The ASUS MX series design was inspired by the concentric style of a sundial - a masterpiece of innovation created over a millennia ago. The ASUS design processes follow a similar line of thinking: simple yet innovative, natural yet empowering. The ASUS design team found inspiration in the sundial concept, and crafted a stand that symbolizes complete flexibility, professionalism, and meticulous art.
A masterful culmination of advanced technology and artistic design, the Designo series MX299Q ultra-wide 21:9 cinematic monitor represents the current state of the art in PC monitors. A sleek 29-inch AH-IPS display with an ultra-wide 21:9 ratio and 2560 x 1080 resolutions, the MX229Q delivers a 33% larger display area compared to a Full HD monitor for the best theater-like home entertainment. What's more, the MX299Q has an edge-to-edge, frameless cinematic display for an ideal multi display setup and stylish design.
Beauty beyond boundaries
The ASUS MX series design was inspired by the concentric style of a sundial - a masterpiece of innovation created over a millennia ago. The ASUS design processes follow a similar line of thinking: simple yet innovative, natural yet empowering. The ASUS design team found inspiration in the sundial concept, and crafted a stand that symbolizes complete flexibility, professionalism, and meticulous art. A masterful culmination of advanced technology and artistic design, the Designo series MX299Q ultra-wide 21:9 cinematic monitor represents the current state of the art in PC monitors. A sleek 29-inch AH-IPS display with an ultra-wide 21:9 ratio and 2560 x 1080 resolutions, the MX229Q delivers a 33% larger display area compared to a Full HD monitor for the best theater-like home entertainment. What's more, the MX299Q has an edge-to-edge, frameless cinematic display for an ideal multi display setup and stylish design. -
Ultra-wide resolution enhances work and play
With a display area equivalent to that of two 17-inch (5:4 aspect ratios) monitors placed alongside each other, the ASUS Designo series MX299Q ultra-wide 21:9 cinematic monitor has a display area 33% wider than a Full HD monitor. The 21:9 aspect ratios gives you more screen real estate for working with multiple windows side-by-side as you would with a secondary display. The 2560 x 1080 resolution also means there are no black bars above and below the image when watching widescreen 2.35:1 movies and gamers can also enjoy games in immersive cinematic widescreen. The LED-backlit AH-IPS display has extremely accurate color reproduction that makes the MX299Q ideally suited for both professional and home use. A 178-degree wide viewing angles also ensures minimal color distortion for enhanced screen sharing. -
Incredibly subtle yet sophisticated
The MX299Q features an ultra-slim profile measuring just 16.4 mm at its thinnest point. ASUS Designo series MX monitors have received numerous design accolades that include the 2012 Japan Good Design Award. The MX299Q also won a 2013 CES innovations awards in the video displays category. -
QuickFit virtual scale
With a simple hotkey, you can preview your photos and documents on screen in their actual sizes prior to printing; or work with an alignment grid to ensure everything is straight and true. -
SPLENDID Video Intelligence technology
ASUS SPLENDID is built upon a color engine that automatically analyzes and determines the nature and parameters of current visual tasks, adjusting display parameters to ensure optimal color accuracy and image fidelity.
- ASUS MX299Q - LED monitor - 29"
- LED-backlit LCD monitor - 29"
- Energy Class
- Class B
- Energy Consumption per Year
- 57 kWh
- Power Consumption (On mode)
- 39 W
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Full HD UWQHD 2560 x 1080
- Brightness
- 300 cd/m²
- Contrast Ratio
- 80000000:1 (dynamic)
- Response Time
- 5 ms (grey-to-grey)
- Colour Support
- 16.7 million colours (8-bit)
- Colour Gamut
- 100% sRGB
- Input Connectors
- DVI-D, DisplayPort, HDMI (MHL)
- Speakers
- Integrated
- Tilt
- Voltage
- AC 120/230 V (50/60 Hz)
- Black, silver
- 70.02 cm x 21.51 cm x 39.1 cm
- 5.5 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified
- UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, J-MOSS, ErP Ready
- Display Type
- Energy Class
- Class B
- 57 kWh
- Diagonal Size
- 29"
- Panel Type
- AH-IPS
- Aspect Ratio
- 21:9
- Native Resolution
- Brightness
- 300 cd/m²
- Contrast Ratio
- Colour Support
- Colour Gamut
- 100% sRGB
- Response Time
- Horizontal Viewing Angle
- 178
- Vertical Viewing Angle
- 178
- Backlight Technology
- LED backlight
- Controls & Adjustments
- Volume, brightness, contrast, gamma correction, input select
- sRGB colour management, HDCP, frameless, ASUS Splendid Video Intelligence Technology, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), ASUS Splendid Video Preset Mode, ASUS QuickFit Virtual Scale
- Black, silver
- 70.02 cm x 21.51 cm x 39.1 cm - with stand
- 5.5 kg
Audio
- Speakers - stereo - integrated
- Output Power / Channel
- 3 Watt
- DisplayPort , HDMI , DVI-D , Audio line-in , Headphones
Mechanical
- Tilt
- Tilt Angle
- -5/+20
- Security lock slot (cable lock sold separately), ASUS SonicMaster, Bang & Olufsen ICEpower
- Cables Included
- 1 x HDMI cable , 1 x DVI cable , 1 x audio cable , 1 x Mobile High-Definition Link (MHL) cable
- Security Slot Type
- Kensington security slot
- Input Voltage
- 39 W
- Power Consumption (Typical)
- 21.92 Watt
- 0.5 Watt
- On / Off Switch
- No
- Included Software
- ASUS MultiFrame
- Shipping Width
- 81.4 cm
- Shipping Depth
- 15.9 cm
- Shipping Height
- 50.6 cm
- Shipping Weight
- 8.1 kg
Sustainability Information
- ENERGY STAR Certified
C2G 2m Value Series™ High Speed HDMI® with Ethernet | In Stock | £8.33 |
