supports ASUS USB 3.0 Boost UASP Mode.
- 2 x USB 3.0/2.0 ports at back panel(blue)
- Intel® Z77 Express Chipset- supports ASUS USB 3.0 Boost Turbo Mode.*
- 2 x USB 3.0/2.0 ports at mid-board for front panel support
- 6 x USB 2.0/1.1 ports (4 ports at mid-board, 2 ports at back panel) * The USB 3.0 ports run at USB 3.0 speed rate under Windows® 7 or later versions.
- BIOS 64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
- ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
- Form Factor ATX Form Factor, 12"x 9.6" (30.5cm x 24.4cm)
Back Panel I/O Ports
- 1 x Thunderbolt port
- 1 x DisplayPort
- 1 x HDMI port
- 1 x BT4 connector for ASUS Wi-Fi GO! card (Wi-Fi 802.11 a/b/g/n and Bluetooth v4.0/3.0+HS)
- 1 x Optical S/PDIF out
- 2 x eSATA ports
- 2 x Intel® LAN (RJ45) ports
- 4 x USB 3.0/2.0 ports (blue, 1 supports USB BIOS Flashback)
- 2 x USB 2.0/1.1 ports
- 1 x USB BIOS Flashback button
- 8-channel Audio I/O ports
Internal I/O Connectors
- 1 x USB 3.0/2.0 connector supports additional 2 USB ports (19-pin)
- 2 x USB 2.0/1/1 connectors support additional 4 USB ports
- 6 x SATA 6.0Gb/s connectors ( 2 x gray; 4 x navy blue)
- 3 x SATA 3.0Gb/s connectors (blue)
- 1 x mSATA connector with 32GB SSD onboard
- 1 x CPU Fan connector (4-pin)
- 1 x CPU Optional Fan connector (4-pin)
- 4 x Chassis Fan connectors (4-pin)
- Front panel audio connector (AAFP)
- 1 x S/PDIF out header
- 1 x TPM connector
- 24-pin EATX Power connector
- 8-pin EATX 12V Power connector
- System Panel(Q-Connector)
- 1 x MemOK! button
- 1 x Clear CMOS button
- 1 x TPU switch
- 1 x EPU switch
- 1 x Power-on switch
- 1 x Reset switch
Accessories
- 2 x Wi-Fi ring moving antennas
- 1 x ASUS Wi-Fi GO! card (Wi-Fi 802.11 a/b/g/n and Bluetooth v4.0/3.0+HS)
- 1 x ASUS USB 3.0 front panel box
- 1 x 4-Way SLI card
- 1 x 3-Way SLI card
- 4 x Serial ATA 6.0Gb/s cables
- 2 x Serial ATA 3.0Gb/s cables
- 1 x ASUS SLI bridge connector
- ASUS Q-Shield
- 2 in 1 Q-connector
- User's manual
Thunderbolt™ Onboard
TAn industry first, ASUS has placed Thunderbolt I/O technology onboard, and are set to revolutionize the speed at which peripherals and displays operate. Featuring a maximum bi-directional speed of 10 Gbps, Thunderbolt is 2 times faster than USB 3.0 and an incredible 20 times faster than USB 2.0. And with the ability to daisy-chain up to six devices without the need for a hub or switch, that means less overheard for a clutter free computing experience. For example, users can connect multiple native Thunderbolt storage devices, an HD video capture device and even an HD display to a single Thunderbolt chain while maintaining maximum throughput. You can also connect a DisplayPort, DVI, HDMI or VGA display with an existing adapter.
ASUS SSD Caching II: Multiple SSD Caching, Instant Upgraded Speed
SSD Caching II has been upgraded with a multiple caching function, adding four extra SATA 6Gb/s onboard. This feature offers performance upgrades by using multiple installed SSDs with no capacity limitations as a cache for frequently accessed data. It also allows user to choose the combinateion that suits their needs. For example, you can choose three SSDs matched with one HDD or two SSDs with two HDDs. Harness a combination of SSD-like performance and response and hard drive capacity with a single click, without the need to reboot for instant activation and complete ease of use. As an added bonus, it can even prevent data loss with the included backup function, so you can rest easy knowing your data is secure.
PCI Express® 3.0
PCI Express® 3.0 (PCIe 3.0) is the latest PCI Express bus standard with improved encoding schemes that provide twice the performance of current PCIe 2.0. Total bandwidth for a x16 link reaches a maximum of 32GB/s, double the 16GB/s of PCIe 2.0 (in x16 mode). As such, PCIe 3.0 provides users unprecedented data speeds, combined with the convenience and seamless transition offered by complete backward compatibility with PCIe 1.0 and PCIe 2.0 devices. PCIe 3.0 will become a must-have feature for users who wish to improve and optimize graphic performance, as well as have the latest technology available to them.
Thunderbolt onboard
ASUS has placed Thunderbolt I/O technology onboard, and are set to revolutionize the speed at which peripherals and displays operate. Featuring a maximum bi-directional speed of 10 Gbps, Thunderbolt is 2 times faster than USB 3.0 and an incredible 20 times faster than USB 2.0. And with the ability to daisy-chain up to six devices without the need for a hub or switch, that means less overheard for a clutter free computing experience. For example, users can connect multiple native Thunderbolt storage devices, an HD video capture device and even an HD display to a single Thunderbolt chain while maintaining maximum throughput. You can also connect a DisplayPort, DVI, HDMI or VGA display with an existing adapter. -
ASUS SSD Caching II
SSD Caching II has been upgraded with a multiple caching function, adding four extra SATA 6 Gb/s onboard. This feature offers performance upgrades by using multiple installed SSDs with no capacity limitations as a cache for frequently accessed data. It also allows user to choose the combination that suits their needs. For example, you can choose three SSDs matched with one HDD or two SSDs with two HDDs. Harness a combination of SSD-like performance and response and hard drive capacity with a single click, without the need to reboot for instant activation and complete ease of use. As an added bonus, it can even prevent data loss with the included backup function, so you can rest easy knowing your data is secure. -
Dual Intelligent Processors 3 with SMART DIGI+ technology
The Dual Intelligent Processors from ASUS pioneered twin onboard chips - TPU (TurboV Processing Unit) and EPU (Energy Processing Unit). Dual Intelligent Processors 3 builds on that foundation with new SMART DIGI+ power control, which includes multiple digital voltage controllers, allowing ultra-precise tuning for the CPU, iGPU and DRAM. It's upgraded with one-click extreme performance optimization and selectable CPU wattage levels, offering easier power control and better power savings with the user-friendly AI Suite II utility. -
TPU plus SMART DIGI+
Always at the forefront of power design, ASUS propels you into the future standard of power management again by SMART DIGI+ technology, which works with the TPU (TurboV Processing Unit) to ramps up performance to its maximum. Enable the SMART DIGI+ key with a single click and adjust CPU ratios manually in the TPU to increase CPU frequency up to an incredible 85%! SMART DIGI+ technology also includes the Smart CPU Power Level profile, which reduces CPU power consumption to a specific indicated wattage with a single click, creating a cooler and quieter PC. -
Wi-Fi GO!
ASUS Wi-Fi GO! makes enjoying home entertainment and remote control capabilities easier than ever by linking PCs, pads, smartphones and TV together. With a Wi-Fi module on board, ASUS Wi-Fi GO! adds a host of useful and free Wi-Fi functions, which provide DLNA streaming so you can enjoy a home theater PC, while also providing remote access to your PC with a smart device. This feature leads the market by integrating Wi-Fi connectivity, DLNA access and all smart devices with a one-stop utility for a futuristic connected lifestyle. -
USB BIOS Flashback
USB BIOS Flashback offers the convenient way ever to update the BIOS! It allows users to update UEFI BIOS versions even without hardware such as a CPU or DRAM installed into the motherboard. Just plug in a USB flash drive containing the BIOS file, and press the BIOS Flashback button for 3 seconds with the power supply connected. The UEFI BIOS will then automatically update without requiring further interaction. -
Network iControl
With a single-click on/off button, the application currently in use has its data and network bandwidth prioritized over other programs. Moreover, you can prioritize your favorite software easily by configuring profiles through the intuitive user interface. Within the profile, programs can be pre-scheduled to run in a specific time period to avoid network congestion and long-waits on downloads. Auto PPPoE network connection provides a one-step setup for enhanced online convenience. Overall, it's an intuitive network bandwidth control center. -
DTS Connect
To get the most out of your audio entertainment across all formats and quality levels, DTS Connect combines two enabling technologies. DTS Neo:PC upmixes stereo sources into as many as 7.1 channels of incredible surround sound. Consumers can then connect their PC to a home theater system. DTS Interactive is capable of performing multi-channel encoding of DTS bitstreams on personal computers, and sending encoded bitstreams out of a digital audio connection designed to deliver audio to an external decoder. -
DTS UltraPC II
DTS UltraPC II delivers exceptional 7.1 surround through the most popular PC audio setups - your existing stereo speakers or headphones. In addition to virtual surround, it upgrades original sound to new levels with Audio Restoration, recreating the dynamic range of audio files. Symmetry mode improves the balance of perceived loudness across different input sources and enhance boosts audio quality through high and low frequency equalization. With these technologies, users experience better home theater audio with ease. -
Way SLI and 4-way CrossFireX support
The P8Z77-V PREMIUM motherboard offers the ultimate in multi-GPU gaming performance! The motherboard features a unique PCIe 3.0 bridge chip to support 4-way SLI/CrossFireX for unrivaled gaming performance. Featuring the powerful Intel Z77 platform to optimize PCIe allocation with multiple GPUs, it supports up to four graphics cards in a 4-way SLI or CrossFireX configuration.
- ASUS P8Z77-V PREMIUM - motherboard - ATX - LGA1155 Socket - Z77 - with mSATA 32GB SSD Onboard
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel Z77 Express
- Processor Socket
- 1 x LGA1155 Socket
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 6 x SATA-600 (RAID), 4 x SATA-300 (RAID), 2 x eSATA-600
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 4 x USB 2.0 via headers)
- Max Allocated RAM Size
- 1696 MB
- Audio
- HD Audio (8-channel)
- LAN
- 802.11a/b/g/n, Bluetooth, 2 x Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- 3-year warranty
- Bundled with
- Product Type
- Motherboard - ATX - with mSATA 32GB SSD Onboard
- Chipset Type
- Intel Z77 Express
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
- 1696 MB
Audio
- Audio Codec
- Realtek ALC898
- DTS Connect, High Definition Audio, DTS UltraPC II
LAN
- Network Controller
- Intel 82579V / Intel 82583
- Network Interfaces
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 4 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 3 x 7pin SATA, 1 x mSATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , Marvell 88SE9230: SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 , SATA-600 -connectors: 2 x 7pin external SATA - 2 devices
- RAID Features
- Intel Smart Response Technology
- 1 x Thunderbolt , 1 x DisplayPort , 2 x LAN (Gigabit Ethernet) , 1 x HDMI , 4 x USB 3.0 , 1 x TOSLINK , 2 x USB 2.0 , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 4 x USB 2.0 , 1 x USB 3.0 - header , 1 x SPDIF out , 1 x audio
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, Intel Extreme Memory Profile (XMP) support, ASUS TurboV, 20 Phase Power Design, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), Intel Clear Video HD Technology, Intel Smart Response Technology, NVIDIA 4-way SLI Technology Support, USB 3.0 Boost, Dual Intelligent Processors 3, Fanless Design Heat-pipe, Q-Code, ASUS Fan Xpert 2, ASUS Network iControl, ASUS SMART DIGI+, ASUS USB Charger+, ASUS Wi-Fi GO!, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, ASUS 2 Phase DRAM Power Design, Onboard mSATA Connector, Intel InTru 3D Technology, Intel Insider, Intel Quick Sync Video, AMD 4-way CrossFireX technology support, ASUS SSD Caching II
- Included Accessories
- ASUS Front Panel USB 3.0 Box, ASUS Wi-Fi GO! card, 2 x Wi-Fi Ring Moving Antennas
- Cables Included
- 6 x Serial ATA cable , 1 x 3-way SLI bridge , 1 x 4-way SLI bridge , 1 x SLI bridge
- Software Included
- Drivers & Utilities, ASUS EZ Flash 2, ASUS Auto Tuning, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
- Plug and Play, ACPI 2.0a
- 30.5 cm
- 24.4 cm
- Limited warranty - 3 years
Asus P8Z77-V Premium S1155 Intel Z77 DDR3 ATX with Thunderbolt Technology
