Asus Motherboard Micro ATX LGA1151 Socket H110 USB 3.0
Quicklinx: D21DWS00 Mfr#: H110M-R
As organizations strive to stay ahead of performance bottlenecks, 10G switching is as important as ever to meet the increasing network demands. The NEW ProSAFE XSeries switches from NETGEAR – the leader in cost effective 10GbE copper switching offers:
  • 10GBASE-T/SFP+ connectivity and advanced L2+/Layer 3 Lite features.
  • Easily managed SMB access to 10G-capable servers and NAS systems.
  • Resilient 10G-enabled Core or Edge solutions with 24-port fully managed and 24/48 port smart managed switching.
  • A complete range – 5 Smart Managed switches for affordable and flexible needs deployment.
  • Advanced hardware protection
    Excellent 5X Protection II components, circuit design and exacting standards guarantee this motherboard exceptional quality and durability, as well as comprehensive protection. All these elements are designed to guarantee your system maximum protection and stability, giving you the benefit of decades of engineering experience from the best motherboard brand.
  • Boosted throughput 2.5 times surge resistance
    ASUS LANGuard is a hardware protection system that employs signal coupling technology and high-quality surface-mounted surge protection capacitors to ensure more stable connections and improved throughput. In addition, components are protected against overvoltage and electric shock, so they are more resistant to static electricity and electrical discharges.
  • Perfect energy design to protect your circuit
    The exclusive design of this circuit incorporates voltage regulators to protect your chipset, network ports and audio codecs from damage caused by an unstable or insufficient power source.
  • Prevention of short-circuit damage
    Resettable fuses have been integrated to prevent any overvoltage or short-circuit problems. This protection is provided not only on the I/O panel, but above all on the RAM slots, to guarantee good system performance and long life.
  • Precise control, stable power supply
    DIGI+ VRM intelligently manages processor power according to real-time demand. This reduces energy losses and improves system stability.
  • Three times more resistant to corrosion
    The stainless steel I/O interface is coated with chromium oxide, giving it a service life three times longer than other interfaces.
  • ESD Guards
    Electrostatic interference can occur suddenly, and its consequences are too often underestimated. ASUS ESD Guards technology works with a circuit specially designed to withstand interference of +/- 10 kV over the air, and +/- 6 kV in direct contact. This extends the life of components, and therefore of your machine.
  • Intuitive BIOS, recognized by the media
    To guarantee impeccable ease-of-use, the UEFI BIOS is mouse-controllable and has been updated to ensure faster settings and ever simpler functions. Whether you're a novice or an experienced overclocker, the UEFI BIOS will meet your expectations thanks to two modes, EZ and Advanced (simplified and advanced).
  • Take advantage of USB 3.0 instantly
    Two USB 3.0 ports await you on the front panel. Enjoy transfers ten times faster than with USB 2.0, and without having to contort yourself behind your PC tower to reach the ports.
  • Easy removal of PCIe components
    Easily accessible Q-Slot buttons help you quickly install and uninstall your graphics cards. Simply press the Q-Slot to remove the graphics card. This makes removing or installing a graphics card, whatever its size, a pure pleasure.
  • Easy RAM removal
    Even if you're using a small PC case, it's easy to install and remove memory modules with Q-DIMM. Small buttons are located at the end of the memory sticks, and you simply press them to detach them.
  • Case and processor fan control
    The exclusive Fan Xpert function ensures that each fan achieves the best balance between silence and cooling. With 100 series motherboards and their 3/4-pin case fans in PWM/DC mode, a simple setting in the BIOS allows you to run your fans in PWM/DC mode. Fan Xpert's Auto-Tuning mode scans and detects the characteristics of each fan for one-click parameter setting.
ASUS H110M-R - motherboard - micro ATX - LGA1151 Socket - H110
Motherboard - micro ATX
Chipset Type
Intel H110 Express
Processor Socket
1 x LGA1151 Socket
Compatible Processors
Pentium, Celeron, Core i5, Core i3, Core i7
Max RAM Size
32 GB
RAM Supported
2 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
4 x SATA-600
USB / FireWire Ports
2 x USB 3.0 + 4 x USB 2.0 + (2 x USB 3.0 + 2 x USB 2.0 via headers)
Max Allocated RAM Size
1024 MB
Audio
HD Audio (8-channel)
LAN
Gigabit Ethernet
Chipset Type
Intel H110 Express
Processor Socket
LGA1151 Socket
Max Processors Qty
1
Supported RAM
Max Size
32 GB
DDR4
Bus Clock
2133 MHz
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Dual channel memory architecture, Intel Extreme Memory Profiles (XMP)
Graphics
1024 MB
Audio
Audio Codec
Realtek ALC887
High Definition Audio
LAN
Network Controller
Realtek RTL8111H
Network Interfaces
Gigabit Ethernet
Expansion Slots
1 x CPU , 2 x DIMM 288-pin , 1 x PCIe 3.0 x16 , 2 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 4 x 7pin Serial ATA - 4 devices
2 x USB 3.0 , 4 x USB 2.0 , 1 x VGA , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x PS/2 keyboard , 1 x PS/2 mouse , 1 x LAN (Gigabit Ethernet) , 1 x DVI , 1 x HDMI
Internal Interfaces
2 x USB 2.0 - header , 2 x USB 3.0 - header , 1 x audio - header , 1 x parallel - header , 1 x serial - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector
BIOS Type
AMI
BIOS Features
DMI 2.0 support, WfM 2.0 support, Multilingual BIOS, ASUS Quiet Thermal Solution, UEFI BIOS, ACPI 5.0 support, ASUS EZ Flash 3, SMBIOS 3.0 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
ASUS Q-Design, Q-DIMM, ASUS EZ DIY, Q-Slot, CrashFree BIOS 3, ASUS EPU (Energy Processing Unit), Intel Extreme Memory Profile (XMP) support, ASUS Fan Xpert, Intel Turbo Boost Technology 2.0, ASUS DIGI+ VRM, ASUS Enhanced DRAM Overcurrent Protection, Preboot eXecution Environment (PXE), ASUS Stainless Steel Back I/O, LANGuard, ASUS 5X Protection II, overvoltage protection
I/O back plate
2 x Serial ATA cable
Software Included
Drivers & Utilities, ASUS AI Charger, ASUS AI Suite III, ASUS EZ Update, Antivirus (OEM version), Mobo Connect, Media Streamer, ASUS EZ Flash 3
Plug and Play, ACPI 5.0
21.08 cm
18.03 cm
