STRIX-GTX1080-O8G-GAMING
ASUS ROG Strix GeForce® GTX 1080 outshines the competition.
1936 MHz engine clock for outstanding performance and gaming experience.
DirectCU III with Patented Wing-Blade Fans delivers 30% cooler and 3X quieter performance.
ASUS FanConnect features 4-pin GPU-controlled headers connected to system fans for optimal thermal performance.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
Aura RGB Lighting to express personalized gaming style.
VR-friendly HDMI ports for immersive virtual reality experiences.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and lets you stream your gameplay instantly.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
DirectCU III technology with direct-GPU contact heat pipes
Exclusive DirectCU III cooling technology features direct-GPU contact heat pipes, that transport more heat away from the GPU, achieving cooler gaming performance. -
Triple wing-blade fans
DirectCU III features triple fans, engineered with a wing-blade design, that delivers maximum air flow and improved static pressure over the heat sink, while operating at quieter volumes. The fans also let you enjoy games in complete silence and make DirectCU III the cool and quiet graphics card. -
Targeted supplemental cooling
When gaming, GPU temperatures are often higher, than CPU temps. For optimal thermal performance, this graphics card features two 4-pin GPU-controlled headers, that can be connected to system fans for targeted cooling. -
Auto-Extreme technology
This ASUS graphics card is produced, using Auto-Extreme technology, an automated production process, that incorporates premium materials to deliver high quality. Auto-Extreme technology ensures consistent graphics card quality as well as improved performance and longevity. This manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption. -
Aura RGB lighting
Featuring Aura RGB lighting on both the shroud and backplate, the graphics card is capable of displaying different colors and effects for a personalized gaming system. -
The graphics card has two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
- ASUS ROG STRIX-GTX1080-O8G-GAMING - OC Edition - graphics card - GF GTX 1080 - 8 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 1080
- Memory
- 8 GB GDDR5X
- Core Clock
- 1784 MHz
- Boost Clock
- 1936 MHz
- CUDA Cores
- 2560
- Memory Interface
- 256-bit
- Max Resolution
- 7680 x 4320
- Interfaces Details
- DVI-D , 2 x DisplayPort , 2 x HDMI
- API Supported
- DirectX 12, OpenGL 4.5
- 4 cm x 29.8 cm x 13.4 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1784 MHz
- Boost Clock
- 1936 MHz
- CUDA Cores
- 2560
- VR Ready
- Max Resolution
- 7680 x 4320
- API Supported
- Native HDMI, NVIDIA G-Sync ready, NVIDIA GameWorks, Super Alloy Power II technology, DirectCU III with Triple Wing-Blade 0dB Fan Design, Nvidia GeForce GTX VR Ready, HDCP
- Size
- 8 GB
- Technology
- GDDR5X SDRAM
- Bus Width
- 256-bit
- Additional Requirements
- 6-pin + 8-pin power connectors
- 300 watt
- Included Accessories
- 2 x ROG touch fastener
- Software Included
- Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
- 4 cm
- 29.8 cm
- 13.4 cm
