Asus MG248QR 24" FreeSync DisplayPort HDMI DVI
Quicklinx: D2BYWS00 Mfr#: MG248QR
Diagonal Size: 24in
Max Resolution: 1920 x 1080
Response Time: 1ms
Speakers: Speaker(s)
Interfaces: DisplayPort, DVI, HDMI
Hurry, only 1 left in stock!
£254.63 ex VAT
£305.55 inc VAT
ASUS MG248QR is the fastest in its class, boasting a 1ms response time to eliminate smearing and motion blur. This lets you react instantly to what you see onscreen, especially in fast paced games - allowing you to take corners like a pro race car driver, or get that headshot like a seasoned pro. There's also the ASUS Extreme Low Motion Blur Technology to make objects in motion look sharper, so gameplay is more fluid and responsive.
With an astonishing 144Hz refresh rate, fast-moving visuals pose no problem for MG248QR. There's no frustrating lag or motion blur, so you get the upper hand in first person shooters, racers, real-time strategy and sports titles.
  • Lightning-fast 1ms response time with
  • Incredible 144Hz refresh rate
  • Adaptive-Sync technology for smooth gameplay
    MG248QR features Adaptive-Sync (Free-Sync) technology - it eliminates screen tearing and choppy frame rates to give you seamless visuals and smooth gameplay.
  • ASUS-exclusive GamePlus technology
    ASUS MG248QR features the ASUS-exclusive GamePlus hotkey to give you in-game enhancements that help you get more out of your game. A crosshair overlay provides four different crosshair options, so you can select the one that best suits the shooter you're currently playing.
  • Flicker-Free technology
    Flicker-Free technology reduces flicker to give you a comfortable gaming experience. This minimizes instances of eyestrain and other potentially damaging eye ailments when you're embroiled in long, drawn-out gaming sessions.
  • Ultra-low blue light technology
    ASUS ultra-low blue light technology reduces the amount of harmful blue. You can access and select four different filter settings onscreen easily through the OSD menu or DisplayWidget interface to find one that best suits the content you're viewing.
ASUS MG248QR - LED monitor - Full HD (1080p) - 24"
LED-backlit LCD monitor - 24"
Energy Class
Class B
Energy Consumption per Year
38 kWh
Power Consumption (On mode)
26 W
5-way joystick
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Full HD (1080p) 1920 x 1080 at 144 Hz
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
1000:1 / 100000000:1 (dynamic)
Response Time
1 ms (grey-to-grey)
Colour Support
16.7 million colours
Input Connectors
HDMI, DVI-D, DisplayPort
Display Position Adjustments
56.1 cm x 21.1 cm x 35.9 cm
5.2 kg
UL, VCCI, C-Tick, BSMI, cUL, WHQL, CB, CCC, PSB, FCC, RoHS, KCC, WEEE, PSE Mark, MEPS, J-MOSS, ErP Ready, E-Standby, UkrSEPRO, RCM, CU-EAC, TUV Rheinland Low Blue Light Certification, TUV Rheinland Flicker Free Certification
Display Type
Energy Class
Class B
38 kWh
26 W
Diagonal Size
24"
Panel Type
TN
Aspect Ratio
16:9
Native Resolution
Pixel Pitch
0.276 mm
Brightness
350 cd/m²
Contrast Ratio
Colour Support
Response Time
1 ms (grey-to-grey)
Vertical Refresh Rate
40 - 144 Hz
Horizontal Refresh Rate
30 - 160 kHz
Horizontal Viewing Angle
170
Vertical Viewing Angle
160
Backlight Technology
WLED
HDCP, Skin-Tone Selection, Trace Free Technology, ASUS Smart Contrast Ratio (ASCR), 72% NTSC colour gamut, ASUS GamePlus, ASUS VividPixel Technology, super narrow frame, Low Blue Light Mode, Flicker Free technology, ASUS EyeCare Technology, FreeSync Technology, ASUS GameVisual Technology, Colour Temperature Selection
56.1 cm x 21.1 cm x 35.9 cm - with stand
5.2 kg
Audio
Speakers - stereo
Output Power / Channel
2 Watt
Input
5-way joystick
DisplayPort , HDMI , DVI-D (dual link) , Headphones , Audio line-in
Mechanical
Tilt Angle
-5/+33
Swivel Angle
180
Rotation Angle
180
Height Adjustment
130 mm
VESA Mounting Interface
100 x 100 mm
Security lock slot (cable lock sold separately), VESA 100 x 100 mm
Security Slot Type
Kensington security slot
65 Watt
Power Consumption (Off Mode)
0.5 Watt
Dimensions & Weight Details
Without stand - width: 56.1 cm - depth: 5.045 cm - height: 32.91 cm , With stand - width: 56.1 cm - depth: 21.1 cm - height: 35.9 cm - weight: 5.2 kg
Shipping Width
66.4 cm
Shipping Depth
22.1 cm
Shipping Height
41.5 cm
Shipping Weight
7.7 kg
Asus MG248QR 24 Bundle deal on Asus MG248QR 24" FreeSync DisplayPort HDMI DVI
£353.80
Diagonal Size: 24in
Response Time: 1ms
Interfaces: DVI
Interfaces: HDMI
Brand: Asus
Price Range Ex VAT: 150 - 300
