The P8Z77-M Pro with a 32GB DDR3 memory and PCLe 3.0, features the new Intel Z77 express chipset and supports a 22/32 nm CPU providing excellent overclocking capabilities of up to 2400 MHz. It also caters to a wide range of end users by including features such as GeForce® SLI™ and AMD Crossfire for a flawless architecture accommodating the power of up to four graphics cards, whether that be for professional graphics work, heavy duty multimedia or dedicated gaming.
The P8Z77-M Pro also includes Dual Intelligent Processors 2 consisting of two onboard chips, the TPU and EPU providing precise Vcore PWM, integrated graphics voltages and frequency module adjustments with minimal power loss. While the ASUS DIGI+ VRM digital power design empowers users with superior flexibility and perfect precision to ensure optimized performance, extreme system stability and greater power efficiency. Other incredible features include Fan Xpert+ which enables customizable fan controls and the ASUS exclusive UEFI BIOS with a multi-language setting offering a mouse controlled and user friendly interface which can be upgraded using BIOS USB flashback, complete within just one click! Furthermore, containing 6 USB 3.0 ports with USB boost UASP which gains unprecedented speed, the P8Z77-M Pro also features LudicLogix Virtu MVP which boots responsiveness, improves gaming frame rates by 30-70%, sharpens visual quality and works seamlessly with hundreds of game stations. Thus making The P8Z77-M Pro a multifaceted motherboard for excellent quality and value!
Asus Exclusive Innovations
- DIGI+ VRM
- Fan Xpert+
- Network iControl
- USB BIOS Flashback
- USB 3.0 Boost
Innovations
- Dual Intelligent Processors 3 - with New DIGI+ Power Control include three digital voltage controllers, allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control
- Quad GPU AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
- LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
- Supports NVIDIA® Quad-GPU SLI™ Technology (with 2 PCIex16 graphics card)
Spec details
- CPU LGA1155 socket for 3rd generation Intel® Core™ processor-based platform and 2nd generation Core™ i7/ i5/ i3/ Pentium® / Celeron® Processors, Supports 22/32nm CPU, Supports Intel® Turbo Boost Technology 2.0* * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
- Chipset Intel® Z77 Express Chipset
- Memory 4 x DIMM, max. 32GB, DDR3 2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C)/1866(O.C.)*/1600/1333/1066 MHz, non-ECC, un-buffered memory, Dual channel memory architecture, Supports Intel® Extreme Memory Profile (XMP) * Hyper DIMM support is subject to the physical characteristics of individual CPUs. Please refer to Memory QVL(Qualified Vendors List) for details.
- Expansion Slots 2 x PCI Express 3.0*/2.0 x16 slots (single at x16 or dual at x8 / x8 mode), 1 x PCI Express 2.0 x16 slot [black] (max. at x4 mode, compatible with PCIe x1 and x4 devices), 1 x PCI Express 2.0 x1 slots * PCIe 3.0 speed is supported by Intel® 3rd generation Core™ processors.
- VGA Integrated Graphics Processor- Intel® HD Graphics support, Multi-VGA output support: HDMI/ DVI-D/ RGB port, Supports HDMI with max. resolution 1920 x 1200@60Hz , Supports DVI-D with max. resolution 1920 x 1200@60Hz, Supports RGB with max. resolution 2048 x 1536@75Hz, Supports Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™, Maximum shared memory of 1696MB
- Multi-GPU support Supports NVIDIA® Quad-GPU SLI™ Technology (with 2 PCIex16 graphics card), Supports AMD® 3-Way/Quad-GPU CrossFireX™ Technology, Supports LucidLogix Virtu MVP Technology* * LucidLogix Virtu MVP supports Windows 7 operating systems.
- Storage Intel® Z77 Express Chipset, 2 x SATA 6.0 Gb/s ports (gray) with RAID 0, 1, 5, 10 support, 4 x SATA 3.0 Gb/s ports (blue) with RAID 0, 1, 5, 10 support, Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology, ASMedia® 1061 SATA 6Gb/s controller, 2 x eSATA 6Gb/s ports with port multiplier support, Supports on Intel® Core™ processor family with Windows 7 operating systems., * These SATA ports are for data hard drivers only. ATAPI devices are not supported.
- LAN Realtek® 8111F Gigabit LAN controller
- Audio Realtek® ALC892 8-channel high definition audio CODEC, Absolute Pitch 192khz/24bit true BD lossless sound, Supports jack-detection, multi-streaming, front panel jack-retasking, Optical S/PDIF out port at back I/O
- USB 1 x ASMedia USB 3.0 controller- supports ASUS USB 3.0 Boost UASP Mode, 2 x USB 3.0/2.0 ports at back panel(blue), Intel® Z77 Express Chipset- supports ASUS USB 3.0 Boost UASP Mode.*, 2 x USB 3.0/2.0 ports at mid-board for front panel support, 2 x USB 3.0/2.0 ports at back panel(blue), Intel® Z77 Express Chipset, 8 x USB 2.0/1.1 ports (6 ports at mid-board, 2 ports at back panel), * The USB 3.0 ports run USB 3.0 speed under Windows® 7 or later versions.
- ASUS Unique Features: ASUS Dual Intelligent Processors 2 with DIGI+ VRM: ASUS Digital Power Design, ASUS EPU, ASUS TPU
- ASUS Exclusive Overclocking Features: Precision Tweaker 2
- Back Panel I/O Ports 1 x HDMI port, 1 x DVI-D, 1 x RGB, 1 x Optical S/PDIF out, 2 x eSATA 6Gb/s ports, 1 x LAN (RJ45) port, 4 x USB 3.0/2.0 ports (blue, 1 supports USB BIOS Flashback), 2 x USB 2.0/1.1 ports, 8-channel Audio I/O ports
- Internal I/O Connectors: 1 x USB 3.0/2.0 connector supports additional 2 USB ports (19-pin), 3 x USB 2.0/1/1 connectors support additional 6 USB ports, 2 x SATA 6.0Gb/s connectors (gray), 4 x SATA 3.0Gb/s connectors (blue), 1 x CPU Fan connector (4-pin), 3 x Chassis Fan connectors (4-pin), Front panel audio connector (AAFP), 1 x S/PDIF out header, 24-pin EATX Power connector, 8-pin ATX 12V Power connector, System Panel(Q-Connector), 1 x USB BIOS Flashback button, 1 x MemOK! button, 1 x Clear CMOS Jumper, 1 x TPU switch, 1 x EPU switch, 1 x COM port connecter, 1 x TPM header,
- BIOS 64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI 2.0a, Multi-language BIOS,
- ASUS EZ Flash 2, ASUS CrashFree BIOS 3, F12 PrintScreen, F3 Shortcut Function and ASUS DRAM SPD (Serial Presence Detect) memory information
- Manageability WfM 2.0, DMI 2.0, WOL by PME, PXE, WOR by PME
- Accessories 2 x Serial ATA 6.0Gb/s cables, 2 x Serial ATA 3.0Gb/s cables, 1 x ASUS SLI bridge connector, 1 x I/O Shield, 2 in 1 Q-connector, User's manual
- Support DVD Drivers, ASUS Utilities, ASUS Update, Anti-virus software (OEM version)
- Form Factor mATX Form Factor, 9.6"x 9.6" (24.4cm x 24.4cm)
USB 3.0 boost
ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol), USB 3.0 standard. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to an already impressive fast USB 3.0 transfer speed. ASUS software automatically accelerates data speeds for compatible USB 3.0 peripherals without the need for any user interaction. -
USB BIOS flashback
A truly revolutionary hardware-based update solution. USB BIOS Flashback offers the most convenient way ever to update the BIOS! It allows users to update UEFI BIOS versions even without hardware such as a CPU or DRAM installed into the motherboard. Just plug in a USB flash drive containing the BIOS file, and press the BIOS Flashback button for 3 seconds with the power supply connected. The UEFI BIOS will then automatically update without requiring further interaction. -
LucidLogix Virtu MVP featuring HyperFormance technology boosts your discrete graphics card up to 60% beyond its original performance through the test of 3DMark Vantage. Designed for Intel processor graphics and Windows 7 PCs, it perfectly combines the performance of discrete graphics cards with fast computing iGPU. Also with the newly designed Virtual Sync, users can enjoy a smoother gaming experience by eliminating tearing artifacts. LucidLogix Virtu MVP could also dynamically assign tasks to the best available graphics resource, based on power, performance and system load. This allows users to fully utilize 3x faster video conversion with Intel Quick Sync Video technology while retaining high-end 3D rendering and gaming performance, provided by both NVIDIA and AMD graphic cards. When the discrete graphics card is not required, power consumption goes automatically down to near zero, making the system more environmentally-friendly. For users searching for perfection, LucidLogix Virtu MVP provides great graphical performance and the best flexibility and efficiency. -
DIGI+ VRM
VRM, or voltage regulator modules, are considered among the most essential motherboard design components. They supply the voltage demanded by the CPU, and a good VRM must intelligently detect actual CPU power draw to provide precise power accordingly. ASUS DIGI+ VRM is an innovative, industry-leading technology that fully integrates Intel VRD12 specifications on a native level, greatly enhancing power to go far beyond the limits of analog designs. -
GPU boost
GPU boost accelerates the integrated GPU for extreme graphics performance. The user-friendly interface facilitates flexible frequency adjustments. It easily delivers stable system-level upgrades for every use. -
UEFI BIOS
ASUS UEFI BIOS offers the first mouse-controlled graphical BIOS designed with selectable modes, providing a user-friendly interface that goes beyond traditional keyboard-only controls. It also natively supports fully-utilized hard drives larger than 2.2 TB in 64-bit operating systems. -
PCI Express 3.0
PCI Express 3.0 (PCIe 3.0) is the PCI Express bus standard with improved encoding schemes that provide twice the performance of current PCIe 2.0. Total bandwidth for a x16 link reaches a maximum of 32 GB/s, double the 16 GB/s of PCIe 2.0 (in x16 mode). As such, PCIe 3.0 provides users unprecedented data speeds, combined with the convenience and seamless transition offered by complete backward compatibility with PCIe 1.0 and PCIe 2.0 devices. PCIe 3.0 will become a must-have feature for users who wish to improve and optimize graphic performance, as well as have the latest technology available to them.Actual PCIe 3.0 speed varies with the installed CPU type.
- ASUS P8Z77-M PRO - motherboard - micro ATX - LGA1155 Socket - Z77
- Product Type
- Motherboard - micro ATX
- Chipset Type
- Intel Z77 Express
- Processor Socket
- 1 x LGA1155 Socket
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600 (RAID), 4 x SATA-300 (RAID), 2 x eSATA-600
- USB / FireWire Ports
- 4 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Chipset Type
- Intel Z77 Express
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Audio
- Audio Codec
- Realtek ALC892
- High Definition Audio
LAN
- Network Controller
- Realtek RTL8111F
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 1 x PCIe 2.0 x1
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , ASMedia ASM1061: SATA-600 -connectors: 2 x 7pin external SATA - 2 devices
- RAID Features
- Intel Smart Response Technology
- 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 4 x USB 3.0 , 2 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 6 x USB 2.0 , 1 x USB 3.0 - header , 1 x serial , 1 x audio , 1 x SPDIF out
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.5 support, USB BIOS Flashback, UEFI BIOS
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, 8 Phase Power Design, ASUS Q-Design, Q-DIMM, GPU Boost, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, NVIDIA Quad SLI Technology Support, ASUS TurboV, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, Fanless Design Heatsink, Dual Intelligent Processors 2, USB 3.0 Boost, ASUS Fan Xpert+, AMD Quad CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS Network iControl, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP
- Cables Included
- 4 x Serial ATA cable , 1 x SLI bridge
- Software Included
- Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+, ASUS Update
- Plug and Play, ACPI 2.0a
- 24.4 cm
- 24.4 cm
