Asus MG279Q 27" 2560x1440 4ms (GTG) WQHD IPS 144Hz Gaming Monitor
Quicklinx: BCWKWS00 Mfr#: MG279Q
Diagonal Size: 27in
Max Resolution: 2560 x 1440
Response Time: 4ms
Speakers: Speaker(s)
Interfaces: DisplayPort, Mini DisplayPort, Mobile High-Definition Link (MHL)
£428.24 ex VAT
£513.88 inc VAT
A Universe of Gaming at Your Command
  • 27-inch, WQHD 2560 x 1440 resolution display with IPS technology provide wide-viewing angles, and clear, vivid visuals
  • 144Hz refresh rate and AMD FreeSync™ technology for seamless visuals and smooth gameplay
  • ASUS-exclusive Ultra-Low Blue Light, Flicker-Free, GamePlus, and GameVisual technologies provide a comfortable gaming experience
  • Ergonomically-designed stand with full tilt, swivel, pivot, and height adjustment for comfortable viewing position
This is a sleek 27-inch display with in-plane switching (IPS) technology and WQHD 2560 x 1440-pixel resolution. MG279Q offers frame rates of over 120fps (120Hz), and with a 4ms grey-to-grey (GTG) response time it delivers ultra-smooth performance for true-to-life gaming experiences.
MG279Q has a gamer-friendly design, with an exclusive five-way navigation joystick for quick navigation of the intuitive on-screen display (OSD) and a dedicated GamePlus hotkey, which displays a customizable crosshair and timer overlap for enhanced combat. The display's super-narrow bezel means that MG279Q blends beautifully into any setting, while the ergonomic design allows full tilt, swivel, pivot and height adjustment. MG279Q also has a smart cable-management system built in and it's VESA wall-mountable.
Connections include DisplayPort, Mini DisplayPort, two HDMI ports (for native WQHD) and a Mobile High-Definition Link (MHL) 2.0 socket for 1080p connections to mobile devices, plus simultaneous charging. MG279Q also has a built-in dual USB 3.0 hub for device changing and data transfers that are up to ten times (10X) faster than USB 2.0.
ASUS MG279Q - LED monitor - 27"
LED-backlit LCD monitor - 27"
Energy Class
Class B
Energy Consumption per Year
58 kWh
Power Consumption (On mode)
40 W
Adaptive-Sync Technology
AMD FreeSync
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
QHD 2560 x 1440 at 144 Hz
Pixel Pitch
0.233 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
4 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
2xMHL, DisplayPort, Mini DisplayPort
Display Position Adjustments
Screen Coating
Anti-glare
62.5 cm x 23.8 cm x 55.9 cm
7.3 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, FCC, RoHS, WEEE, PSE Mark, J-MOSS, EAC
Display Type
Energy Class
Class B
58 kWh
40 W
Diagonal Size
27"
AMD FreeSync
Built-in Devices
USB 3.0 hub
Panel Type
IPS
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.233 mm
Pixel Per Inch
109
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
4 ms (grey-to-grey)
Horizontal Viewing Angle
178
Vertical Viewing Angle
178
Screen Coating
Anti-glare
Backlight Technology
WLED
Controls & Adjustments
Input select, colour temperature
HDCP, anti-glare, Skin-Tone Selection, Trace Free Technology, ASUS Splendid Video Preset Mode, 100% sRGB colour gamut, ASUS GamePlus, ASUS VividPixel Technology, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology
62.5 cm x 23.8 cm x 55.9 cm - with stand
7.3 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
DisplayPort , 2 x USB 3.0 , 2 x MHL / HDMI , Mini DisplayPort
Mechanical
Tilt Angle
-5/+20
Swivel Angle
120
Rotation Angle
90
Height Adjustment
150 mm
VESA Mounting Interface
100 x 100 mm
1 x Mini DisplayPort-DisplayPort cable
38.7 Watt
Power Consumption Stand by
0.5 Watt
Power Consumption Sleep
0.5 Watt
On / Off Switch
No
Dimensions & Weight Details
Without stand - width: 62.5 cm - depth: 6.3 cm - height: 36.8 cm , With stand - width: 62.5 cm - depth: 23.8 cm - height: 55.9 cm - weight: 7.3 kg
ENERGY STAR Certified
Asus MG279Q 27 Bundle deal on Asus MG279Q 27" 2560x1440 4ms (GTG) WQHD IPS 144Hz Gaming Monitor
£527.41
Diagonal Size: 27in
Response Time: 4ms
Interfaces: Mini DisplayPort
Interfaces: Mobile High-Definition Link (MHL)
Brand: Asus
Price Range Ex VAT: 300 - 500
