Asus N3050I-C mini ITX Intel Celeron N3050 USB 3.0 Gigabit LAN
Quicklinx: BW1YWS00 Mfr#: N3050I-C
They are the world's biggest motherboard manufacturer, and renowned the design thinking that revolves around users - just like you. The engineers employ exacting standards to guarantee quality throughout the product's life, choosing the finest components for real-world protection. The motherboards are proven to be compatible with more than 1,000 components and devices, and undergo a minimum of 7,000 hours of strict validation. That gives you the peace of mind of knowing that ASUS motherboards are fit for all environments and applications. To build your PC with the best foundations, build it with an ASUS motherboard.
ASUS LANGuard socket has advanced signal-coupling technology and premium surface-mounted capacitors to improve throughput, while surge-protected and electrostatically-guarded components (ESD Guards) protect your motherboard from lightning strikes and static electricity.
Onboard resettable fuses prevent overcurrent and short-circuit damage. This extends beyond I/O ports to DRAM to safeguard the lifespan of both your system and connected device.
  • Strict compatibility and validation
  • LANGuard for advanced LAN protection
  • Enhanced DRAM overcurrent protection
  • 5K-hr solid-state capacitors that last 2.5x longer
    Solid-state capacitors are able to withstand extreme temperatures of up to 105°C for as long as 5,000 hours - that's two-and-a-half (2.5x) times longer than traditional capacitors. This exceptional durability means superb real-world endurance to more typical PC operating temperatures, ensuring that ASUS motherboards continue working longer.
  • Stainless-steel back I/O that lasts 3x longer
    ASUS motherboard back I/O panels are made from strong and corrosion-resistant stainless steel, which is bonded with a thin layer of chromium oxide to enhance anti-corrosive properties. Passing 72-hour spray salt endurance tests, ASUS stainless steel back I/O panels have a lifespan that's three times (3x) longer compared to ordinary panels.
  • ESD Guards for protection from electrostatic discharge
    Electrostatic discharge (ESD) can happen suddenly, and its damaging effects are easily underestimated. ASUS ESD Guards are tested to very high standards, capable of up to +/- 10 kV for air discharge and +/-6 kV for contact discharge. They employ an active protective circuit design to guard your system against electrostatic interference and damage, providing greater component longevity.
  • Proven compatibility
    Having the freedom to pick and choose the parts that go into your machine is at the heart of PC DIY. The extensive certification program focuses on providing the very best compatibility with the widest range of components and devices, giving you the freedom to build and upgrade without frustration. Compatible today and compatible far into the future - that's the ASUS way.
  • Designed - great compatibility with ASUS products
    When you choose an ASUS motherboard, it's likely you'll also go with ASUS for other components. ASUS designs products from the ground up so that graphics cards, sound cards and optical drives work flawlessly with your motherboard.
  • 170% faster transfer speeds with USB 3.0 Boost
    ASUS USB 3.0 Boost technology supports UASP (USB Attached SCSI Protocol) USB 3.0 in Windows 8. With USB 3.0 Boost technology, a USB device's transmission speed is significantly increased up to 170%, adding to already fast USB 3.0 performance.
ASUS N3050I-C - motherboard - mini ITX - Intel Celeron N3050
Motherboard - mini ITX
Intel Celeron N3050 (Dual-Core)
Max RAM Size
8 GB
RAM Supported
2 DIMM slots - DDR3, non-ECC, unbuffered
Storage Ports
2 x SATA-600
USB / FireWire Ports
2 x USB 3.0 + 2 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Graphics
Intel HD Graphics
Max Allocated RAM Size
512 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Microsoft Certification
Compatible with Windows 7
Supported RAM
Max Size
8 GB
DDR3
Bus Clock
1600 MHz, 1066 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture
Graphics
Graphics Controller
Intel HD Graphics
512 MB
Audio
Audio Codec
Realtek ALC887-VD2
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
2 x DIMM 240-pin , 1 x PCIe 2.0 x4 (x1 mode)
Storage Interfaces
SATA-600 -connectors: 2 x 7pin Serial ATA - 2 devices
1 x VGA , 1 x HDMI , 1 x LAN (Gigabit Ethernet) , 2 x USB 3.0 , 2 x USB 2.0 , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x serial , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack
Internal Interfaces
2 x USB 2.0 - header , 1 x serial - header , 1 x audio - header , 2 x USB 3.0 - header , 1 x parallel - header , 1 x LVDS - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS MyLogo2, ASUS Quiet Thermal Solution, ASUS EZ Flash 2, ACPI 2.0a support, UEFI BIOS, SMBIOS 2.8 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
ASUS Anti-Surge Protection, ESD Guards, ASUS EZ DIY, CrashFree BIOS 3, ASUS Fan Xpert, Fanless Design Heatsink, USB 3.0 Boost, Low EMI Solution, ASUS 5X PROTECTION, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, LANGuard
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS MyLogo2, ASUS EZ Flash 2, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version)
Plug and Play, ACPI 2.0a
17 cm
17 cm
