Thanks to ASUS innovation, the EA-N66 presents the world's first versatile 3-in-1 dual-band 450Mbps Access Point/ Wi-Fi Bridge/ Range Extender with powerful performance and a truly exhilarating design. The stylish pyramid shape offers both artistic merit and a practical approach to technology, embedded with orthogonally-arranged antennas to lessen interference and boost signal coverage. Dual operating bands meet diverse needs for every user segment, while easy mode switching via the new interface lets you turn the device into different modes at will.
Unique Antennas
Patent orthogonal 3x3 antenna design
With the unique orthogonal arrangement of the three antennas designed by ASUS RD, EA-N66 is developed to prevent any interference between each antenna, boosting the coverage to the extreme.
Silver & black Pyramid with blue LED
ASUS presents the unprecedented design to the world, expressing the idea of space age and future technology. The distinctively rippled pattern signifies an excellent wide networking coverage of EA-N66.
Extreme Dual-band Speed
Selectable dual-band N900 data throughput
The dual-band operating mode can satisfy both normal and power user: with 2.4GHz, web surfing or e-mail delivery will be brisk, and when HD streaming or blu-ray movie are needed, the 5GHz band provides a blazingly fast lag-free home entertainment.
Access Point (AP) Mode
Create or upgrade your wireless home network.
Just connect the EA-N66 via an existing Ethernet cable and create home Wi-Fi networks with selectable 2.4GHz/5GHz bands. Get speedy and smooth networking, with dual-band operation connecting more devices wirelessly. The 2.4GHz band supports daily tasks like web browsing, while clearer 5GHz allows ultra-fast and stable online gaming, HD streaming, and heavy downloading. Each band works at up to 450Mbps!
Bridge Mode
Instant wireless for all your Ethernet devices!
The ASUS EA-N66 is compatible with any devices with Ethernet support, including smart TVs, multimedia players, games consoles, and your PC. WPS allows you to connect to your Wi-Fi router with a single button press.
Range Extender Mode
Expend your existing Wi-Fi network's coverage.
The ASUS EA-N66 can expand the range of your home's existing Wi-Fi network. Now you can enjoy trouble-free wireless networking in your backyard, garage, or attic.
Ultimate Performance
Extend your existing Wi-Fi network's coverage.
ASUS-patented antennas and high-quality components ensure wide-cover stable Wi-Fi even in multi-floor locations.
Easy Setup
Simply switch modes and build your networks
New user-friendly ASUS interface gives you neat and streamlined control, so network settings, mode switching, and device configuration are extra-easy.
Unique orthogonal 3 x 3 patent antenna technique
With the unique orthogonal arrangement of the three antennas designed by ASUS RD, EA-N66 is developed to prevent any interference between each antenna, boosting the coverage to the extreme. -
Fascinating silver and black pyramid outfit with blue LED
ASUS presents the unprecedented design to the world, expressing the idea of space age and future technology. The distinctively rippled pattern signifies an excellent wide networking coverage of EA-N66. -
Selectable dual-band 450 Mbps data throughput
The dual-band operating mode can satisfy both normal and power user: with 2.4 GHz, web surfing or e-mail delivery will be brisk, and when HD streaming or Blu-ray movie are needed, the 5 GHz band provides a blazingly fast lag-free home entertainment. -
Repeater and AP mode
Besides the Ethernet adapter mode, EA-N66 also have repeater and access point mode. With the wall-mounting design, the router can be mounted on wall to extend the home networking coverage. -
User-friendly UI
ASUS further enhance the already popular EZ UI to a whole level. The stylish web setup page is absolutely neat and simple to use, making networks settings as easy as possible for users.
- Header / Product Line
- ASUS
- Header / Manufacturer
- ASUSTeK COMPUTER
- Wired / Wireless
- Wireless
- Radio access point
- Speed
- 450 Mbps
- Standards
- IEEE 802.11a, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Networking / Wireless Protocol
- 802.11 a/b/g/n
- Header / Packaged Quantity
- 1
- Networking / Ports Qty
- 1
- Miscellaneous / Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-Enterprise, WPA-PSK, WPA2-Enterprise, WPA2-PSK
- Dimensions & Weight / Height
- 6.2 cm
- Header / Model
- EA-N66
- Form Factor
- External
- Networking / Remote Management Protocol
- HTTP
- Aerial / Aerial Form Factor (F)
- Internal integrated
- Compatibility
- PC, Mac, Unix
- Dimensions & Weight / Width
- 12.2 cm
- Dimensions & Weight / Depth
- 11.1 cm
- Dimensions & Weight / Weight
- 110 g
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
