The P8H77-V with a 32GB DDR3 memory and PCLe 3.0, features the new Intel H77 express chipset and supports a 22/32 nm CPU providing excellent overclocking capabilities of up to 2200 MHz. It also caters to a wide range of end users by including features such as AMD Crossfire for a flawless architecture accommodating the power of up to four graphics cards, whether that be for professional graphics work, heavy duty multimedia or dedicated gaming. While GPU Boost accelerates the integrated GPU for extreme graphics performance and stable system-level upgrades.
The P8H77-V also includes Dual Intelligent Processors 3 consisting of two onboard chips, the TPU and EPU providing precise Vcore PWM, integrated graphics voltages and frequency module adjustments with minimal power loss. The EPU is also part of Protect 3.0 which safeguards devices by preventing overvoltage damage and contains an anti-surge protection design while also eliminating 50% of radiation. ASUS DIGI+ VRM digital power design empowers users with superior flexibility and perfect precision to ensure optimized performance, extreme system stability and greater power efficiency. Other incredible features include FAN Xpert which enables precise fan controls and the ASUS exclusive UEFI BIOS with a multi-language setting offering a mouse controlled and user friendly interface.
Furthermore, containing 4 USB 3.0 ports with USB 3.0 boost UASP which gains unprecedented speed, the P8H77-V also features LudicLogix Virtu MVP which boots responsiveness, improves gaming frame rates by 30-70%, sharpens visual quality and works seamlessly with hundreds of game stations. Thus making The P8H77-V a multifaceted motherboard for excellent quality and value!
Asus Exclusive Innovations
- DIGI+ VRM
- GPU Boost
- USB 3.0 Boost
- FAN Xpert
- Protect 3.0
Innovations
- Dual Intelligent Processors 3 - with New DIGI+ Power Control include three digital voltage controllers, allowing ultra-precise DRAM tuning in addition to ultra-precise CPU voltage control
- Quad GPU AMD CrossfireX - a flawless architecture accommodating the power of up to four graphics cards
- LudicLogix Virtu MVP - boots responsiveness, improves gaming frame rates by 30-70% and sharpens visual quality
Spec details
- Model P8H77-V
- Chipset H77
- Power Phase DIGI+ VRM, 6+2+1 Phase
- Memory 4*DIMM,2200(O.C.)
- Graphics 1 x PCIe 3.0/2.0 x16 slot / 1*PCIe 2.0 x16 slot (@x4)
- VGA DP/HDMI/DVI/RGB
- LucidLogix Virtu MVP YES
- SLI/CrossFire CrossFireX
- PCI 3
- PCIex1 2
- Storage 2SATA 6Gb/s / 4SATA 3Gb/s
- LAN 1*Atheros 8161 Gb LAN
- USB 4USB 3.0 / 10USB 2.0
- Audio VIA, VT1708S 8-CH
- Accessories 2*SATA 6G cable
- Unique Features DIGI+ VRM / GPU Boost / USB 3.0 Boost / FAN Xpert / Protect 3.0
- BIOS UEFI BIOS
- Form Factor ATX, 30.5cm x 22.6cm
LGA1155 Intel 3rd/2nd Generation processors ready
This motherboard supports the Intel 3rd/2nd generation processors in the LGA1155 package, with iGPU, memory and PCI Express controllers integrated to support onboard graphics output with dedicated chipsets, 2-channel (4 DIMM) DDR3 memory and 16 PCI Express 3.0/2.0 lanes. This provides great graphics performance. Intel 3rd/2nd generation processors are among the most powerful and energy efficient CPUs in the world. -
Intel H77 Express chipset
The Intel H77 Express chipset is a single-chipset design to support socket 1155 Intel 3rd/2nd generation processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, H77 chipset provides 4 USB 3.0 ports for 10 times faster data retrieval speed. Moreover, Intel H77 Express chipset can also enable iGPU function, letting users enjoy the latest Intel integrated graphic performance. -
Intel Smart Response technology
Intel Smart Response technology boosts overall system performance. It uses an installed fast SSD (min 18.6 GB available capacity required) as a cache for frequently accessed data. Key benefits include reduced load and wait times, and lower power consumption through the elimination of unnecessary hard drive spin. This technology combines SSD performance with hard drive capacity, operating up to 6X faster than a hard drive-only system. -
Intel Smart Connect technology
Your computer can receive web updates with fresh content for selected applications, even when the system is in sleep mode. This means less time waiting for applications to update and sync with the cloud, leading to a more efficient computing experience. -
Intel Rapid Start technology
Allows your computer to quickly resume from a low-power hibernate state in seconds. Saving your system memory to the designated SSD, it provides your computer a faster wake-up response time, while still keeping the energy use low. -
LucidLogix Virtu MVP featuring HyperFormance technology boosts your discrete graphics card up to 60% beyond its original performance through the test of 3DMark Vantage. Designed for Intel processor graphics and Windows 7 PCs, it perfectly combines the performance of discrete graphics cards with fast computing iGPU. Also with the newly designed Virtual Sync, users can enjoy a smoother gaming experience by eliminating tearing artifacts. LucidLogix Virtu MVP could also dynamically assign tasks to the best available graphics resource, based on power, performance and system load. This allows users to fully utilize 3x faster video conversion with Intel Quick Sync Video technology while retaining high-end 3D rendering and gaming performance, provided by both NVIDIA and AMD graphic cards. When the discrete graphics card is not required, power consumption goes automatically down to near zero, making the system more environmentally-friendly. For users searching for perfection, LucidLogix Virtu MVP provides great graphical performance and the best flexibility and efficiency.
- ASUS P8H77-V - motherboard - ATX - LGA1155 Socket - H77
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel H77 Express
- Processor Socket
- 1 x LGA1155 Socket
- Max RAM Size
- 32 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 2 x SATA-600 (RAID), 4 x SATA-300 (RAID)
- USB / FireWire Ports
- 2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 6 x USB 2.0 via headers)
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel H77 Express
- Processor Socket
- LGA1155 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 32 GB
- Technology
- DDR3
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Audio
- Audio Codec
- VIA VT1708S
- High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 1 x PCIe 3.0 x16 , 1 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 3 x PCI
- Storage Interfaces
- SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-300 -connectors: 4 x 7pin Serial ATA - 4 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5
- RAID Features
- Intel Smart Response Technology
- 1 x PS/2 keyboard / mouse , 1 x DVI-D , 1 x VGA , 1 x DisplayPort , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 4 x USB 2.0 , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
- Internal Interfaces
- 1 x USB 3.0 - header , 6 x USB 2.0 , 1 x serial , 1 x audio , 1 x SPDIF out
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, SMBIOS 2.6 support, UEFI BIOS
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- ASUS Q-Fan, C.P.R. (CPU Parameter Recall), jack retasking, ASUS Anti-Surge Protection, MemOK!, ASUS Q-Design, GPU Boost, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, audio jack detect technology, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, ASUS TurboV, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, Fanless Design Heatsink, ASUS Protect 3.0 Technology, Conductive Polymer Capacitors, USB 3.0 Boost, AMD Quad CrossFireX technology support, Intel Rapid Start Technology, Intel Smart Connect Technology, Lucid Virtu MVP, 6+1+2 Phase Power Design
- Cables Included
- 2 x Serial ATA cable
- Software Included
- Drivers & Utilities, ASUS AI Suite II, ASUS Update
- Plug and Play, ACPI 2.0a, ErP Ready
- 30.5 cm
- 22.6 cm
