Asus P8Z68-V PRO LGA1155 Intel Z68 DDR3 ATX (USB 3.0)
Quicklinx: 7HDTWS00 Mfr#: P8Z68-V PRO
ASUS is proud to introduce the P8Z68-V PRO Motherboard which includes all of the rich features that you would expect from ASUS, providing users with Smart, Fast and Efficient Tuning.
The P8Z68-V PRO board brings users Intel® Smart Response Technology while also delivering the most flexible tuning of the core, graphics and memory.
Smart Response Technology allows users to experience the benefits of both SSD & HDD. The board combines SSD responsiveness with the capacity of HDD. This in turn results in a FASTER system boot and FASTER data retrieval!
Users can benefit from a free GPU performance upgrade via two simple methods using iGPU. The first method is through the on-board GPU Boost switch and the second method is via the easily adjustable settings in the friendly UI. Users can enhance GPU performance by a massive 34%*.
The ASUS P8Z68-V PRO features LucidLogix® Virtu, which is specifically designed for the Intel® Sandy Bridge platform's powerful integrated graphics. Its GPU virtualization dynamically assigns tasks to the best available graphics resources, providing greater flexibility and efficiency.
Exclusive ASUS features also include, Dual Intelligent Processors 2 which features DIGI+ VRM providing high system stability and efficiency, precise adjustment under BIOS &UI and an active cooling micro-processor. EPU provides system energy saving and real time power management. TPU delivers a second micro-processor to free CPU resources as well as easy O.C. and an instant performance boost through an on-board switch or the easy O.C. tool, TurboV EVO.
UEFI BIOS (EZ Mode) offers users a flexible and simple BIOS graphical interface and mouse control.
This model is also rich in SPEC, including Quad USB 3.0 & SATA 6Gb/s ports and one Intel® LAN, allowing users to experience the thrill of faster data transfer rates.
ASUS Unique Selling Points
  • Dual Intelligent Processors 2 with DIGI+ VRM: Industry leading Digital 16-Phase Power Design (12-phase for CPU, 4-phase for iGPU)
  • ASUS EPU & EPU switch: Automatically provides the most appropriate power usage to save power and money.
  • ASUS TPU with Auto Tuning and TurboV: Providing simple steps to easy overclocking.
  • GPU Boost: Upgrade your graphics performance by up to 48%
  • BT GO! (Bluetooth): Folder Sync, BT Transfer, Shot & Send, BT to Net, Music Player, Personal Manager
  • BT Turbo Remote: Exclusive Smartphone Interface supporting iPhone, Android, Windows Mobile and Symbian systems
  • ASUS EFI BIOS(EZ Mode):The most flexible and easy to use Bios.
  • MemOK!: Quickly ensures memory boot compatibility with failsafe settings.
  • AI Suite II: One stop access to all Asus features.
  • Anti-Surge Protection: This special design prevents expensive devices and the motherboard from damage caused by power surges.
  • Disk Unlocker: Allows support for 2.2TB HDD and above.
  • Fanless Design: Silent Heat-sink solution
  • Fan Xpert: Smart thermal control via fan speed detection.
  • CrashFree BIOS 3: Restore corrupted BIOS data from a USB flash disk
  • EZ Flash 2: Easily update your systems bios firmware.
Key specification
  • Form Factor: ATX Form Factor, 12"x 9.6" (30.5cm x 24.4cm)
  • Socket: LGA1155 socket for Intel® 2nd Generation Core™ i7/ Core™ i5/ Core™ i3 Processors
  • Chipset: Intel® Z68 Express Chipset
  • Graphics interface: 2 x PCI Express 2.0 x16 slots (single at x16 or dual at x8 / x8 mode)
  • Expansion Slots: 1 x PCI Express 2.0 x16 slot* [black] (max. at x4 mode, compatible with PCIe x1 and x4 devices), 2 x PCI Express 2.0 x1 slots, 2 x PCI slots
  • Multi GPU: Supports NVIDIA® Quad-GPU SLI™ Technology/ ATI® Quad-GPU CrossFireX™
  • Memory: 4 x DIMM, max. 32GB, DDR3 2200(O.C.)*/2133(O.C.)/1866(O.C.)/1600/1333/1066 MHz, non-ECC, un-buffered memory, Dual channel memory architecture
  • Audio: Realtek® ALC892 8-Channel High Definition Audio CODEC
  • LAN: Gigabit Intel® Ethernet LAN
  • Storage: - 2 x SATA 6.0 Gb/s ports (gray), 4 x SATA 3.0 Gb/s ports (blue): RAID 0, 1, 5 and 10, 2 x SATA 6.0 Gb/s ports (navy blue), 1 x eSATA 3.0 Gb/s port
  • USB: - 2 x USB 3.0 ports at mid-board for front panel support (blue), 2 x USB 3.0 ports at back panel (blue), 12 x USB 2.0 ports (6 ports at mid-board, 6 ports at back panel)
  • Manageability: WfM 2.0, DMI 2.0, WOL by PME, WOR by PME, PXE
  • Bluetooth: Bluetooth v2.1 + EDR
Back Panel I/O Ports
  • 1 x HDMI
  • 1 x DVI
  • 1 x RGB
  • 1 x Optical S/PDIF Out
  • 1 x Bluetooth module
  • 1 x eSATA port
  • 1 x Intel® LAN (RJ45) port
  • 2 x USB 3.0/2.0 ports (blue)
  • 6 x USB 2.0/1.1 ports
  • 8-channel Audio I/O ports
Internal I/O Connectors
  • 1 x USB 3.0/2.0 connector supports additional 2 USB ports (19-pin)
  • 3 x USB 2.0/1/1 connectors support additional 6 USB ports
  • 4 x SATA 6.0Gb/s connectors ( 2 x gray; 2 x navy blue)
  • 4 x SATA 3.0Gb/s connectors (blue)
  • 2 x CPU Fan connector (4-pin)
  • 2 x Chassis Fan connectors (1 x 4-pin; 1 x 3-pin)
  • 2 x Power Fan connector (3-pin)
  • 2 x IEEE1394a connector
  • Front panel audio connector
  • 1 x S/PDIF Out Header
  • 24-pin EATX Power connector
  • 8-pin EATX 12V Power connector
  • System Panel(Q-Connector)
  • 1 x MemOK! Button
  • 1 x EPU switch
  • 1 x TPU switch
In The Box
  • 2 x Serial ATA 6.0Gb/s cables
  • 2 x Serial ATA 3.0Gb/s cables
  • 1 x ASUS SLI bridge connector
  • 1 x ASUS USB 3.0 Bracket
  • ASUS Q-Shield
  • 2 in 1 Q-connector
  • User's manual
  • Support DVD
  • Drivers
  • ASUS Utilities
  • ASUS Update
  • Anti-virus software (OEM version)
  • Flexible & Easy BIOS interface
    Exclusive to ASUS motherboards, its UEFI (Unified Extensible Firmware Interface) is the first ever mouse-controlled graphical BIOS interface designed with dual selectable modes. It delivers a user-friendly interface that goes beyond traditional keyboard-only BIOS controls to enable more flexible and convenient input with quick scrolling. Users can easily navigate the UEFI BIOS with the smoothness of their operating system. Quick and simple overclocking and setup sharing is facilitated by the F12 hotkey BIOS snapshot feature. The exclusive EZ Mode displays frequently-accessed setup info, while the Advanced Mode is for experienced performance enthusiasts that demand far more intricate system control, including detailed DRAM information.
  • Supports Hard Drives over 2.2 TB
    ASUS UEFI BIOS natively supports hard drives larger than 2.2 TB in 64-bit, with full storage space utilization helping deliver far more exciting computing than traditional BIOS versions.
  • Universal switchable graphics technology
    LucidLogix Virtu is designed for the Intel Sandy Bridge platform's powerful integrated graphics. Its GPU virtualization dynamically assigns tasks to the best available graphics resources based on power, performance and system load on Windows 7 based PCs. It allows users to fully utilize the unique capabilities of advanced Sandy Bridge multimedia features alongside the high end 3D rendering performance provided by installed graphics cards. When no discrete graphics are needed, the graphics card is put in idle mode to lower utilization, heat, fan speed and power draw down to near zero, making the system more environmentally-friendly. For users with diverse needs, LucidLogix Virtu GPU virtualization provides great flexibility and efficiency.
    LucidLogix Virtu's GPU virtualization technology assigns tasks to the best available GPU, allowing dynamic graphics switching between integrated graphics and NVIDIA or AMD graphics cards.
  • 3X Faster Video Conversion
    With switchable graphics, all ASUS P8Z68 Series motherboards leverage the transcoding power of Sandy Bridge, allowing users to enjoy three times faster video conversion with Intel Quick Sync Video technology.
  • Intel Smart Response technology
    Intel Smart Response Technology boosts overall system performance. It uses an installed fast SSD (min 18.6GB available capacity) as a cache for frequently accessed data. Harness the combination of SSD-like performance and response with hard drive capacity, that's 4X faster than a HDD-only system.
  • SSD speed with HDD capacity
  • Energy efficiency all around
    Tap into the world's first real-time PC power saving chip through a simple onboard switch or AI Suite II utility. Get total system-wide energy optimization by automatically detecting current PC loadings and intelligently moderating power consumption. This also reduces fan noise and extends component longevity!
  • Go to the limit with iGPU level up
    GPU Boost accelerates the integrated GPU for extreme graphics performance. The user-friendly interface facilitates flexible frequency adjustments. It easily delivers stable system-level upgrades for every use.
  • BT GO!
    Onboard Bluetooth wireless design enables smart connectivity to Bluetooth devices with no additional adapter. ASUS BT GO! comes with 7 special functions that offer a significant breakthrough in Bluetooth evolution, including Folder Sync, BT Transfer, BT Turbo Remote, BT-to-Net, Music Player, Shot and Send, and Personal Manager. All are accessible through the exclusive, user-friendly ASUS interface.
  • Double USB access, double convenience
    ASUS facilitates strategic USB 3.0 accessibility for both the front and rear panels - 4 USB 3.0 ports in total. Experience the latest plug & play connectivity at speeds up to 10 times faster than USB 2.0. The P8Z68-V PRO affords greater convenience with high speed connectivity.
  • Extra ports, extra speed and accessibility
    The Intel Z68 Express chipset natively supports the next-generation Serial ATA (SATA) interface, delivering up to 6Gb/s data transfers. ASUS provides extra SATA 6 b/s ports with enhanced scalability, faster data retrieval and double the bandwidth of current bus systems.
  • DTS Surround Sensation UltraPC
    DTS Surround Sensation UltraPC delivers exceptional 5.1 surround experience through the most common PC audio setups - your existing stereo speakers or headphones. In addition to virtual surround, "Bass enhancement" provides stronger low frequency bass sound, and "Voice clarification" provides clear human dialog even with loud background sound. With these technologies, you may experience a better home-theater audio with ease.
  • Intel LAN support
    P8Z68-V PRO features Intel Gigabit LAN which complies with 802.3az Energy Efficient Ethernet (EEE) standard and reduces power consumption during normal operation and enhances faster transfer speed through dual interconnection between the Integrated LAN controller and Physical Layer (PHY).
ASUS P8Z68-V Pro - motherboard - ATX - LGA1155 Socket - Z68
Motherboard - ATX
Chipset Type
Intel Z68 Express
Processor Socket
1 x LGA1155 Socket
Compatible Processors
Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
4 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600 (RAID), 2 x SATA-600, 4 x SATA-300 (RAID), 1 x eSATA-300
USB / FireWire Ports
2 x USB 3.0 + 6 x USB 2.0 + (2 x USB 3.0 + 2 x FireWire + 6 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
3-year warranty
Motherboard - ATX
Chipset Type
Intel Z68 Express
Processor Socket
LGA1155 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR3
Bus Clock
1600 MHz, 1333 MHz, 1066 MHz
Speed
PC3-12800, PC3-10600, PC3-8500
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Audio
Audio Codec
Realtek ALC892
DTS Surround Sensation UltraPC, High Definition Audio
LAN
Network Controller
Intel 82579
Network Interfaces
Expansion Slots
1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 1 x PCIe 2.0 x16 , 2 x PCIe x1 , 2 x PCI
Storage Interfaces
SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , JMicron JMB362: SATA-300 -connectors: 1 x 7pin external SATA - 1 devices
1 x DVI-D , 1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 6 x USB 2.0 , 2 x USB 3.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
6 x USB 2.0 , 2 x USB 3.0 , 2 x FireWire , 1 x SPDIF out
Power Connectors
24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support, ASUS EFI BIOS
Sleep / Wake Up
Wake on LAN (WOL), wake on ring (WOR)
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, ASUS TurboV EVO, Stack Cool 3+, Q-DIMM, GPU Boost, ASUS EZ DIY, Q-LED, Q-Slot, CrashFree BIOS 3, ASUS Q-Connector, All-Solid Capacitor motherboard Design, ASUS Noise Filter, audio jack detect technology, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, NVIDIA Quad SLI Technology Support, ASUS TurboV, ASUS BT GO!, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), ASUS DIGI+ VRM, 16 Phase Power Design, Lucid Virtu, AMD Quad CrossFireX technology support
4 x Serial ATA cable , 1 x SLI bridge , 1 x SuperSpeed USB panel
Software Included
Drivers & Utilities, ASUS AI Suite II, ASUS AI Charger+
Plug and Play, ACPI 2.0a, EuP Ready, ErP Ready
30.5 cm
24.4 cm
Limited warranty - 3 years
