This motherboard supports the latest Intel Lynnfield processors in LGA1156 package, which has memory and PCI Express controller integrated to support 2-channel (4 DIMMs) DDR3 memory and 16 PCI Express 2.0 lanes, providing great graphics performance. Intel Lynnfield processor is one of the most powerful and energy efficient CPU in the world.
P7P55D-E PRO brings you the multi-GPU choice of either SLI or CrossFireX. The motherboard features the most powerful Intel P55 platform to optimize PCIe allocation in multiple GPU configurations. Expect a brand-new gaming style you've never experienced before!
The Intel P55 Express chipset is the latest one-chipset design to support latest 1156 socket Intel Core i7/Core i5/Core i3 processors. Intel P55 providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability.
This motherboard supports the latest PCIe 2.0 devices for double speed and bandwidth which enhances system performance.
The motherboard supports DDR3 memory that features data transfer rates of 2200(O.C.) / 1600 / 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance.
Experience ultra-fast data transfers at 4.8 Gb/s with USB 3.0. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10X faster and is also backward compatible with USB 2.0 components.
Supporting next-generation Serial ATA (SATA) storage interface with onboard Marvell controller, this motherboard delivers up to 6.0 Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems.
The ultimate O.C. processor satisfies every level of overclockers - from die-hard enthusiasts to beginners. Auto tuning intelligently pushes the system to the fastest clock speeds while maintaining stability. Turbo Key boosts performance with just one touch; while TurboV offers more options to advanced overclockers to achieve world O.C.Moreover, upgrade your CPU at no additional cost with CPU Level Up!
Achieve extreme yet stable overclocking results automatically with Auto Tuning! With built-in stability testing, Auto Tuning lets even beginners improve performance with no additional cost.
The T.Probe microchip detects and balances power phase loads and temperatures real-time. With optimal power phase functions, components run cooler and extend system lifespan.
The groundbreaking 12+2 phase VRM design is brought to the ASUS motherboards. 12+2 phase power design, 12-phase for Core and extra 2-phase for memory controller inside CPU, can provide the highest power efficiency, and hence generates less heat to effectively enhance the overclocking capability. With the high quality power components such as low RDS (on) MOSFETs, Ferrite core chokes with lower hysteresis loss and 100% Japan-made high quality conductive polymer capacitors, ASUS 12+2 phase VRM design also ensure longer component life and minimum power loss.
Intel P55
The Intel P55 Express chipset is the one-chipset design to support latest 1156 socket Intel Core i7/Core i5/Core i3 processors. Intel P55 providing improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. -
Flexible multi-GPU solutions, your weapon of choice
The motherboard features the most powerful Intel P55 platform to optimize PCIe allocation in multiple GPU configurations. Expect a gaming style you've never experienced before! -
Double speed, double bandwidth
This motherboard supports the PCIe 2.0 devices for double speed and bandwidth which enhances system performance. -
Dual-channel DDR3 2200(O.C.) / 1600 / 1333 / 1066 support
The motherboard supports DDR3 memory that features data transfer rates of 2200(O.C.) / 1600 / 1333 / 1066 MHz to meet the higher bandwidth requirements of the latest 3D graphics, multimedia, and Internet applications. The dual-channel DDR3 architecture enlarges the bandwidth of your system memory to boost system performance. -
True USB 3.0 support
Experience ultra-fast data transfers at 4.8 Gb/s with USB 3.0 - the connectivity standard. Built to connect easily with next-generation components and peripherals, USB 3.0 transfers data 10x faster and is also backward compatible with USB 2.0 components. -
True Serial ATA 6.0 Gb/s support
Supporting next-generation Serial ATA (SATA) storage interface, this motherboard delivers up to 6.0 Gb/s data transfer rates. Additionally, get enhanced scalability, faster data retrieval, double the bandwidth of current bus systems. -
Auto system level up
Achieve extreme yet stable overclocking results automatically with auto tuning! With built-in stability testing, Auto Tuning lets even beginners improve performance with no additional cost. -
Leading active cooling technology
The T.Probe microchip detects and balances power phase loads and temperatures real-time. With optimal power phase functions, components run cooler and extend system lifespan. -
System level energy saving
The ASUS EPU - the world's first power saving engine, has been upgraded to a six engine version, which provides total system power savings by detecting current PC loadings and intelligently moderating power in real-time. With auto phase switching for components, the EPU automatically provides the most appropriate power usage via intelligent acceleration and overclocking - helping save power and money. -
Active quiet and cool
ASUS Fan Xpert intelligently allows users to adjust both the CPU and chassis fan speed according to different ambient temperature, which is caused by different climate conditions in different geographic regions and system loading. Built-in variety of useful profiles offer flexible controls of fan speed to achieve a quiet and cool environment. -
Enjoy high-end 8-channel sound system on your PC
The onboard 8-channel HD audio CODEC enables high-quality 192KHz/24-bit audio output, jack-sensing feature, retasking functions and multi-streaming technology that simultaneously sends different audio streams to different destinations. This motherboard now adopts the future standard to deliver the most vivid audio enjoyment! -
DTS Surround Sensation UltraPC
DTS Surround Sensation UltraPC delivers exceptional 5.1 surround experience through the most common PC audio setups - your existing stereo speakers or headphones. In addition to virtual surround, "Bass enhancement" provides stronger low frequency bass sound, and "Voice clarification" provides clear human dialog even with loud background sound. With these technologies, you may experience a better home-theater audio with ease. -
Easy and comfortable installations
The specially designed ASUS Q-Shield does without the usual "fingers" - making it convenient and easy to install. With better electric conductivity, it ideally protects your motherboard against static electricity and shields it against Electronic Magnetic Interference (EMI). -
Make connection quick and accurate
ASUS Q-connector allows you to connect or disconnect chassis front panel cables in one easy step with one complete module. This unique adapter eliminates the trouble of plugging in one cable at a time, making connection quick and accurate. -
Conveniently store or load multiple BIOS settings
The motherboard features the ASUS O.C. profile that allows users to conveniently store or load multiple BIOS settings. The BIOS settings can be stored in the CMOS or a separate file, giving users freedom to share and distribute their favorite overclocking settings. -
IEEE 1394a interface
IEEE 1394a interface provides high speed digital interface for audio/video appliances such as digital television, digital video camcorders, storage peripherals and other PC portable devices. -
S/PDIF-out on back I/O port
This motherboard provides convenient connectivity to external home theater audio systems via coaxial and optical S/PDIF-out jacks. It allows to transfer digital audio without converting to analog format and keeps the best signal quality.
- ASUS P7P55D-E PRO - motherboard - ATX - LGA1156 Socket - P55
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel P55 Express
- Processor Socket
- 1 x LGA1156 Socket
- Compatible Processors
- Core i5, Core i3, Core i7
- Max RAM Size
- 16 GB
- RAM Supported
- 4 DIMM slots - DDR3, non-ECC, unbuffered
- Storage Ports
- 1 x ATA, 9 x SATA, 1 x eSATA
- USB / FireWire Ports
- USB 3.0, FireWire
- USB Ports Configuration
- 14 x USB
- FireWire Ports Configuration
- 2 x FireWire
- Audio
- HD Audio (8-channel)
- LAN
- Gigabit Ethernet
- Microsoft Certification
- Compatible with Windows 7
- Product Type
- Motherboard - ATX
- Chipset Type
- Intel P55 Express
- Processor Socket
- LGA1156 Socket
- Max Processors Qty
- 1
Supported RAM
- Max Size
- 16 GB
- Technology
- DDR3
- Bus Clock
- 1600 MHz, 1333 MHz, 1066 MHz
- Speed
- PC3-12800, PC3-10600, PC3-8500
- Supported RAM Integrity Check
- Non-ECC
- Registered or Buffered
- Unbuffered
- Dual channel memory architecture
Audio
- Audio Codec
- VIA VT1828S
- DTS Surround Sensation UltraPC, High Definition Audio
LAN
- Network Interfaces
- Gigabit Ethernet
- Expansion Slots
- 1 x CPU , 4 x DIMM 240-pin , 2 x PCIe 2.0 x16 , 2 x PCIe 2.0 x1 , 2 x PCI
- Storage Interfaces
- SATA-300 -connectors: 6 x 7pin Serial ATA - 6 devices - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices , JMicron JMB363: ATA-133 -connectors: 1 x 40pin IDC - 2 devices , JMicron JMB363: SATA-300 -connectors: 1 x 7pin external SATA - 1 devices , JMicron JMB363: SATA-300 -connectors: 1 x 7pin Serial ATA - 1 devices
- RAID Features
- Intel Matrix RAID Technology
- 1 x PS/2 keyboard , 1 x PS/2 mouse , 6 x USB 2.0 , 1 x LAN (Gigabit Ethernet) , 1 x audio line-out - mini-jack , 1 x audio line-out (surround)/line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (side surround) - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack , 1 x TOSLINK , 1 x SPDIF out , 1 x FireWire - 6 pin FireWire , 2 x USB 3.0 , 1 x storage - eSATA-300 - 7 pin external Serial ATA
- Additional Connectors (Optional)
- 1 x IEEE 1394 (FireWire), 6 x USB 2.0
- Power Connectors
- 24-pin main power connector, 8-pin ATX12V connector
- BIOS Type
- AMI
- BIOS Features
- DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS EZ Flash 2, ASUS O.C. Profile, ACPI 2.0a support, SMBIOS 2.5 support
- Manual Settings
- CPU frequency, processor core voltage, memory voltage, PCI Express x16 slot frequency, chipset voltage
- Sleep / Wake Up
- Wake on LAN (WOL), wake on ring (WOR)
- Hardware Features
- C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, ASUS Absolute Pitch Hi-Fi, ASUS Turbo Key, Stack Cool 3, T.Probe, 12+2 Phase Power Design, ASUS TurboV EVO, Q-DIMM, CrashFree BIOS 3, ASUS Q-Connector, ASUS AI NET2, ASUS Noise Filter, ASUS Stepless Frequency Selection (SFS), audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS Q-Shield, ASUS Precision Tweaker 2, Intel Extreme Memory Profile (XMP) support, ASUS Express Gate, ASUS Fan Xpert, NVIDIA Quad SLI Technology Support, ASUS TurboV, Intel Turbo Boost Technology, AMD CrossFireX technology support
- Software Included
- Drivers & Utilities, ASUS Live Update
- Plug and Play, ACPI 2.0, RoHS
- 30.5 cm
- 24.4 cm
Asus P7P55D-E PRO, Intel P55, 1156, 4DDR3, 2PCI-Ex16, CrossfireX/SLI, RAID, 8CHHD, USB3 & SATA6, ATX
