Asus NVIDIA GeForce GTX 1060 DUAL OC 3GB GDDR5 PCIe3.0
Quicklinx: CB8FWS00 Mfr#: DUAL-GTX1060-O3G
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
DUAL-GTX1060-O3G
ASUS Dual series of GeForce® GTX 1060 graphics provide sweet spot performance.
1809 MHz Boost Clock in OC mode for outstanding performance and gaming experience.
Patented Wing-Blade Fans for max air flow with 105% more air pressure.
Perfectly Matched with ASUS X99 A II motherboards for optimized style and performance.
Industry Only Auto-Extreme Technology with Super Alloy Power II delivers premium quality and best reliability.
VR-Friendly HDMI Ports for immersive virtual reality experiences.
GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and instant gameplay streaming.
NVIDIA ANSEL for a revolutionary new way to capture in-game screenshots.
NVIDIA GameWorks™ provides an interactive and cinematic experience, as well as incredibly smooth gameplay.
The Sweet Spot Performance
ASUS Dual series of GeForce® GTX 1060 comes equipped with Patented Wing-Blade Fans for max air flow with 105% more air pressure. While exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming. ASUS Dual series of GeForce® GTX 1060 is perfectly matched with your ASUS X99-A II motherboard!
Max Air Flow with 105% More Air Pressure
A patented wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3X quieter volumes than reference cards.
Optimized Style and Performance
Perfectly matched with ASUS X99-A II motherboards
ASUS Dual series of GeForce® GTX 1060 graphics card and X99-A II motherboards share perfectly matching color themes and are ready for Windows 10. ASUS Dual series of GeForce® GTX 1060 is equipped with DirectX 12 to squeeze more graphics performance from the CPU and prevent GPU bottlenecks.
Enjoy immersive virtual reality experience
ASUS Dual series of GeForce® GTX 1060 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
  • The sweet spot performance
    ASUS Dual series of GeForce GTX 1060 comes equipped with Patented Wing-Blade Fans for max air flow with 105% more air pressure. While exclusive Auto-Extreme Technology with Super Alloy Power II components for superior stability. GPU Tweak II with XSplit Gamecaster that provides intuitive performance tweaking and instant gameplay streaming. ASUS Dual series of GeForce GTX 1060 is perfectly matched with your ASUS X99-A II motherboard!
  • Optimized style and performance
    ASUS Dual series of GeForce GTX 1060 graphics card and X99-A II motherboards share perfectly matching color themes and are ready for Windows 10. ASUS Dual series of GeForce GTX 1060 is equipped with DirectX 12 to squeeze more graphics performance from the CPU and prevent GPU bottlenecks.
  • Patented wing-blade fans
    A patented wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3x quieter volumes than reference cards.
  • Auto-Extreme technology with Super Alloy Power II
    ASUS graphics cards are produced using Auto-Extreme technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
  • VR-Friendly HDMI Ports
    ASUS Dual series of GeForce GTX 1060 graphics cards have two HDMI ports for connecting a VR device and display at the same time, so you can enjoy immersive virtual reality experiences anytime without having to swap cables.
ASUS DUAL-GTX1060-O3G - OC Edition - graphics card - GF GTX 1060 - 3 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
NVIDIA GeForce GTX 1060 - up to
3 GB GDDR5
Core Clock
1594 MHz
Boost Clock
1809 MHz
CUDA Cores
1152
Effective Memory Clock
8.008 GHz
Memory Interface
192-bit
Max Resolution
7680 x 4320
Interfaces Details
DVI-D (dual link) , 2 x HDMI , 2 x DisplayPort
API Supported
DirectX 12, OpenGL 4.5
4.3 cm x 24.2 cm x 13 cm
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1594 MHz
Boost Clock
1809 MHz
CUDA Cores
1152
VR Ready
Max Resolution
7680 x 4320
Interfaces Details
API Supported
Dual Slot Fan Cooler, Native HDMI, Dual Fan Design, NVIDIA G-Sync ready, NVIDIA GameWorks, Super Alloy Power II technology, AUTO-EXTREME technology, Nvidia GeForce GTX VR Ready, Wing-Blade Fans, HDCP
Size
3 GB
GDDR5 SDRAM
Effective Clock Speed
8.008 GHz
Bus Width
192-bit
Software Included
Display drivers, ASUS GPU Tweak II, XSplit Gamecaster 2 (1 year Premium licence)
4.3 cm
24.2 cm
13 cm
